Nikon d800 Princeton
Started Dec 31, 2013 | Photos
John1908 New Member • Posts: 5
Comment & critique:
Nikon D800 Tamron SP 24-70mm F2.8 Di VC USD
John1908 OP New Member • Posts: 5
Re: Nikon d800 Princeton
any thoughts on the pictures?
jmiller1948
jmiller1948 Contributing Member • Posts: 865
I'd work on the lens distortion.  It's pretty easy with different plugins for various software platforms.  I use PTLens in Aperture and it's really pretty simple.  I think that especially with buildings where there are a lot of vertical lines the degree of distortion you get with a 24 mm lens is distracting.
Joel
There is only you and your camera. The limitations in your photography are in yourself, for what we see is what we are.
Ernst Haas
 jmiller1948's gear list:jmiller1948's gear list
Nikon D700 Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
TOF guy MOD Forum Pro • Posts: 12,819
The pictures are sharp, are well-exposed and have good colors.
But the composition just does not appeal to me. I kind of like #2 though.
Also if you point your camera up doing architecture photography you should consider correcting the images during post processing as vertical lines converging up may be a distraction.
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Sigma 150mm F2.8 EX DG OS Macro HSM +5 more
Full Frame Regular Member • Posts: 337
Very nice set, composition could be slightly improved. If you want to get out with a group (they just did Princeton) try this.    http://www.meetup.com/PA-NJ-Photo-Tour-Enthusiasts/--
You can also look at their set of photos for Princeton.
http://www.meetup.com/PA-NJ-Photo-Tour-Enthusiasts/photos/18770152/
HDR man
http://www.flickr.com/photos/52333300@N05/
 Full Frame's gear list:Full Frame's gear list
Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 8-16mm F4.5-5.6 DC HSM Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +3 more
Fave Photog Senior Member • Posts: 1,241
Try A Different Forum
This is not meant to discourage you, some nice shots, but you may receive a better response in a forum that is dedicated to posting images, such as 'Landscape and Travel'.
The only connection your images have with this gear forum is that they were shot with a D800. Images are allowed in this forum but they are typically used to demonstrate a function or issue, etc., with a camera.
The Five 'Ps' of Photography:
*Proper Planning Prevents Poor Performance!*
thanks
hey thanks everyone for the comments. now that i look at them more, i see where my composition is indeed flat. i will for sure improve on that.
Ernie Misner
Ernie Misner Senior Member • Posts: 2,489
Re: Try A Different Forum
Some interesting compositions, especially the verticals.   The D800 has captured some nice range of tones.   Something tells me you are hand holding?   Nothing wrong with that although slower work on the tripod really fine tunes things and ISO 100.  About the keystoning distortion - with all those nice pixels the D800 has, try holding the camera more level, the crop a bunch later to get your composition.
sgoldswo
sgoldswo Senior Member • Posts: 5,590
I'm not that happy with the composition here, mainly because of the trees in shot which I'm not sure are the subject or not. I'm not with those who say you cannot post pictures without comment in a gear forum, but if you do, try not to replicate the same subject even if you do like both shots. Also, keeping posts to 3 or 4 shots is a good rule as is tying them to the gear you used with some kind of commentary or observation/insight.
That said, it's funny how much the buildings of princeton look like an Oxbridge college (speaking as someone who grew up near Oxford and attended Cambridge University), though I suppose that was the intention!
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
Ernie, thanks for your thoughts. Yes these were handheld using the tamron 24-70mm vc so i was pretty much okay with camera shake. Regarding the distortion, i tend to use Viewnx 2 and lightroom 5 for my workflow. For whatever reason, distortion is so hard for me to pick out and say "oh my i need to fix that" don't know what it is. Anyway, what's the best way in fixing this? Is there a lens correction that i have to enable?
Thanks for the help
"But" what? Oh, I see...you have no issue with people posting images as long as they conform to yourlist of rules. Gotcha! Thanks for the laugh!
yray
yray Senior Member • Posts: 1,478
I suggest using DxO Viewpoint to correct distortion. It is inexpensive and does an excellent job.
ryan2007 Forum Pro • Posts: 12,001
I think it is a matter of focal length choice. If you are able re-shoot using a 35 mm focal length.
If possible and you you have a lens that covers the initial 24 mm up to at least 70 mm take the same shot at each focal length and you'll see how the perspective will change. If you have to shoot wide with no correct it is best to keep the camera and lens level to the structure.
This can mean using a tall tripod with a cable release to get the camera taller than you into position. In short, don't tilt the camera up or down for architecture IMO.
If your intent is architecture photography correcting with the idea of what a tilt/shift lens can do is ideal.
sgoldswo
No, I'm trying to suggest some rules of thumb that are less likely to subject the OP to boorish comments. Whether he follows them is up to him.
Thanks for your insightful contribution.
The ability to discern hypocrisy is not your strong suit, is it?  Don't take it so hard, mkay?
Hey, any time!
ravinj Contributing Member • Posts: 587
Since I live a few miles from the campus, your post interested me. Not knowing your prior photographic experience, a few comments anyway:
1) Wide angle lenses are hard to master and it is difficult to pull off convincing shots with 24MM or even 28MM. I would suggest 50MM to start with. You will get much stronger pictures with 50MM or 85MM or 100MM. For the campus at Princeton, my two favorite focal lengths are 50MM and 90MM. 50MM gives a nice tight frame without losing any context.
2) Related to the point above: don't try to capture "everything" in one shot. That is not the point of using a wide-angle lens anyway. Capture one subject at a time.
3) I am assuming you have very steady hands and can handhold the D800 and get a sharp picture. If not, up the ISO or get a tripod.
Good luck.....
R.
 ravinj's gear list:ravinj's gear list
Sony Alpha 7 +1 more
A Corrected Image
Thanks for the help
I quickly did this using CS5 and the Lens Correction filter tool.  Mostly the vertical perspective needed to be adjusted with a little horizontal.
Note how much of the original image is 'lost' in order to straighten the verticals.  So keep that in mind when composing the original shot.
A more affordable image editing program to perform the needed lens corrections is made by DXO.  Google it for their web site.
David A. Hamments
David A. Hamments Senior Member • Posts: 1,432
Thanks for the help
I see you're using LR5 - there is a tool that is perfect for this....  the Upright Tool.  Google it and check out some of the fine video tutorials available to learn its use.  It's a new tool for LR5 and one of my favourites!
Cheers, D. Hamments
My Flickr Page: http://www.flickr.com/photos/dhamments2013/
 David A. Hamments's gear list:David A. Hamments's gear list
Nikon 1 V2 Nikon D7100 Nikon D750 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 +20 more
Robin Casady Forum Pro • Posts: 12,898
Some things to think about when composing...
Some things to think about when composing in camera:
1. What is the purpose of the picture? What are you trying sho/say? How effective does the composition do that?
2. Is there a center of interest? Most compositions need one. People want something to focus their attention on. The CofI helps tell the viewer what the image is about. Without it a viewer can feel somewhat lost.
3. Where is the CofI placed in the frame? Is it in a visually comfortable location? People will tell you about the Rule-of-Thirds, but it is often a little off. There are more pleasing geometric rules that have been used since before the Parathion was built. Google: "dynamic symmetry in photography"
A quick rule I was taught for a good placement of the CofI was to visualize a diagonal line from one corner of the frame to another. Then imagine a line from another corner that hits that diagonal at right angles. This gives you four possible CofI locations in the frame. It works best with a frame that has the proportions of a golden rectangle, but the FX frame is close enough. It does not work with a square frame. This is just a starting point, not a hard rule.
Consider whether the CofI draws your attention. Or is your eye distracted by something else? The eye goes to areas of high contrast. If there is something contrasting distracting in the frame, crop it out.
Consider balance. Does it feel comfortably balanced?
Those are some things to start with. Mostly, you can tell if they feel right. You just have to consider them.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
sgoldswo
Hey, any time!
I don't follow you. Please explain?
