AF method on 70D
Started Dec 31, 2013 | Discussions
tomtek1221
tomtek1221 Regular Member • Posts: 221
AF method on 70D
Could you explain to me the four choices that are available in the menu under AF method. I have my 70d set up as back focus button, one shot and single af point. I am thinking I would want to set AF method to Flex zone but which one?
Canon EOS 70D
Lemming51
Lemming51 Forum Pro • Posts: 13,986
Re: AF method on 70D
The 4 choices (that include Flex zone) you refer are for AF in Live View and Video shooting only.  Choice depends on your subject.  There isn't one "best" selection.  May have situations where manual focus is best.  Not sure I can add any more than what's described for the typical use and shortcomings of each that is given in pp. 233-244 of the 70D instruction manual..
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
tomtek1221
tomtek1221 OP Regular Member • Posts: 221
Thank you.
R2D2
R2D2 Forum Pro • Posts: 16,370
I use BB focus too (exclusively).  Have for years.  I set the camera to a single AF point and AI Servo, and have AF disassociated from the shutter button.  Focus can then be locked at any time by lifting your thumb from the button.  Very fast and convenient.
R2
Sony RX100 II Canon PowerShot G3 X Canon EOS 70D
MMACory
MMACory Senior Member • Posts: 1,328
You don't have to keep you thumb on the back button to keep the focus locked?  I may have to break down and read the manual.
 MMACory's gear list:MMACory's gear list
Canon EOS 70D Canon EF 85mm f/1.8 USM Canon EF 200mm f/2.8L II USM Canon EF 35mm f/2 IS USM Canon EF-S 10-18mm f/4.5–5.6 IS STM +2 more
R2D2
Right.  If you take your thumb off the button, it locks focus at that point.  Subsequent shutter button actuations will not start AF all over again (if you disassociate the shutter button from AF).
I find this an extremely useful feature.  You can even bring your camera down for a while, and then back up to shoot some more and the focus will still be locked at that point.  It also means that you can pre-focus on a particular subject (or a particular distance), then when you want to take a photo later, the lens is already very close to that distance and AF is lightning fast.  Works great with Players or Perched Birds or Events or Kids etc etc.  I couldn't go back to shooting the other way.
Now if you keep your thumb on the button, then the AI Servo will continue to focus, even through a burst (viewfinder AF).  Depending on what the subject is doing, I'll shoot using either or both of these methods.  It becomes second nature very quickly.
Have fun!
R2
MMACory
Wow.  Very cool.  Might have to try that and thanks.
