Extremely sharp, lot's of microdetails, bad ergonomics
Started Dec 31, 2013 | User reviews
frici
frici Junior Member • Posts: 38
This is the sharpest 24mm I have tried so far, sharper (and/or has more microdetail) than the AF-S 24-70/2.8, AF-S 17-35/2.8 or the AF-S 24/1.4.
The movements work the best on a D3/D4 size body. D200/D300/D700/D800 will limit the rotation (switch between portrait and landscape) because the knobs bump into the pentaprism house of the camera body.
Although the focus ring is really smooth and allows precise operation, the overall mechanics of the lens is rather disappointing because the tilt/shift lock knobs tend to overtighten themselves just by staying in the camera bag to a degree where you will need a pair of pliers to release it. Tightening the lock knobs requires large amount of force, which is hard to deliver as the knob heads are rather small and doesn't grip very well (especially in gloves, it is impossible to lock them). Without locking, the weight of the lens will prohibit keeping the set tilt angle, it will rotate by itself.
The axis of shift and tilt is fixed (unlike the new Canon T/S designs), and changing their orientation relative to each other needs a Nikon repair shop. The lens ships with the tilt and shift axis being perpendicular to each other. Landscape and architectural photography usually needs them to be parallel. Good news is, that if you can handle a screwdriver, you can do it yourself too, here is my tutorial on it:
http://blog.davidudvardyphoto.com/2008/12/25/swapping-the-tilt-and-shift-axis-nikon-pc-e-24-mm/
David Udvardy
interaction designer, photographer
work > prezi.com
photo > blog.davidudvardyphoto.com
 frici's gear list:frici's gear list
Nikon D3 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Voigtlander 58mm F1.4 Nokton SL II +1 more
Nikon PC-E Nikkor 24mm f/3.5D ED
Wideangle perspective control prime lens • Nikon F (FX) • 2168
Announced: Jan 29, 2008
frici's score
4.5
Average community score
4.5
