New bag for setup
Started Dec 30, 2013 | Discussions
chumphries
Regular MemberPosts: 107
New bag for setup
Dec 30, 2013
I like to use a sling bag for walking around with my DSLR. My current Lowepro SlingShot 202 AW isn't deep enough to support my recently purchased a Canon 6D, 24-70 f/2.8, and 70-200 f/4 IS. It works fine with the 24-70, but the 70-200 is too long when attached to the camera.
I'm looking for a sling type bag that will at least hold the camera, those two lenses, and a flash.
Canon EOS 6D
Aussie Coop
Regular MemberPosts: 392Gear list
Re: New bag for setup
In reply to chumphries, Dec 31, 2013
Have a look at the Tamrac Velocity 8x . It will accommodate your set-up nicely. Or go up to the 9x for some room to grow.
http://www.cambags.com/bag-type/slingbags-menu/tamrac-sling-bags.html
 Aussie Coop's gear list:Aussie Coop's gear list
Canon PowerShot S100 Canon EOS 7D Canon EOS 5D Mark III Canon EF 28mm f/1.8 USM Canon EF 85mm f/1.8 USM +10 more
Wei Kelun
Contributing MemberPosts: 524
Most camera bags these days are made of nylon and look like extreme mountaineering gear. If you want something just as useful, but with a different look, try Billingham:
http://www.billingham.co.uk/acatalog/Hadleys.html
Jules Tohpipi
Junior MemberPosts: 42Gear list
I ended up with a ThinkTank Urban Disguise 35 v2 to fulfil those requirements - after a very, very long period of research...
Some quick background first.  My kit consists Canon 7D (similar size to your 6D), Canon 17-55 f/2.8 IS (very similar size to your 24-70), Canon 70-200 f/4 (same size as yours), and a Canon 430EX ii flash.
I similarly wanted lenses to fit in attached, and ideally with hoods attached too.
In short, the ThinkTank UD35 allows you to do this.
It's not the size of a monster - in fact it is quite compact compared to my original expectations.  It's beautifully (and I mean really beautifully) made.
Just to clarify, down the centre slot, I can have either my 17-55 or 70-200 attached to the 7D; and it's an easy and comfortable fit. That includes having the hoods on in their forward-facing positions.  Whichever is attached, the other will fit down the right slot and with its hood attached facing forward.  The left slot is not so tall but accommodates my flash (it's not so tall because the grip-side of the 7D must sit on top of the left slot).
Right now, my UD35 is packed as follows: left slot = flash; centre slot = 7D with 17-55 f/2.8 attached with hood in forward position; right slot = 70-200 f/4 with hood reversed and 85 f/1.8 underneath with hood reversed (without the 85mm in there the 70-200 would fit in with hood facing forward).  My BlackRapid strap is attached in the main compartment, too. There's a trillion other hidey-holes with stuff in, including a slot for an iPad to the front, and a slot for a 12" laptop to the back.
Amongst other things, I like that it is not too wide (less bumping into other people in crowded situations); it being tall makes it more manageable than a wide bag IMO; and that the bag is beside me not behind me (good for security).
The strap is comfortable, the zips never snag, and it feels like it's going to last forever.  With top zip partially opened, the camera slides in and out effortlessly.
Bags are a personal thing but this is worth a look.
 Jules Tohpipi's gear list:Jules Tohpipi's gear list
Fujifilm X100S Canon EOS 5D Mark III Canon EF 85mm f/1.8 USM Canon EF 70-200mm f/4.0L USM Canon EF 24-105mm f/4L IS USM
chumphries
In reply to Jules Tohpipi, Jan 1, 2014
I ended up going with the Lowepro Slingshot 302 AW. I really liked my 202, but this one is a bit deeper to accommodate longer teles. I'm really partial to the sling style because I take my camera out/put it up a lot.
fordman1
Regular MemberPosts: 111Gear list
In reply to chumphries, 9 months ago
I have the 7DII, 17-55, and the 70-200L F4. I want to habe the 17-55 attached and the 70-200 in one of ther slots, but 70-200L clearly is too tall for any slot. What am I missing here? This bag is advertised as holding as many as 2 long lenses. No way!
 fordman1's gear list:fordman1's gear list
Canon PowerShot G15 Canon EOS 7D Mark II Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm f/4L IS USM Canon Extender EF 1.4x III +1 more
