working on exposure /lighting
Started Dec 29, 2013 | Photos
rska2013
Contributing MemberPosts: 506
Dec 29, 2013
c.c on lighting and exposure only please not the pose
Comment & critique:
LincolnB
Veteran MemberPosts: 4,008Gear list
Re: working on exposure /lighting
In reply to rska2013, Dec 30, 2013
At the very least there's some unattractive vignette going on in the upper corners.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony Alpha 7 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
Sailor Blue
Veteran MemberPosts: 8,676Gear list
The subject exposure looks pretty good, close to Rembrandt. The fill might be a bit strong for my taste but not by much. You might let the lighting fall off a bit more from the face downward. The biggest problem is that the hair looks dull & dead. A hair light would fix that.
You said not the pose but lighting and posing go together. The pose has the subject broad lit, which makes his face look wider (fatter) than it really is. Rotating the face to the subject's left until the ear just disappears and adjusting the lighting to again give you Rembrandt lighting would give you short lighting and be more flattering.
Sekonic - Frank Dispensa - Classical Posing and Portrait Lighting
Don't let the dark upper corners worry you. When doing seamless white all you need to do is get a pure white halo around the subject. It is easy to fix the rest of the "white" area in post processing. Of course if you can get the lighting right so that all the background is around +0.8 ± 0.2 stops then you won't have to fix it in post processing.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Fog Maker
Senior MemberPosts: 1,692
In reply to Sailor Blue, Dec 30, 2013
Sailor Blue wrote:
T It is easy to fix the rest of the "white" area in post processing. Of course if you can get the lighting right so that all the background is around +0.8 ± 0.2 stops then you won't have to fix it in post processing.
True, but these days it much easier to fix it in post,
instead of lighting the background proper ,which means additional flashes and equipment
to get it right.
rska2013
In reply to Sailor Blue, Dec 31, 2013
thank you very much for the great suggestions.......i did some selfies i will post later playing with black back ground
