Rokinon 24mm Tilt Shift Lens: First Photos
Started Dec 29, 2013 | Discussions
Dale108
Dale108 Veteran Member • Posts: 6,250
5
This is a lens that I have wanted for a long time.  While I had the Arasat 35mm tilt shift at one time, the IQ was not to my expectations.  The Rokinon 24mm has a nice focal length and allows shifting or tilting in all directions.  A few days ago I visited the Rocky Mountains in Alberta to try it out.  The first pic is shot at f5.6 and appears quite sharp.  Both pictures are with the K3.  The focus peaking on the K3 allows you to select the degree of tilt for max sharpness across the frame.
Dale
Greyser Veteran Member • Posts: 4,158
Re: Rokinon 24mm Tilt Shift Lens: First Photos
Very interesting. Would you please post more details, e.g. approx. degree of tilt and/or shift what was used for example for the shot #1? Was it shot hand held or from a tripod? Other technical specifics?
 Greyser's gear list:Greyser's gear list
Pentax K-5 Pentax K-01 Pentax K-5 IIs Pentax K-3
Dale108
Dale108 OP Veteran Member • Posts: 6,250
The 1st shot had 2 deg of tilt and all photos are from a tripod.
Dale
Joseph Tainter Veteran Member • Posts: 9,267
Is it designed for full frame, or APS-C?
Thanks,
Joe
Ian Leach Senior Member • Posts: 1,410
Without vertical lines how do you decide what tilt and shift to apply or is it about getting sharp foreground? Great first photo scene.
brecklundin Senior Member • Posts: 1,995
Thanks, never knew this one existed...I think.
Nice first shots too. One thing I've wanted was a TS lens for interiors as well as exteriors. I know there is an M42 option out there (have the link forget the name) but this Samyang/Rokinon looks interesting. Might end up on my 2014 wish list, especially as I might be getting a lot more of that sort of work.
I had planned on picking up a used 1D3 or even a used 5Dmk II or mk III and the Canon TS 17mm...but this is a new option.
This was an interesting review from the perspective (pun intended) of real world use:
http://fstoppers.com/fstoppers-reviews-the-rokinon-24mm-f3-5-tilt-shift-lens
It sure had potential I do wish this was a 17mm though.  But, hey it's a great start.  Keep the example shots coming!!  Inquiring minds want to know.
Dale108
Hi Joe:
It is designed for a FF; actually larger than FF as you need lots of sensor coverage for shifting.
Dale
Dale108
Hi Ian:
For tilt there are Tables on the web that provide an approximate value; in practice, you tilt until you see the max focus using Live View.
Dale
Dale108
Re: Thanks, never knew this one existed...I think.
Yes 17mm for APS-C would be ideal but if Pentax ever come out with a FF, 24mm would be great.
Dale
leopold Forum Pro • Posts: 14,030
# 1 is superb, and beautiful PP.
It's a kind of lens that is missing to my kit, might be tempted by it eventually.
 leopold's gear list:leopold's gear list
Fujifilm X-E1 Canon EOS 7D Fujifilm XF 27mm F2.8 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF 400mm f/5.6L USM +3 more
Dale108
DAVID MANZE Veteran Member • Posts: 3,530
Focus peaking is a gods-send for here for you and some great shots!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Pentax K-01 Pentax K-3 Nikon D7100 Nikon D750 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +20 more
Dale108
Jim Beverlin Veteran Member • Posts: 3,309
Dale - #1 is superb.  Since I do a lot of landscapes and I was thinking about the FA24mm f2.0.  I am going to look into this lens since I have wanted a tilt shift lens and the length would be ideal.
Seems like this lens would work very well on my K-01 with focus peaking.
Thanks for posting and hope you post more images very soon.
JRB
Dale108
Thanks Jim.  Yes it does work well with the K01 also.
Dale
Rod McD Veteran Member • Posts: 3,933
Hi Dale,
Thanks for posting.  I love the first one - a classic near-far landscape.  I used to shoot LF and later made my own TS adapted lenses for my Pentax 645 (film, not the D) when I was using that.  I really miss movements........they just add sooooo much.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +8 more
miles green
miles green Veteran Member • Posts: 5,200
All this is really bad for my LBA.... I might have to order one of these.....
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax K-1 Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +10 more
Ian J G Contributing Member • Posts: 615
Nice to see what you can do with it; the first one really shows you the focus possibility.
This is a very interesting lens, though dangerous for budgetary considerations.
Let's see more
Keep at it!
Ian
Dale108
Dale108
Agreed Ian that this is not an inexpensive lens.
Dale
