Leica M Diopter
Started Dec 29, 2013 | Discussions
user_name Veteran Member • Posts: 3,134
Leica M Diopter
Are these things stackable to get greater dioptor strength?
I am trying to find the right dioptor for my M8.  Bought a +1 , but that is not enough.
I am thinking a +2 is my next try, but I hate the "buy & try" approach if I can avoid it.
 user_name's gear list:user_name's gear list
Leica M8 Nikon D700 Nikon D800 Leica M Typ 240 +1 more
(unknown member) Senior Member • Posts: 2,216
Re: Leica M Diopter
You can stack close-up lenses and the strength in diopters approximately adds up, but I don't know if viewfinder correction lenses have the right threads in them to allow you to stack them...
Joe
"Well, it's too late to die young now..."
 Joe Pineapples's gear list:Joe Pineapples's gear list
Ricoh GR
DaveOl
DaveOl Veteran Member • Posts: 3,073
Re: Leica M Diopter
There is a company in South Africa that grinds eyepieces to your prescription.  I don't remember the name of the company, but they are very expensive.
 DaveOl's gear list:DaveOl's gear list
Nikon D300S Epson Stylus Photo PX720WD
RaajS Veteran Member • Posts: 5,776
Re: Leica M Diopter
Check this http://www.japanexposures.com/shop/accessories/ms-mag-x1.15-magnifier-for-leica-m.html.  It's a magnifier but has a variable diopter and is available in different magnifications.  I've used this on both my M8 and M9 and found it invaluable.
Good luck!
-raaj
'Change is not Mandatory, you don't have to Survive...'
SeekingLight.net
user_name OP Veteran Member • Posts: 3,134
Re: Leica M Diopter
Good luck!
-raaj
SeekingLight.net
Is it really $3,000?
Re: Leica M Diopter
Good luck!
-raaj
SeekingLight.net
Approx $170 (USD)...
-raaj
SeekingLight.net
Re: Leica M Diopter
That's better, but it claims it is not available in US.  Must be a patent infringement.
I think I figured it out...
The M system viewfinder is already biased to -.5 diopter.
I bought a +1 and that was not enough, but my Nikons are adjusted to +1, so I was confused why it did not seem to work.
A +2 might be the ticket as that works out to a +1.5 correction and my near vision has getting a little worse as time goes on.
JDLaing
JDLaing Senior Member • Posts: 6,185
Re: Leica M Diopter
 JDLaing's gear list:JDLaing's gear list
Leica D-Lux (Typ 109) Leica M8.2 Olympus OM-D E-M5 Leica M Typ 240 Sony Alpha 7 II +15 more
