NJ service center??
Started Dec 28, 2013 | Discussions
Sal18
Veteran MemberPosts: 4,777Gear list
NJ service center??
Dec 28, 2013
I think I have to send my 5DIII in to get serviced for a weird problem I had on my last shoot. I am interested in recent experience with the New Jersey service center. Good? Not so good? Slow? Fast?
My problem is that though I have never shot jpegs with this camera, only RAW, ¾ of the files from my last shoot were jpegs! I had done no menu diving at all…just used my usual go-to settings. Since the camera has another month under warrantee I thought it would be worthwhile to send it in.
I'm grateful for your wisdom and advice,
Sal
Canon EOS 5D Mark III
Sal18
Sal18 OP
Re: NJ service center??
In reply to Sal18, Dec 29, 2013
Anyone?
(Apologies if bumps are rude manners!)
Sal
Steven-T
Veteran MemberPosts: 3,316Gear list
Sal
3-4 years ago, my 5D had a power problem.  The camera was sent in four times, and I finally got a replacement refurbished unit.  About two years ago, I had a problem with my 5D2, again power problem.
If memory serves, from their website, I found a form, filled it and sent camera in.  The first time was under warranty, subsequent ones were not, but within the three months period for repair warranty (?).
It was pretty fast, within a week returning.  My experience is quite positive.
Good luck. . . Steven
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
Michael Fryd
Senior MemberPosts: 2,672
Before sending it in, I would reset the camera settings, make sure the firmware is up-to-date, and see if you still have the problem.
These are the steps the repair facility will go through.
There is little benefit in sending in the camera if you can resolved the issue yourself.
Sal18
Sal18 OP
In reply to Michael Fryd, Dec 29, 2013
Thank you, Steven and Michael. So far I've not been able to get it to repeat this behavior. My concern is that there is one month left on the warranty and ir may not do this again during this time. However, it is probably a good idea to re-do the firmware update? Do the recent one again? And a camera reset. (ugh!)
Sal
hotdog321
Forum ProPosts: 14,574Gear list
I'm a photojournalist and have used the NJ pro location several times for fairly major disasters: SNAPPED a 16-35 in two, electronic fail on my 300 f/2.8, smashed in the pentaprism on a 1D mark II, lens knocked out of alignment, shutter broken, etc.
The NJ folks have always been fast, professional and done a first-rate job. The repair charges have increased considerably over the years, but I don't think they are in control of billing.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
90c4
Contributing MemberPosts: 561
New Jersey is fast, but I wouldn't bother. If you can't repeat the problem, they won't be able to either. I can almost guarantee that you bumped the mode dial (I've bumped mine, despite the lock) and were in a mode that wasn't set to RAW.  AV, TV, etc all have separate settings I believe. Check the EXIF of the JPG shots.
Michael Fryd
Sal
I have had issues getting intermittent problems repaired.  If they can't quickly reproduce it, they can't fix it.
I had an issue with a 7D that would lock up a few times a day.  Removing the battery would reset it, but if the lockout occurred at the wrong time, I could lose the shot.
The first two times I sent the camera in, they found nothing wrong, and sent it back.  To be fair, the techs don't have the time to sit around playing with the camera hoping it will fail.
I am a CPS member and complained.  I sent it back a third time and they replaced some main board, which fixed the problem.
The advantage of sending it in now, is that you get it on record that the failure occurred during the warranty period.  If you are lucky, you will get a 6 month warranty on the "repair".
If you already have the latest firmware, I would not bother with updating again.
I would double check the manual to make sure that this is a camera malfunction and not user error.  For instance, even when the camera is set to RAW, HDR images will be saved as JPEG.
