Epson 3800 Banding
Started Dec 27, 2013 | Discussions
John Roy
Contributing MemberPosts: 645
Epson 3800 Banding
Dec 27, 2013
This is a topic which has arisen before, and I have followed all suggestions to no avail. My 3800 is now exactly 5 years old and has performed brilliantly over this time, but has developed an annoying banding, as shown in this scan of my son, with the original TIFF on the left:
Digital file on L, scanned photo on R. Original 20cm high.
I am running the latest iMac with OS X Mavericks, and have installed the latest Epson driver.
Photoshop CS6, with Epson's own profile for Matt Archival, Pro 38 ARMP.
Numerous head alignments both via utility and printer panel
Numerous nozzle checks and cleanings
Power cleaning x2
Any suggestions gratefully received. I know there's bait of colour calibration to be done.
Leica X2
Hugowolf
Forum ProPosts: 12,336
Re: Epson 3800 Banding
In reply to John Roy, Dec 27, 2013
Power cleaning x2
And the head aligned and the nozzle checks were clean?
Brian A
Gesture
Veteran MemberPosts: 3,341Gear list
Are you printing at highest possible printer resolution?
Hugowolf
In reply to Gesture, Dec 27, 2013
Good question, and also whether bi- or uni-directional.
Brian A
John Roy
In reply to Hugowolf, Dec 27, 2013
Just did another nozzle check: defect in light magenta, slightly so in light cyan.
Head clean no improvement, power clean no improvement.
Are we talking print head ?
John Roy
I've always printed at 360dpi, no problems.
I had to look the direction thing up. If you mean LS_High Speed, it is not checked.
Hugowolf
That would be enough to cause a slight banding.
Repeated head cleaning isn't a good thing, especially repeated power cleanings.
Are you using OEM or third party inks?
Brian A
John Roy
Always Epson inks
jtoolman
Senior MemberPosts: 5,314
You are confused!! We do not mean image resolution ( Pixels per inch ) We mean PRINTER resolution as in quality. In your PRO3880 printer driver you will find that. Pick Quality 5
You also need to clear out those blocked nozzles. Or NOTHING will help!
You might need the folded paper towel wetted with Windex with Ammonia under the head trick.
Stop doing clean cleans as these will only cause to waste more ink. Try only running several nozzle checks every 20-25 minutes and take a look to see if the SAME EXACT patter or missing nozzles occurs. Also turn off the printer tonight over night and then Power it back on in the morning and after it pressurizes do another nozzle check and compare with the previous sets.
Joe
My main printers ( there are more though )
2200/CX-7400/R-1900/R-2000/R-2400/R-2880/PRO-3800/R-340/R-380/SP-1400/Artisan- 725/Canon-Pro-9000MKII/Canon-PRO-9500 MKII / PRO-100
My videos!
PRO-100 Printing out of various sources
http://www.youtube.com/watch?v=fiYfoDpKk5Y
PRO-100 Setup and Basic Use:
http://www.youtube.com/watch?v=LlV7cqqladQ&feature=youtu.be
New way to refill EPSON OEM carts:
http://www.youtube.com/watch?v=BU6fi9VCOo0
01 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Intro
http://www.youtube.com/watch?v=gccxLvfknuE&feature=youtu.be
02 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part One
http://www.youtube.com/watch?v=9zJepnArTdo&feature=youtu.be
03 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part Two
http://www.youtube.com/watch?v=TEeDpEIUkkQ&feature=youtu.be
04 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Refilling
http://www.youtube.com/watch?v=lRr-rUu9hkU&feature=youtu.be
05 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Printing
http://www.youtube.com/watch?v=QaQju7xOKy4&feature=youtu.be
Cleaning the Purge Pad and Wiper on the Epson PRO 3800
http://www.youtube.com/watch?v=iKzxAm9QtWo
Basic Epson R2000 Maintenance
http://www.youtube.com/watch?v=wRZU1_XD7xE
Calibrating your monitor and Printing to the R2000
http://www.youtube.com/watch?v=-2X7MSd-ebE
Refillable 3800 3880 cart sticking problems
http://www.youtube.com/watch?v=rDi1lhDoWjM
Gloss Optimizing Prints
http://www.youtube.com/watch?v=9iRUoUwwSlA
Printing out of Photo Shop to Epson and Canon Printers
http://www.youtube.com/watch?v=mPV75Ak0R1g
Printing in LR-2 this time to the EPSON R2880
http://www.youtube.com/watch?v=huZ6BlXQqew
Multi Image printing in LR
http://www.youtube.com/watch?v=7xoJFJVemo8
Basic Printing in Qimage Ultimate
http://www.youtube.com/watch?v=uvrEAam6H_U
Canon PGI-9 Cart Refilling by the "Dribble" method
http://www.youtube.com/watch?v=mGBzHSQx5bU\
Refill Canon PGI 9 via Freedom Method
http://www.youtube.com/watch?v=VjgQIWLw10M
Refilling and resetting R2000 China Carts
http://www.youtube.com/watch?v=hh2wuzwezxM
Refilling Epson OEM carts - Thorough, Long Winded Version!
http://www.youtube.com/watch?v=fB8QspjBbhk
Taking out the CURL on prints done on from roll paper
http://www.youtube.com/watch?v=Q8Zj9dtzeU0
Taking out the Curl - TWO.mpeg
http://www.youtube.com/watch?v=VataFqqN-Jo
R2000 Push Buttom Reset Carts
http://www.youtube.com/watch?v=xzYreszSdAM
Creating a Color Profile & Printing on the Canon Pixma PRO 9000 MKII using Color Managent
http://www.youtube.com/watch?v=D0N-jgaJY94
Print Room Visit + Filling and Priming Refillable fro Epson 3800
http://www.youtube.com/watch?v=0ARPQ74_9N0
Color Management PART 01
http://www.youtube.com/watch?v=ScojQ7dWAFU
Color Management PART 02
http://www.youtube.com/watch?v=hqda4F9YlLU
Color Management PART 03
http://www.youtube.com/watch?v=IhmkI5EcPbI
Epson Stylus 2200 using refilled OEM carts and Roll attachment
http://www.youtube.com/watch?v=WEVDIPt_0tU
Sloepoke
Junior MemberPosts: 33
My last resort is always to fold a paper towel soaked with windex and park it on the capping station. Google it, there's plenty of instructions, works sometimes.
Hugowolf
Joe?
In reply to jtoolman, Dec 27, 2013
Joe, does the 3800 have an auto nozzle check like the 3880? It prints out much more from each nozzle (small blocks instead of tiny lines), the printer then scans the print (working on four colors at a time), then does what looks like a pairs cleaning on any channel with blocked nozzles, and then reprints the four colors again.
I know there is no way to manually initiate a pairs cleaning with either the 3800 or 3880, and it may be that it does all channels, but the auto print itself is probably equivalent of eight or so manual noxxle check prints. So you are getting about eight nozzle checks before a cleaning - much better than back to back cleanings.
Brian A
Howard Moftich
Veteran MemberPosts: 7,433
Re: Joe?
yes, the 3800 has auto nozzle check.  When I have let mine (3800) sit for a while, invariably, the first auto nozzle check is a disaster (and in fact throws a printer error) and a 2nd one gets everything going.
John Roy
Thanks Joe
I will search out some Windex. How wet should the paper towel be?
There is a consistent pattern in the nozzle check in LM.
I can't find anything in Printer Utility or Photoshop dialog box about printer resolution and quality numbers
jtoolman
Re: Joe?
In reply to Hugowolf, Dec 28, 2013
Yes there is and auto nozzle check.
Brian A
My videos!
jtoolman
In reply to John Roy, Dec 28, 2013
John Roy wrote:
Thanks Joe
Just make it not drippy. The idea is to have the nozzle place come into contact with the wet enough folded paper towel so the head nozzle plate is totally wet and in good contact with it.
Joe
My videos!
John Roy
In reply to jtoolman, Dec 28, 2013
Thank you. I followed advice in this thread and Googled away, finding a couple of useful sites.
So off to supermarket: no Windex. Same at auto parts. Eventually found the stuff is called Mr Muscle in New Zealand for some reason.
xrdbear
xrdbear MOD
Veteran MemberPosts: 3,879Gear list
Mr Muscle window cleaner in the UK does not contain ammonia which is important for the unblocking process. I eventually found a company in the UK that could sell me US made Windex but I had to buy 5 bottles. Whatever you do, don't use Mr Muscle kitchen or bathroom cleaners, they are far too aggressive.
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
John Roy
In reply to John Roy, Dec 30, 2013
Windex is available in New Zealand under a different brand name: Mr Muscle. There are several sorts and I got the Glass Cleaner with Ammonia-D, which I see is an ingredient in Original Windex.
Got the head soaking in it for several hours and did a clean and nozzle check, No change, blast it. So it is having a second soak now. I presume then one or two cleaning cycles?
Anybody got to this stage with no success?
John Roy
OK, two Windex soakings each several hours long, the second followed by (yet another) power clean.
Nozzle check still shows original defects.
Misery.
xrdbear
xrdbear MOD
Misery.
Frankly I think a couple of hours is not long enough. Most people go for overnight and if I was feeling as down as you are I'd go for at least 24 hours. Considering the amount of use the printer has had it may be time to consider cleaning of the capping station and particularly the wiper blade. If the wiper blade is the same as on the 4800 it is two blades next to each other and the space between can get filled with thick and drying ink which may make it stiff and ineffectual. There are instructional videos for this on youtube and probably one by jtoolman which you will find in his signature.
Brian
