Could anyone help me with the "banding" or "mouire patterns"?
Started Dec 27, 2013 | Discussions
Xiaomao
Senior MemberPosts: 1,459Gear list
Dec 27, 2013
I shot the sunset on a highland; it looks smooth and natural on the camera LCD screen and when opened in LR 3.6; it also looks good after my PP. But the "banding", "mouire patterns" or anything else appeared after the image was exported and viewed in ACDSee browser. Any comment and help would be highly appreciated!
The annoying "banding" or "mouire patterns" could be found in the darker or transitional areas.
Best regards,
Yang
 Xiaomao's gear list:Xiaomao's gear list
Leica D-LUX 4 Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 70mm F2.4 AL Limited +6 more
Mark Ransom
Veteran MemberPosts: 3,453Gear list
Re: Could anyone help me with the "banding" or "mouire patterns"?
In reply to Xiaomao, Dec 27, 2013
It's not moire.
I see the bands you speak of. I can think of two possible causes - first is that you enhanced the brightness of this image significantly during post processing, causing posterization. Second is that you used a very low quality JPEG setting causing visible artifacts.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 Tamron AF 70-300mm F/4-5.6 Di LD Macro +2 more
miles green
Veteran MemberPosts: 4,711Gear list
In reply to Mark Ransom, Dec 27, 2013
Mark Ransom wrote:
It's not moire.
Yep, I think it's No.2, the "bands" are jpg compression artifacts. In other words, the jpg doesn't have enough colors to accurately display the gradients.
Images with such smooth tones need top quality jpgs. I would use a 16-bit tiff to print.
Lovely image btw!
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
Xiaomao
Xiaomao OP
It's not moire.
Thank you very much, Mark! You comment is very helpful, I'll try to lower the brightness andcontrast and see what will happen. But I shot in DNG and exported in JPEG. Did you mean that I should set to export high quality JPEG files in LR? If so, I will try to find the place to change the setting in it.
Best regards,
Yang
Xiaomao
Xiaomao OP
In reply to miles green, Dec 27, 2013
miles green wrote:
Mark Ransom wrote:
It's not moire.
Lovely image btw!
Miles Green
Corfu, Greece
Hi, Miles! Thanks for taking your time to make it clear to me why there were such bands. I'll try to export the DNG files to TIFF files and hope the bands would be smoothed out.
Best regards,
Yang
afterswish1
Contributing MemberPosts: 737
Definitely looks like posterization as mentioned. If the original looks okay in Lightroom then you know it isn't banding or moire, the problem is introduced in the processing stage. I'd be interested in seeing the fixed version because I'm sure it really will be stunning.
Gravity will make you crazy until you get the hang of it.
Cideway
Veteran MemberPosts: 5,700Gear list
In reply to Xiaomao, Dec 28, 2013
If light room allows it, try adding some noise to the image, it will break up the posterisation, and smooth out the tones.
Chris.
A weather sealed ultra wide, is that too much to ask?
http://www.pentaxphotogallery.com/chriside
GMT +9.5
Pentax SLR talk FAQ
http://forums.dpreview.com/forums/read.asp?forum=1036&message=23161072
 Cideway's gear list:Cideway's gear list
Pentax K-5 II Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +2 more
Xiaomao
Xiaomao OP
In reply to afterswish1, Dec 28, 2013
Thanks, Afterwish1! I'm sorry I have to say that I give up. No matter what I tried, Lightroom, Photoshop, ACDSee Pro, image processed, image unprocessed, the horrible bands are still there after the DNG file is exported as JPEG. Sorry that I cannot bring up the satisfactory fixed version due to my poor PP skills.
Best regards,
Yang
Xiaomao
Xiaomao OP
In reply to Cideway, Dec 28, 2013
Chris.
GMT +9.5
Pentax SLR talk FAQ
Thank you so much, Chris! I've followed you advise to add some noise, or not to do any PP at all, and exported in JPEG format. I'm terribly sorry to tell you that the bands stayed on the image(s). I'll have to say that I have to surrender now.
It was a misty afternoon, I guess it might have something to do with the sunlight in the late afternoon and the rather dense mist in the mountains. I've never met this case before with my K-5 and Kx. Maybe I wasn't in such similar condition either. I was using DA L 55-300 (this came with Kx) for these shots.
Best regards,
Yang
JNR
JNR
Senior MemberPosts: 2,402Gear list
Xiaomao wrote:
Chris.
GMT +9.5
Pentax SLR talk FAQ
Best regards,
Yang
Don't give up! It is a nice shot, and if you work from a 16-bit TIF you can probably find a good work around. My solution when all else fails in this kind of situation is to use brush - set at large radius, at a "soft" setting and very high transparency spread along the banding area; it might take more than a single stroke. This will tend to soften or eliminate the pixelization without further damage. Not sure the name of the brush for your particular software, but in Picture Window Pro "smudge" is most effective.
JNR
www.jamesrobins.com
 JNR's gear list:JNR's gear list
Pentax K-3 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 XS Lens Pentax smc DA 50mm F1.8 +7 more
