EVF - XE1 vs. XE2?
Started Dec 26, 2013 | Discussions
GringoMike
New MemberPosts: 16Gear list
EVF - XE1 vs. XE2?
Dec 26, 2013
I am about to buy an X-E1 or X-E2. Unfortunately, it's impossible for me to get my hands on either camera in the country in which I am based, so I'll have to order (sight unseen) from the US. I have done extensive research online, which has given me answers to most of my questions--with the exception of one. Hopefully, one of you will be kind enough to give me a bit of information.
Here goes: When using manual focus, will the EVF keep up, or will there be a significant lag time? And, when using manual focus, is there a significant difference in EVF lag time between the X-E1 and X-E2?
I don't shoot sports, but do a good bit of documentary work, so I need something that will keep up when shooting on the fly. I will use AF when necessary, but prefer to focus manually.
At this point, I am leaning toward the X-E1 because I have read about an embedded sensor dust problem with some X-E2s (particularly those sold by Amazon).
Thanks in advance.
Mike
http://www.flickr.com/photos/michaelevans/
 GringoMike's gear list:GringoMike's gear list
Nikon D70 Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS
Fujifilm X-E1 Fujifilm X-E2
Sal Baker
Veteran MemberPosts: 8,067Gear list
Re: EVF - XE1 vs. XE2?
In reply to GringoMike, Dec 26, 2013
Thanks in advance.
Mike
The sensor on my X-E2 is pristene.  I bought it at B&H.  Be sure to buy digital cameras from retailers that have a good return/exchange policy.
I found the EVF in the X-E–1 to be jerky in low light, but usable.  Try both cameras to decide.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Canon EOS 350D Fujifilm X-E2 Canon EF 50mm f/1.4 USM +8 more
Group4
Regular MemberPosts: 203
In reply to Sal Baker, Dec 26, 2013
I just picked up the X E2 and did try both cameras as well as an X Pro1. I am only using manual lenses and chose the X E2 because I found it is quick and responsive. I am used to Leica M cameras and it isn't the same but it is the next best thing. If on the ball, I can focus my X E2 manually quicker in low light than my X100S.
And apparently the improved refresh rate on the X E2 makes the EVF much more stable for viewing. Also, there is split image focus on the newer model.  It is a nice camera and worth a try.
ScottD1964
Contributing MemberPosts: 949Gear list
I have both an x100s and X-E2. The x100s has a faster refreshing EVF than the X-E1 and I was completely fine with it till I just got my X-E2. The refresh rate of the X-E2 blows the X100s out of the water in low light. It's so much better than the 100s it's not even funny.
i love the digital split image for MF on both.  With the focus check feature on it zooms the split image to fill the frame as soon as you move the focus ring on the lens. Once you half press the shutter it goes back to full live view. If you have used a film SLR with the split image in the center of a micro prism ring this will feel much the same just with much greater coverage area of the image you are focusing on.
Scott
 ScottD1964's gear list:ScottD1964's gear list
Fujifilm X100S Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
AlbertInFrance
Senior MemberPosts: 2,842Gear list
In reply to ScottD1964, Dec 26, 2013
I haven't had a chance to try out an X-E2 yet, but with my X-E1 I do find that it can make manual focusing difficult at times. Generally it's fine, but in really low light or with a long (~300mm) lens it starts getting hairy.
I plan to get the X-E2 when finances permit mainly for the EVF and focusing aid improvements.
Albert
Every photograph is an abstraction from reality.
Most people are more interested in the picture than the image.
 AlbertInFrance's gear list:AlbertInFrance's gear list
Canon PowerShot G15 Fujifilm X-E1 Fujifilm X-T1 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R +4 more
57LowRider
Senior MemberPosts: 2,873Gear list
It was suggested recently that the latest firmware update had improved the EVF refresh rate with the X-E1. I don't know if it was that update or a previous one but I think it is true to say that it has improved. I did some tests with my Hektor 135 f4.5 in low light (about as challenging a setup as I could test) and at no time did I get the old stop-motion effect that was there at the X-E1's release in Nov 2012.
I shouldn't think the refresh rate is anywhere close to the Mk II processors of the X100S or X-E2, the hardware grunt isn't there, but I think Fuji have done what they can within the constraints.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +8 more
Patrick T. Kelly
Veteran MemberPosts: 4,061Gear list
In reply to 57LowRider, Dec 26, 2013
I recently bought an X-E1 from Fujifilm/Mexico. They matched the B&H price plus I.V.A. I am enjoying my X-E1 immensely and find it quite workable.
I don't know where you are but if you visit Oaxaca you're welcome to take photos with my X-E1 or if you visit Mexico City, Eduardo Izquierdo at Fujifilm/Mexico might be able to help you.
Patrick T. Kelly
Oaxaca, Mexico
Brad Morris
Veteran MemberPosts: 4,482
EVF on the X-E1 does have a slower refresh rate than the X-E2 but that only becomes an issue if you are whipping the camera around from subject to subject shooting quickly with the EVF to your eye. It is more noticeable in lower light. In use I have only really noticed it when I have been switching back and forward between the X-E1 and a DSLR during some event photography I have shot. While it is there and there was room for improvement, I think that it is an issue that has been a bit overblown in the forums.  I don't normally notice anything when just shooting the fuji on its own.
If you takle a more studied approach to photography, line up the camera on subject, focus and then shoot, the lag is not an issue wither in AF or MF modes.
Thanks in advance.
Mike
racecar5150
New MemberPosts: 23
In reply to Brad Morris, Dec 27, 2013
apart from the refresh rate, the x-e1's focus peaking in the EVF doesn't seem to be very pronounced, making it difficult to use it sometimes. Is the x-e2 more noticable?
GringoMike
In reply to Sal Baker, Dec 27, 2013
Thanks for the information, Sal. I live in Colombia and, unfortunately, I cannot find either camera in a shop here. I plan to buy from B&H as soon as I make a decision.
Thanks again,
Mike
GringoMike
In reply to ScottD1964, Dec 27, 2013
Thanks for the information, Scott. I shot with film cameras for over 25 years, so the split image focus screen is a plus.
GringoMike
In reply to 57LowRider, Dec 27, 2013
Thanks for the information, LowRider.
GringoMike
Thanks for the info, Brad. I tend to focus and then shoot, so it sounds like either camera will work for me.
Brad Morris
In reply to racecar5150, Dec 28, 2013
The peaking does not put coloured splotches all over the screen in the same way that Sony does with their peaking implementation. I think a lot of the complaints stem from some users expecting the fuji to look like what they think the Sony looks like with funky colours everywhere and that is just not the case.
The Fuji peaking slightly enhances the edges of the in focus areas only enough to make the in focus areas look more obviously focused on screen. The effectiveness will depend on EVF diopter adjustment and the quality of your eyesight.  Key is that you do need some high contrast edges for it to be really effective without the zoom in. The Zoom in is only a single click away for fine tuning or in situations where the contrast is not that high
I wear glasses for myopia -1.5/-2 and have astigmatism so my eyes are certainly not 20/20. I find that the peaking is usable on the X-E1 most of the time. without an additional accessory diopter, I would not be able to use the X-pro1 at all for manual focusing.
I believe that the X-E2 is pretty much the same as the X-e1 with regards the peaking feature
GringoMike
In reply to Brad Morris, Dec 29, 2013
Thanks, Brad, this is most helpful. I have been shooting with a Nikon D70 for nearly 10 years, so I think either Fuji camera will be a big improvement.
Sal Baker
In reply to GringoMike, Dec 29, 2013
I recently discovered the focus check feature for manual focus (off by default).  I use focus peaking, when I start to turn the focus ring the image automatically (and instantly) magnifies the image.  Touch the shutter button and the view returns to full view.  Very nice!
Sal
Brad Morris
In reply to GringoMike, Jan 7, 2014
One other thing that I have noticed is that there have beem complaints about the tone curve on the X-E2 as the colours look different to the X-E1.
I personally don't have an opinion one way or the other as I am only shooting RAW on X-E1 but it may be worth your while looking at jpeg samples of both cameras if Jpg is applicable to you.
GringoMike
In reply to Brad Morris, Jan 9, 2014
Thanks, Brad. I am aware of the tonal curve reports about the XE-2. I only shoot RAW, so it shouldn't be an issue for me.
Mike
historianx
Senior MemberPosts: 1,390Gear list
In reply to GringoMike, Jan 10, 2014
Thanks again,
Mike
good move. avoid Amazon at all costs, they have a habit of re-selling defective customer returns as new in box, hoping the consumer won't notice. That being said, when I returned the items, the replacements were DEF new in box.
Funny thing: this never happened until I got Prime membership.
 historianx's gear list:historianx's gear list
Fujifilm X100S Fujifilm X-Pro1 Fujifilm X-E1 Nikon D7100 Nikon D750 +2 more
Macintosh Sauce
Contributing MemberPosts: 565Gear list
In reply to historianx, Jan 10, 2014
Then Amazon threatens you with closing your account, because you've made "too many returns." All because they send you defective crap. :-/
I had ordered the Hogan's Heroes: The Komplete Series, Kommandant's Kollection DVD box set, and I can tell when something has been re-shrinkwrapped. The box looks worn and the shrinkwrap is broken and somewhat loose. Returning for replacement. Stuff like this really makes me angry, because it wastes my precious time.
Personally, I would be very wary of buying any digital camera and/or lens from Amazon.
 Macintosh Sauce's gear list:Macintosh Sauce's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8
