50 and 24-70 zeiss, does it make sense to own both ?
Started Dec 25, 2013 | Discussions
Jb502 Regular Member • Posts: 441
Just like it says. I have both. Just wondering if I should sell the 50 and get some other lenses. Or continue on until I have all zeiss lenses.
Only reason I see to keep the 50 is for the 1.4 when I need it. Problem is at 1.4 dof is so shallow, I almost have to go to 2.8 anyways.
I guess it's also smaller too. So that's another reason.
 Jb502's gear list:Jb502's gear list
Sony SLT-A99 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony DT 55-200mm F4-5.6 SAM Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM +1 more
havoc315 Senior Member • Posts: 2,709
Re: 50 and 24-70 zeiss, does it make sense to own both ?
You answered your own question. If you sometimes want something lighter, or if you sometimes need extreme low light, it's worth keeping the 50.
 havoc315's gear list:havoc315's gear list
Sony RX100 Nikon D750 Sony Alpha a6300 Nikon AF-S Teleconverter TC-20E III Nikon AF-S Nikkor 50mm f/1.8G +12 more
Alpha Tech Regular Member • Posts: 406
The 50 is also a good base lens for testing camera malfunctions and comparisons with other lenses you acquire over the years.
 Alpha Tech's gear list:Alpha Tech's gear list
Nikon Df Nikon AF-S Nikkor 50mm f/1.8G Special Edition
Evildogofdoom
Evildogofdoom Senior Member • Posts: 1,333
I have both and use both regularly on an A99.  Size is definitely a factor, but the quality of the 50mm even at 1.4 is better than the 24-70 ( if you pixel peep!). I also love shooting with primes!
 Evildogofdoom's gear list:Evildogofdoom's gear list
Sony RX100 II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sigma 150mm F2.8 EX DG OS Macro HSM Sony SLT-A99 Sony a77 II +13 more
MediaArchivist
MediaArchivist Senior Member • Posts: 2,651
Embrace the shallow...
Learn to use a shallow DoF. You have one of the best lenses in the world to work with, embrace it! Try to visualize the focal plane, in particular how the angle changes as the camera moves. You may find you get better results with your subject off center, where the angle of the focal plane cuts across the subject in a way where more is in focus.
It is not easy, and you have to do it a lotto get the hang of it— but you be rewarded with shots that otherwise would not exist. Hopefully, they will include many keepers
Want a roXplosion!?
 MediaArchivist's gear list:MediaArchivist's gear list
Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +16 more
911Tyson1 Regular Member • Posts: 273
If you do low light photography then yes. I own both and there is no substitute. Each serves it's own purpose. Image quality of a prime is still hard to beat.
Bucky1971 Junior Member • Posts: 35
I own both and truthfully, I'm sorry I bought the 50 prime.  In my Nikon days I shot almost exclusively with the 50, and I love the standard lens.  There is no question the IQ on the CZ 50 is incredible.  However, I find that for $1500 it is not worth it, if you have the CZ 24-70.
The CZ 24-70 is just and sharp and I use a flash or bump the ISO if the light is too dark for 2.8. On my A99 the 24-70 is by far my most used lens.
For my type shooting (portraits and landscape) I prefer the 24-70. If I had to do it again I would go with CZ 85 or 135.
Good luck
EinsteinsGhost
IMO, a normal lens compliments a zoom better than be a substitute for it unless you also get additional primes to cover wider angles. With 24-70, the significance lies in 24-50mm FL which can be crucial.
The 50/1.4 may have very shallow DOF but can be quite useful when light gets really low or the subject farther (when DOF increases).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
nyoneway Junior Member • Posts: 38
I have both. Picked up the 50mm recently. IMO the 50mm gives you a slightly better IQ and about 2 stops of light for those indoor shots. I wanted to shoot my moving baby, indoor, at <3200 iso without flash and that extra stop or two of light let me shoot at a faster shutter speed which increase my keeper rate.
In hindsight, I feel the upgrade wasn't worth the $1500 as an addition to the 24-70z.
 nyoneway's gear list:nyoneway's gear list
Sony RX100 Sony SLT-A99 Sony Alpha 7 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +3 more
