D800 firmware bug?
Started Dec 24, 2013 | Discussions
ah001 Junior Member • Posts: 47
D800 firmware bug?
Hello, I am having the following problem with D800...I set my D800 to take raw photo only using "qual" button on top, and, in the shooting menu, I have option to record nef on cf card, and jpg on sd card selected.  When I take a photo, my camera records nef files on both cards. The only way I can avoid this behavior is if I set option that sd card is used for overflow and jpg.
Also, if I set it to overflow, and top lcd can read, for example, "raw + basic" but I don't get jpg written to sd card...nothing is written.  The only way I can get jpg is if I make sure that top lcd and shooting menu are synched.
Is this normal behavior or am I doing something wrong?
 ah001's gear list:ah001's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 20mm f/2.8D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
Nikon D800
AustinTed Contributing Member • Posts: 563
Re: D800 firmware bug?
I have mine set to record raw + basic.  Primary slot selection is CF.  Secondary slot function is RAW primary and JPEG secondary.  I get RAW on the CF and JPEG on the SD.  Perhaps give a different CF card a try?
ah001 OP Junior Member • Posts: 47
Mine works the same. But can you try setting only raw on top lcd, and leave the rest?
I get 2 nefs!
I get 2 nefs!
When I do that I get a raw on both the CF and SD....
Arnold Cruz Regular Member • Posts: 230
For a certain scene, I shoot with NEF on SD (16GB) and JPEG (Fine) on CF (8GB), and always works. But I have to check the setting of my QUAL button.
 Arnold Cruz's gear list:Arnold Cruz's gear list
Nikon 1 J1 Nikon D800 Fujifilm X-E1 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +11 more
I get 2 nefs!
Exactly! It sucks if you don't know it is happening and suddenly, card is full for no reason!
I get 2 nefs!
Thanks for the heads up. I haven't been burned by this yet, but it is good to we aware.
I tested this with settings mention above (i.e. just switched primary to sd card), and it works the same - 2 identical nefs are written on both cards if top lcd is raw only.
AustinTed wrote:
I get 2 nefs!
The D4 does the same thing.  However, the big difference is that the D4 clearly indicates on the rear LCD that it intends to write raw files to both cards.
The rules seem to be the following:
1) The secondary card will always be used.
2) If you turn off JPEGs then the secondary cad will be used for raw files.
3) If you don't want the secondary card to be used, then remove it.
Robin Casady Forum Pro • Posts: 12,898
Logic, not a bug
You have conflicting settings, so the camera has to pick which option to choose. You are telling it to put a JPEG on the SD card, and at the same time telling it not to take a JPEG.
That leaves the camera to decide which of the two remaining options to use—SD card as backup or overflow. It decided to use it as backup. If you don't want a backup copy on the SD card, set it for overflow.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
romfordbluenose Senior Member • Posts: 2,009
AustinTed wrote:
AustinTed wrote:
I get 2 nefs!
If I use SD card for overflow it is not used until the CF is full and vice-versa. I use the SD card for overflow and video, and I get my videos only on the SD card and nothing else until the CF card is full.
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
