Df Battery Charging Screeching Noise
Started Dec 24, 2013 | Discussions
dL302 Junior Member • Posts: 29
Hello guys,
For those who have a Df camera, do you notice the battery charger making an audible screeching noise when charging the battery? I have never encountered that on any battery charger from Nikon before.
Please let me know. If this is not normal, I will go exchange it.
dL
Nikon Df
user_name Veteran Member • Posts: 3,134
Re: Df Battery Charging Screeching Noise
Never had one do that.
They probably use a switch mode power supply and what you are hearing is the switching frequency of the circuit.
Sometimes a loose winding in a transformer will buzz or sing with the frequency it is operating at.
Probably not a problem, but if you feel better, return it.
 user_name's gear list:user_name's gear list
Leica M8 Nikon D700 Nikon D800 Leica M Typ 240 +1 more
Alpha Tech Regular Member • Posts: 406
I have not heard any noise from the battery or charger. The battery which came with my Df has been charged twice. Yesterday I received a spare battery that I had ordered. It was charged yesterday evening.
Is this noise you are hearing very audible? I charged the Df batteries using a kitchen outlet. It is possible that the nearby noise from the refrigerator overrode any sound from the battery chargef, though I doubt it. The next time I charge a battery I will move the charger to a different room.
 Alpha Tech's gear list:Alpha Tech's gear list
Nikon Df Nikon AF-S Nikkor 50mm f/1.8G Special Edition
dL302 OP Junior Member • Posts: 29
It is very audible. I just swapped the charger with another new box and I will report my finding.
Also had to swap my strap because the thread came loose like clothes, and eventually it will wear out.
Quality control these days.
dL
Arnold Cruz Regular Member • Posts: 230
I don't hear anything on mine. I charged twice already.
 Arnold Cruz's gear list:Arnold Cruz's gear list
Nikon 1 J1 Nikon D800 Fujifilm X-E1 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +11 more
malabito
malabito Senior Member • Posts: 1,782
dL302 wrote:
Hello guys,
dL
It does in mine as well, I have two batteries. Is no that laud but if you guys bring your ear close to the charger you will easily hear it, at least I do with both batteries.
 malabito's gear list:malabito's gear list
Leica Q Leica M Typ 240 Leica Elmarit-M 28mm f/2.8 ASPH Leica APO-Summicron-M 75mm f/2 ASPH Carl Zeiss Biogon T* 2,8/21 ZM +7 more
ravduc
ravduc Senior Member • Posts: 1,969
As long as it charges the battery, I would not worry about it.
 ravduc's gear list:ravduc's gear list
Leica Digilux 2 Fujifilm FinePix X100 Leica Digilux 3 Olympus E-1 Olympus E-3 +19 more
bikinchris
bikinchris Forum Pro • Posts: 18,778
It is common for Nikon chargers to do this. Especially when you remove the battery and leave it plugged in.
Get your facts first, then you can distort them as you please.
Mark Twain
 bikinchris's gear list:bikinchris's gear list
Nikon D3 Nikon D4S Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +1 more
Update: I am charging a battery right now. The charger is completely silent. I put my ear next to it and cannot hear anything as the amber LED is slowly flashing.
dv312
dv312 Veteran Member • Posts: 3,504
little noise
I presume you're using both Nikon OEM parts
Mine makes a low hissing noise you can only detect if you place your ears next to the charger
Certainly not a screeching sound
Without the battery the charger is silent
Cheers
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 +8 more
scorpiuspix Regular Member • Posts: 327
Re: little noise here with new spare battery
…that i just picked up at B&H (EN-EL14a).  There's a small bit of noise during charging if you put your ear close to the battery.  Upon fully charging no more noise.
pbase/scorpius
 scorpiuspix's gear list:scorpiuspix's gear list
Nikon D300 Nikon D700 Nikon D3S Nikon Df
