Nikon 85mm 1.8D - Can't get autofocus to work
Started Dec 23, 2013 | Questions
Alandb Regular Member • Posts: 336
I just bought a used Nikon 85mm 1.8D. I Have a Nikon D7000. I can't figure out how to get the autofocus to work. I'm sure it is just a setting I am not doing properly but I can't figure it out. Please advise.
 Alandb's gear list:Alandb's gear list
Canon PowerShot G1 X Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tokina AT-X 12-28mm f/4 Pro DX +1 more
Nikon D7000
starman1969
starman1969 Senior Member • Posts: 3,710
Re: Nikon 85mm 1.8D - Can't get autofocus to work
It's a non G lens so it will have an aperture ring. As far as making sure the aperture is locked to f16 on the lens, then making sure the AF switch on the body is in the on position I can't think what else it might be.
Take the lens off the camera, then put it back on again & make sure the contacts are clean.
They are watching us......
 starman1969's gear list:starman1969's gear list
Nikon D800E Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G Canon EOS 1000D Nikon D4 +5 more
Alandb OP Regular Member • Posts: 336
I believe I did all that and it still doesn't work.
PSCL1 Senior Member • Posts: 3,095
If it's bought used, return the item.  If it's bought new, return the item.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
Kvenna Contributing Member • Posts: 631
It seems rather too obvious to need pointing out, but have you set the ring on the lens to A?
Chris
(unknown member) Veteran Member • Posts: 3,441
Check if You have Programmed a Button for AF-ON.
If so, the Camera will only Focus when the corresponding Button is pushing.
Read the Nikon D7000 Manual for this...
As far as making sure the aperture is locked to f16 on the lens, then making sure the...
Aperture-Switch on the Lens is on the orange Position.
Carsten, thank you. I never would have figured that out.
Windancer
Windancer Veteran Member • Posts: 5,379
Well done Cartsten because I don't do this I personally would have never thought of this
Terry
Graham Fine Art Photography
http://www.pbase.com/windancer
Remember, it's not the CPU that's in your camera that makes great images, it's the one located about 4" behind the viewfinder that does.
Disclaimer: This e-mail is intended to impart a sense of humor. Given e-mail's inability to carry inflections, tone and facial expressions it may fail miserably in its intent. The sender acknowledges the limitations of the technology and assigns to the software in which this message was composed any ill feelings that may arise.
 Windancer's gear list:Windancer's gear list
Nikon D70 Nikon D100 Nikon D200 Nikon D300 Nikon D700 +21 more
Cool, i have save some Money for You.
Well done Cartsten because I don't do this I personally would have never thought of this.
That was only to guess right.
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 13,239
But AF-ON is global
If you have set the focus to AF-ON, then none of your lenses would autofocus with the shutter button. I was under the impression that only the 85 wasn't autofocusing.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
Re: But AF-ON is global
Leonard, that is an interesting question. I believe you are mostly correct. I forgot that I recently changed to back button focusing. I just put on my 16-85mm and it seems that it will take a shot, but not always, but it won't autofocus. I watched to see whether the lens moved without pushing the backbutton focus and it did not. It might have fired without pressing the backbutton if it was already in focus, but I am not sure. I thank everybody for helping me out with this. Everything is a learning experience.
Leonard Migliore
When I changed to back button focusing I got a whole bunch of out-of-focus pictures. Usually with back button focusing you set AF-C so the camera will fire whether it's in focus or not.
Leonard Migliore
You are correct but I have my camera set for AF-S.
Leonard Migliore
Did you change the AF-S priority selection to "release"? The default selection is "focus", meaning the camera will only take pictures when the camera is in focus. AF-C default is "release", meaning the camera will take a picture whenever the shutter is pressed.
Leonard Migliore
Old Photo Dog New Member • Posts: 1
Thanks for this post...
I managed to make all of the mistakes mentioned above, except I did have AF-ON. This saved me a lot of debugging time!
Thanks again.
