Which AF settings on D5200?
Started Dec 22, 2013 | Discussions
OceanFroggie Contributing Member • Posts: 623
On my previous film SLRs and recent compact bridges my preferred mode of shooting was to centre the camera on the main subject focus point, depress shutter release half way to establish focus and exposure, then move frame slightly left or right to recompose the frame while the focus and exposure were held/locked until I shot or released the shutter button.
How can I set the D5200 up to behave this way?
I have tried various settings including AF-S with single point AF but as soon as I move the frame slightly the focus sometimes refocuses even though I have held the shutter release halfway down.  How can I get the half depressed shutter to lock focus and exposure?  I don't want to have to press other buttons like AE/AF lock as well as the shutter release button.  I guess the settings will be similar for D3x00, D5x00 and D7x00 models.  I mostly shoot in app priority or shutter priority mode and would prefer not to have to mode the focus point manually using the cursor.  Or have I completely missed the point of newer focusing technology such as AF area?
Thanks in advance.
Nikon D3X Nikon D5200
Jeff AG Regular Member • Posts: 157
Re: Which AF settings on D5200?
AF-S, single point, focus and recompose, should work.  With the button half way down the camera should not refocus unless you are in AF-C mode.  If you are sure you are holding the shutter release half way down you might want to get your camera looked at.
 Jeff AG's gear list:Jeff AG's gear list
Fujifilm X20 Nikon D7000 Nikon D600 Nikon D7100 Nikon AF-S DX Nikkor 35mm f/1.8G +13 more
stuntmonkey
stuntmonkey Senior Member • Posts: 2,696
Thanks in advance.
From a technique standpoint, try to avoid this as much as possible. When you focus and recompose, you are essentially locking the point of focus behind your subject. (Draw a radius from you your subject when you first lock, and then swing the radius along an arc until you have recomposed, you'll see by the geometry that the point of focus is now behind the intended plane of focus that your subject is in. The degree to which this affects your focus varies with subject distance.
OceanFroggie OP Contributing Member • Posts: 623
Thanks Jeff.  I suspect I may have had the camera in AF-A mode (can switch between S and C) instead of AF-S.  That seems to have sorted it.
Thanks in advance.
Thanks, but I'm not sure I understand. Say for instance I have set AF to single point.  Compose a frame with subject in the middle of frame with focus point centered, squeeze shutter release to lock focus on centered subject, then while holding shutter still half way down to keep focus locked, move frame slightly left or right so subject is no longer center and then shoot.  Will the subject not be in correct focus?  Or by doing this will I slightly upset the focus (ie have moved the focus plane)?
stuntmonkey
OceanFroggie wrote:
Thanks in advance.
I have a feeling I might be misunderstanding you, so if I am, I apologize. Here's a MSPaint chicken-scratch of what I was trying to say. (Assuming single point and AF-S mode) Note that this would be an exaggeration of real-life shooting, but the geometry still applies:
If you start out at (1) and hold the shutter on half-press to lock the focus, and recompose to position (2), your locked point of focus has essentially moved behind the subject. Or put another way, you've moved the subject to the left side of the picture frame, but unintentionally, you've also "moved" if forward.
frenchy01 Regular Member • Posts: 284
Nice drawing to explain your point...but should the "Final Plane of focus" line not go through the white circle (focus point after rotation), which will be consistent with "your locked point of focus has moved behind the subject"? Unless you meant "Wished Final Plane of focus"...;-)
Frenchie
Nismo350Z New Member • Posts: 10
stuntmonkey wrote:
OceanFroggie wrote:
Thanks in advance.
Food for thought, I like this. OK, since the focus was locked, shouldn't the plane of focus be 'locked' as well? Even if you took a panorama shot with that locked focus, and spun around a perfect 360 degrees, when returning to the subject it will still be in focus. Therefore, the distance of the plane of focus should not have changed at all.
BirgerH
BirgerH Senior Member • Posts: 4,254
Nismo350Z wrote:
stuntmonkey wrote:
OceanFroggie wrote:
Thanks in advance.
Yes, and then it is the blue line, that is the subject-plane again.
A lense has focus in a plane, 90 degrees to the focalline, not in a circle. Your sensor is a plane too, not a bow. Thats why changing the angle to the subject in focus, changes the subject-plane.
Normally this should not be a problem, as long as you still got your subject in the frame, the dof should be good enough to keep the subject in acceptable focus. Else, increase aperturenumber.
BirgerH.
 BirgerH's gear list:BirgerH's gear list
Nikon D90 Nikon D7000 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Tamron SP AF 11-18mm F/4.5-5.6 Di II LD Aspherical (IF) +14 more
mosswings Veteran Member • Posts: 7,493
BirgerH wrote:
Nismo350Z wrote:
stuntmonkey wrote:
OceanFroggie wrote:
Thanks in advance.
BirgerH.
We also have to remember that focus and recompose messes up the exposure by varying degrees depending on subject and lighting. In Nikon cameras, the exposure meter is biased to the active focus point, and does not establish final exposure until shutter release. When you recompose, you maintain focus, but exposure shifts to match whatever is under the focus point at release.
The way that Nikon intends for you to use the camera is to compose, then move the focus point around with the joydisk to keep exposure and focus synchronized.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
BirgerH
mosswings wrote:
BirgerH wrote:
Nismo350Z wrote:
stuntmonkey wrote:
OceanFroggie wrote:
Thanks in advance.
BirgerH.
Right Mosswings, this could be a problem more than an out-of-focus issue related to the shift of angle. Lot of Things to be considered - isn't there.
BirgerH.
stuntmonkey
Frenchie
Whoops. My mistake.
stuntmonkey
Also, i didn't mention it because it would make the discussion way more complicated than it should be, but there's the aspect of lens field curvature to deal with... which may or may not mess up the focus point when the photog focus-recomposes. But used properly, the AF selector pad should be the button that gets the most use.... you only use the shutter once per shot, but you should always be moving the selector with each composition.
Frenchie
Whoops. My mistake.
Ah, I was getting very confused as I too had expected the plane of focus to intersect the white circle, after slight left/right shift in recomposition. In my case the angle is likely to be less than 5 degrees so I would not have expected a focus issue. Accept the metering make be slightly off after recomp.  More often than not I'm just moving a subject off centre. Thanks all for your replies.
