Olympus 12-40 2.8 Question
Started Dec 21, 2013 | Questions
brood shooter New Member • Posts: 4
I just purchased the Only 12-40 2.8 for my OM-D EM-1 and I have been extremely happy with it thus far.  I have a question though.
The zooming part of my lens has a bit of play to it.  is this normal?
I just want to make sure I don't have a defective unit.
Thanks in advance.
 brood shooter's gear list:brood shooter's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital 25mm F1.8 Olympus 40-150mm F2.8 Pro
lambert4
lambert4 Senior Member • Posts: 1,913
Describe the play?
I also received mine only yesterday but I cannot seem to see anything on the lens with what I would describe as play, the barrel ring for zoom  is firm no movement that isn't conveyed to the mechanism, the snap focus ring is firm as well.  I also have none of the grinding or tight movement noises as described by others?
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Olympus OM-D E-M5 Olympus E-M1
brood shooter OP New Member • Posts: 4
Re: Describe the play?
The play occurs in the portion of the lens that extends during zooming. That portion of the lens has a bit of movement in directions perpendicular to the barrel. Not in and out from the camera, up, down, right and left and everything in between. It's not a lot of play, but it's there.
JeanPierre Martel Senior Member • Posts: 2,842
Very little on mine. But it does.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
Bobby J Veteran Member • Posts: 4,213
Re: Normal
BJM
lambert4
Thanks for clarifying, when the lens is extended on mine it does have movement less than a mm in all directions, when retracted it is firm.  I haven't had an external zoom lens in so long I have to say I forgot it moved as well.  Nothing but primes and the 35-100 Panasonic which is internal.
Thanks to everyone for their responses.  Peace of mind is a great thing.
Cheers.
Georg Metz New Member • Posts: 5
Re: Olympus 12-40 2.8 Question
The zooming tube of my 12-40 has a very, very slight play, too. It's so slight, that it's more a little "klick" that i can feel when pushing or pulling the tube up and down or sideways. Imho this is in between the regular tolerances.
 Georg Metz's gear list:Georg Metz's gear list
Panasonic Lumix DMC-LX5 Olympus PEN E-P1 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
jimTN New Member • Posts: 8
Mine has play too,  and when I carry the camera, I can hear it jiggle. It would be nice to get an official answer on Olympus for this.
Advent1sam
Advent1sam Senior Member • Posts: 2,859
Get a replacement? my body and lens have absolutely no play, its of a very high precision and so it should be for £900 in the UK.
lnikj Regular Member • Posts: 190
You must be very lucky Advent1sam because no externally zooming lens I have ever owned in my life has not a modicum of play in it, including the 12-40.
 lnikj's gear list:lnikj's gear list
Olympus XZ-1 Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1
ABM Barry
ABM Barry Forum Member • Posts: 67
I purchased the 12-40mm f2.8 last week and I hadn't noticed the play until I read your post. I have a bit of play starting at about 35mm with the max movement being at 40mm which is to be expected if this tolerance is allowable.
I think I will mention it to my retailer so Olympus can give their feed back. I have personally found Olympus here in Australia to be very good with their support.
I doubt it would effect the image quality however, I wonder about the weather sealing?
Thanks for posting, ... Regards, ... Baz
 ABM Barry's gear list:ABM Barry's gear list
Panasonic Lumix DMC-TS3 Olympus Tough TG-4 Nikon D200 Panasonic Lumix DMC-GH4 Olympus E-M5 II +24 more
