Why ETTR?
Started Dec 20, 2013 | Questions
Ysbrand Galama Regular Member • Posts: 151
Why ETTR?
Can someone explain to me why I should expose to the right (ETTR) in low light conditions.
Let's take an example to explain what I do not understand. Let's say my camera measures F2.0, 1/50th and ISO 800 (no over- or under exposure). I want to ETTR so I set my camera to F2.0, 1/50th and ISO 1600.
Why would ISO 1600 give better results than ISO 800? I maybe exposing to the right, but also the sensor noise increases, negating the effect.
I must be missing something.
Y.
s_grins
s_grins Forum Pro • Posts: 10,295
Re: Why ETTR?
Y.
Why not to set camera to F 2.0  1/30  ISO 800?
BTW, I do not ETTR, or ETTL, except of just a few cases.
Looking for equilibrium...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
AndyGM Contributing Member • Posts: 698
Re: Why ETTR?
7
ETTR principles don't involve changing the ISO setting at all. They involve shooting in RAW and changing the shutter speed and/or aperture to move the maximum exposed measure to the far right of the histogram, because that increases the signal to noise ratio, even if it means the image is essentially overexposed. You then downward adjust the exposure in post processing to reveal the headroom in the RAW file.
 AndyGM's gear list:AndyGM's gear list
Olympus PEN E-PL1 Olympus PEN E-PL3 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +4 more
Ysbrand Galama OP Regular Member • Posts: 151
Re: Why ETTR?
I still don't get it. I Can ETTR by exposing longer. But why not decrease the ISO? Yes, if I decrease the ISO, the exposure curve goes to the left. But so does the sensor noise. I don't see the benefit.
smithling Regular Member • Posts: 382
Re: Why ETTR?
To ETTR properly, you need to increase the amount of light that hits the camera sensor. This means making the path to the sensor bigger (aperture), or giving the sensor more time to collect light (slower shutter speed). More light hitting the sensor means a higher signal to noise ratio. Think of ISO as the sensor's electronic gain, which introduces noise as it increases. Sometimes an increase in ISO is needed however, given the photographers choice of shutter speed and/or aperture.
If you ETTR properly, the OOC jpeg will look overexposed. Just make sure to keep the exposure as high as you can, without blowing out important elements in your scene.
Re: Why ETTR?
I am still missing something. The purpose of ETTR is to improve the signal to noise ratio, so increasing the exposure time makes sense, I understand that.
But if you want to improve the S/N-ratio, why not reduce the ISO instead of lengthening the exposure time? A lower ISO has a better S/N-ratio, so the end effect is the same.
Or, worded differently: when your lense is wide-open you have two ways to increase the S/N-ratio: increase shutter time, or reduce ISO. Why is increasing the shutter time better than reducing the ISO?
Brigcam Regular Member • Posts: 163
Re: Why ETTR?
ETTR only makes sense at base ISO. The older sensors could be pretty noisy even at base ISO. So ETTR was used to help clean up the shadows at the expense of possibly blowing out highlights.
CobaltFire Regular Member • Posts: 204
Re: Why ETTR?
ETTR is not a simple concept.
First the reason: the amount of information in each photo is tied to the brightness level. The higher the brightness, the more information (colors, detail) there is, until you exceed the DR of the sensor/camera and clip. You can test the relatively easily by manually shooting the same scene with offsets of two or three stops and looking at the file sizes (for a quick reference) and developing the photos (for a more thorough analysis). Note that the file may get SMALLER if you step up ISO, due to the loss of DR. This indicates that you've gone past the point of gaining anything.
Second is how to do it. This is not as simple as it sounds. I'm sure you are aware of the tradeoffs present in opening your lens up or slowing the shutter speed down. However, knowing if you can use ISO to slide your exposure is quite a bit more difficult. You must understand your camera and how much of an advantage you will gain by ETTR, then compare that to how much of a disadvantage stepping up the ISO will give you. As mentioned above raising ISO will cause a loss of DR. On many cameras the first stop of ISO (on my E-M5 400) is not actually that much of a loss. This is usually the "gimme" step that you know you can take. After that it's up to you to decide how much DR you can trade for more detail and color.
For example, I shoot an E-M5 and an A65. On the E-M5 I have it set to +1 Exposure Comp and stay with that down to ISO 800, with shutter speed based on subject (between 1/10 and 1/100) and f/stop based on subject. On the A65 I have the camera set to ISO 400 (no auto for P mode on that camera), f/2.8 to f/4, and let the shutter speed float. Both of these sets of numbers are from MY testing, MY expectations, and MY skillset.
Note that when I owned the GH2 I only biased 0.5 stops due to the camera offsetting RAWs more to the shadows (lots of information in the shadows, early clipping of highlights). This is another factor that must be understood and compensated for.
Once it's all said and done it's worth while for me, but it has ruined a few shots that were on the limits of my skills/equipment to capture. I don't think those pictures would have been worthwhile if they were that close, but it's possible they were.
Hope that all helps!
 CobaltFire's gear list:CobaltFire's gear list
Sony Alpha NEX-5N Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Sony E 18-55mm F3.5-5.6 OSS +7 more
GeorgianBay1939
GeorgianBay1939 Senior Member • Posts: 3,537
Re: Why ETTR?
7
Y.
It seems that you are using ISO as an EXPOSURE variable, which it isn't.   (You are not alone!)
To better understand the mechanics of ETTR read Gollywop's excellent two page article on Exposure vs Brightening.
With a mirrorless camera proper ETTR (using blinkies/live view histogram as your primary exposure aid and your meter as a secondary) helps a lot when shooting wide luminance range subjects in RAW.
ETTR is NOT meant for JPEG use.
Gollywop will help you a lot!
Tom
 GeorgianBay1939's gear list:GeorgianBay1939's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 7-14mm F4 ASPH +9 more
DonSC Senior Member • Posts: 1,032
Re: Why ETTR?
Because the higher S/N ratio more than makes up for the higher noise at the higher ISO.
Re: Why ETTR?
That is true for cameras at certain higher ISOs. For example, on my Lumix G3, if I need to conserve shutter speed, I can underexpose using ISO 1600 (keeping a faster shutter speed) and then brighten the photo later on in post, and there will be the same noise as if I matched the camera's suggestion to use ISO 3200. Anyway, the S/N remains the same in that case for that camera. The camera is "iso-less" from 1600 on.
However, if I had ETTR by slowing the shutter instead, I would have much less noise. You can reduce the ISO, but you haven't increased the signal. Your just telling the camera to underexpose.
If you decrease the ISO so much that you have underexposed, you will have to brighten the photo with your raw processor (lightroom et al.) anyway to get get the required brightness. By doing so, you are increasing the noise without increasing the signal (try it). Conversely, if you ETTR, you have to darken the photo later on, which does not introduce any noise.
GodSpeaks
GodSpeaks Forum Pro • Posts: 11,582
Read this article
From the Luminous Landscape site...  ETTR
and this...  Exposure
Hope that helps.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-FZ1000 Kodak DCS Pro SLR/n Sony Alpha DSLR-A850 Panasonic Lumix DMC-GX1 +45 more
PurpleFringe Contributing Member • Posts: 579
Re: Read this article
Hope that helps.
- Rayna Butler
And this article
 PurpleFringe's gear list:PurpleFringe's gear list
Fujifilm FinePix X100 Olympus PEN E-P1 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
Re: Why ETTR?
Y.
This is correct.
Just a reminder that those blinkies/histogram apply to the resultant JPEG only. No camera on the market AFAIK feature a raw sensor histogram or overexposure display.
Re: Why ETTR?
Well... I don't know. I read a lot of technical description, but the only answer that really makes sense to me is the shortest one, by DonSC. I have a feeling it is no more complicated than that.
rare wolf
rare wolf Contributing Member • Posts: 885
Re: Why ETTR?
Exactly ... with ETTR you get less noise in the shadows but the result is generally over-exposed, and possibly with blown highlights. Then use raw development to remedy the over exposure and highlights.
Presumably you are already working with lower ISOs for maximizing your dynamic range.
HTH
cheerios from the Avalon Peninsula, Newfoundland
Cogito ergo zZOooOMm
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,062
It's a matter of making use of ALL the signal the sensor captures.
When you lower shutter speed or open up the aperture a bit (but staying at the same ISO to not increase sensor noise!) it's important to not clip highlights but to use as much of the signal the sensor can capture. So the idea is to use all 12 bits or 4096 intensity levels the sensor can capture.
The result of ETTR is lower noise, not just because of using all the values but also because of the non-linear behavior of the sensor.
Clearly the downside of ETTR is that it is more likely that highlights will be clipped. If you take a few shots at slightly higher and lower exposure you can find the best exposed image where highlights are just not clipped. Near the top of what the sensor can capture the behavior is not linear but a good RAW converter will compensate for that.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
Ontario Gone
Ontario Gone Senior Member • Posts: 4,183
Re: Why ETTR?
Heya Ysbrand, some of what has been posted is right, most of it wrong, i will try to summarize and clarify and hopefully this will help.
First we need to clarify how we are ETTR. Technically ISO is not part of exposure, but for this conversation, we will pretend it is. One can either adjust ISO higher to result in overexposure, or adjust SS/aperture. Lets cover both scenarios.
ADJUSTING SS F2.8  SS 1/1000  ISO-800: So in this first scenario, we can change the SS to 1/500 and get a +1, perhaps clipping some highlights, then pull it back down in post. This is the idea. This doesn't help though, because i could simply shoot at 1/500 at ISO-400 and achieve the same result with no need for PP. Same noise, same SS/aperture. If the scene is capable of a 1/500 SS to begin with, it makes no sense to overexpose when you don't have to, may as well just lower ISO to begin with. In fact, some cameras that apply unwanted NR like Pentax are better off shooting at 1600 ISO or less even if it's ETTL, to avoid this NR. The camera will never do a better job than good PP software.
ADJUSTING ISO F2.8  SS 1/1000  ISO-800: This is the scenario that the idea is really based on. The reason is, some sensors have a lower read noise % the higher the ISO setting is set to. As gain increases, read noise is actually less. This thinking however is flawed because of two reasons. First, this only applies to certain sensors, mostly Canon sensors, which are the minority nowadays. Second, read noise comprises such a small % of the visible noise in a photo it is barely worth paying attention to. Low read noise is much more an issue for long exposures for star watching, which is one reason canon is so good for this kind of photography. For most photography, 1/2 sec to 1/8000 SS, it is not noticeable.
So, to explain, lets change that ISO-800 to ISO-1600 to overexpose the image +1. We then pull the shot back down to 0 in post, and supposedly have less noise. Remember though, if you were shooting a sensor like in Canon cameras, the difference would be there but would be so small you wouldn't notice. In newer non Canon sensors, such as the ones Sony makes for just about everybody else, they don't behave this way. The read noise stays almost exactly the same regardless of the ISO setting. This means your ISO setting in camera does exactly the same thing that pulling or pushing in post does: it changes the amplification of the signal. Amplifying a signal darkens or brightens both signal and noise, so there is no advantage to any ISO setting over another in terms of read noise. The noise will be determined by the amount of light hitting the sensor, which has nothing to do with ISO.
Some believe (myself included), it is actually better to ETTL to preserve highlights and pull up later. If you go too far banding can show up so you gotta be careful, but i usually keep my shots underexposed by 1/2 stop or so just in case (always shooting raw). I hope this helps, there is a legitimate theory behind ETTR but the difference is negligible and it is only for a small % of today's sensors. If anybody out there can prove me wrong i would be happy to see a comparison shot.
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G Canon EF 40mm f/2.8 STM
JeanPierre Martel Senior Member • Posts: 2,842
Re: Why ETTR?
On my e-m5, I usually set the aperture (according to the DOF that I want) and let the camera decide the rest. If I overexpose, I never know what the camera will do: boost ISO or higher exposure time (at the risk of a blurred image).
If I understand correctly, in order to ETTR, I have to set the max ISO at a lower point (from its present value, 6400, to 800 for example) and set a +1 Exposure correction. Is that right?
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
texinwien Senior Member • Posts: 3,320
You're still missing something
No, it absolutely does not. ISO is not a part of the exposure equation. Shutter speed, aperture and scene brightness are the only three variables in the exposure equation. If you hold those three variables constant and lower ISO, you will not have an improved SNR.
Wrong. The two ways to increase SNR in your scenario are to increase shutter time or increase scene brightness (e.g. with a flash). Reducing ISO won't increase SNR.
Because increasing shutter time raises the amount of exposure while reducing ISO does not.
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
