Olympus E-M1 focus peaking is extremely laggy?
Started Dec 20, 2013 | Discussions
Clyzm Forum Member • Posts: 64
So I'm in the market for an m43 camera. I'm ditching my 6D and lenses. I've realized that the E-M1 with a 17mm f/1.8 and 45mm f/1.8 are good enough for what I shoot and how I shoot.
However, one thing bothers me. On my 6D with magic lantern firmware installed, I've been using focus peaking A LOT with my Sigma 35mm f/1.4. It has been fantastic, dead on, and very responsive. I've also picked up and used the Sony A7, and the peaking has been great there as well. However, the E-M1 has been a whole other story. With peaking turned on, as soon as I touch the focus ring it feels like everything slows to a crawl. The rear LCD (or the EVF if I'm using that) feels like it slows down to a slide show. I tried two different bodies at two different camera stores, and both times the sales reps agreed with me regarding how awful peaking seems on the E-M1.
Am I missing something? Is peaking on the E-M1 really this bad? Is there something switched on in the menus that's causing this sort of lag? I would love some feedback from people who own or at least have used the camera, as this is a dealbreaker to me in a $1400 camera body. If this is really an issue and there is no word from Olympus, I feel like I'm better off grabbing a used E-M5 or a new A7.
Canon EOS 6D Olympus E-M1 Sony Alpha 7
Hagane
Hagane Regular Member • Posts: 114
Re: Olympus E-M1 focus peaking is extremely laggy?
Hi,
I'm using an E-P5 (AFAIK with the same peaking as the E-M1). Peaking on the E-P5 also slows down the frame rate, its useable, but annoying...
It seems that peaking on these cameras is enabled with an art filter which would explain the laggy display.
 Hagane's gear list:Hagane's gear list
Olympus PEN E-PM1 Olympus PEN E-P5 Panasonic Lumix G 20mm F1.7 ASPH Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus M.Zuiko Digital 45mm F1.8 +3 more
bimmerman Senior Member • Posts: 2,396
Yes it is extremely laggy. Seems to me like an afterthought and a very poor implementation compared to Sony's. I assigned focus peaking to a button and just doing that already disables the high refresh rate EVF even without actually using focus peaking. I immediately disabled focus peaking on my EM-1.
tgutgu Veteran Member • Posts: 3,627
Yes, Wehen using focus peaking, the EVF becomes a bit laggy and it looses contrast. However, that does not disturb at all, because when I set the focus, composition is usually finished, and I don't move the camera a lot afterwards. Also, focus peaking is only engaged when you turn the focus ring, as I have set up my E-M1. After pressing the shutter half, the EVF image returns to normal. The slightly lower contrast image with focus peaking active helps to recognize the contours.
On the contrary, I find the focus peaking contour display in Sony cameras too disruptive.
To me Olympus has found an excellent way to implement focus peaking. It is not meant to be always on, as the view finder is so excellent for focusing anyway so that it is needed only in special situations.
So, for me, no problem with it.
Thomas
 tgutgu's gear list:tgutgu's gear list
Olympus E-M1 Olympus E-PL7 Olympus E-M5 II Panasonic Lumix DMC-GX8 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +30 more
DoubleSwitch New Member • Posts: 6
It doesn't slow down on the Panas. You can even change the peaking color.
 DoubleSwitch's gear list:DoubleSwitch's gear list
Panasonic Lumix DMC-GX7
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Never noticed to be honest, will have to look at that next round...
Utilised FP on all of these:
http://acwilli.smugmug.com/Other/EP5-Close-Ups/31910986_gfXFt4#!i=2770775389&k=PmzQFjj
http://acwilli.smugmug.com/Other/EM1-Close-Ups/32244574_qtJnnH#!i=2804555043&k=LsBnXTQ
http://acwilli.smugmug.com/Other/EM1-100-300/32265571_p7mCGq#!i=2806840628&k=cNHfxNQ
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
JYPfoto Contributing Member • Posts: 757
It lagged on the E-P5, it lags on the E-M1.  It's not as smooth as the Sony.
 JYPfoto's gear list:JYPfoto's gear list
Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 35mm F1.8 OSS Sony FE 55mm F1.8 Sony Vario-Tessar T* E 16-70mm F4 ZA OSS
LTZ470
Problem is I haven't seen any Sony close ups that even come close to the details…even if they have a great EVF…and I own several 5n, Nex-7, A7r, RX100, RX1...
Really nice details for ISO 1600...
FlickR Photostream:
Brian Wadie
Brian Wadie Veteran Member • Posts: 6,906
the answer is
buy a Sony,
why use a camera that doesn't meet your needs, then complain about it?
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 Canon EOS 7D Mark II Olympus 12-40mm F2.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Canon EF 70-300mm f/4-5.6L IS USM +1 more
Florida Nature Photographer Senior Member • Posts: 7,805
Those are quite impressive. I especially like the first two.
 Florida Nature Photographer's gear list:Florida Nature Photographer's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 12-40mm F2.8 Panasonic Lumix G Vario 7-14mm F4 ASPH Adobe Photoshop Lightroom 5 +3 more
Clyzm OP Forum Member • Posts: 64
Re: the answer is
Brian Wadie wrote:
buy a Sony,
It does meet my needs. It meets my needs more than any other camera. It was less of a complaint and more of a question asking if I was doing something wrong and producing lag. Sadly, that seems to be the current status quo with this camera and I'll be waiting around to see if that changes.
I'm not sure why anyone is posting photos comparing sharpness between this and a Sony, but that isn't what this thread is about. Sharpness (especially in macro) is a function of the lens and the skill of the photographer, not laggy focus peaking.
jkrumm Veteran Member • Posts: 9,029
Re: the answer is
I messed with the peaking a little but always seemed to take slightly off-focus photos with it. I have more luck with the magnified view. Never got around to being bothered by the slow-down.
John Krumm
Juneau, AK
Brian Wadie
Re: the answer is
John Krumm
Juneau, AK
my experience too, I don't even use it for my manual focus lenses. Even with the EM-5 I found the magnified view did everything I needed, whether shooting bees in flight with the macro or birds in flight with the Tamron 500mm mirror lens
Simplicity in all things works for me (but we all have different needs and styles, there is no one right answer - thank goodness   )
Godfrey Forum Pro • Posts: 29,011
Focus peaking seems to be implemented by an art filter type of mechanism so it slows down the viewfinder refresh. That said, I find it more likely to accurately indicate the in-focus area than the focus peaking in my other cameras.
To get around the slow refresh, I have focus peaking assigned to the lower front function button. I enable it when I'm getting my focus point where I want it to be as a rough guide, then disable it. If I need critical focusing beyond that, I enable magnification.
Both the Sony and the Ricoh GXR focus peaking runs faster, but I find I have to enable/disable it the same way for most accurate focusing, and use magnification there for critical focus as well.
It sounds almost as if they saw the little trick people started using with the E-M5 and shoehorned it into the firmware. I think I've settled on my choice being the E-M5. If I really need peaking, I'll just map a myset to one of the function buttons, but otherwise the image quality is just too close for me to spend $600 more on the E-M1.
Thanks for everyone's feedback in this thread.
Martin.au
Martin.au Forum Pro • Posts: 10,317
Agree. This is why I use a myset for peaking, rather than have it in the default settings.
 Martin.au's gear list:Martin.au's gear list
Olympus E-M1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic Lumix G Fisheye 8mm F3.5 +6 more
You do not need to use a MySet to map any one function, such as focus peaking, to a MySet to have a function button control it. Just map that function to the function button. MySets are for use with a series of different functions that you want to change for a given purpose. I change about three different things to shoot moving subjects vs stationary one so I have a MySet to cover both of those situations so I don't have to change all three setting individually.
Further, you can set focus peaking to come on when you moving the manual focus ring so you don't need to occupy a function button with the focus peaking function.
Martin.au
You use my sets so that when you aren't using peaking you can keep the EVF on high speed refresh rate.
