"Dirty" prints from an Epson 1400
Started Dec 16, 2013 | Questions
Bunzer
New MemberPosts: 10Gear list
Dec 16, 2013
I have an Epson Stylus Photo 1400 A3+ printer. It's a few years old, but has always served me well.
Increasingly, I have noticed that the lighter colours are contaminated with dark ink at the start of a printing session, but return to normal after one or two pages. This isn't a big deal on plain paper charts, etc, but it's a waste of good quality paper and ink on high quality photo prints.
A workaround is to print a couple of sheets on plain paper before loading the nice paper. But this seems a bit of an unnecessary annoyance.
The sponge under the parking position seems to be quite wet. I don't know if this is related to the problem (I can't compare this with before the problem started). I can usually soak up quite a bit of ink using toilet tissue. There are no maintenance errors on the printer, and I've just replaced all the inks (always genuine Epson), so I don't think it's faulty cartridges.
Any suggestions, please?
 Bunzer's gear list:Bunzer's gear list
Nikon D800 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +2 more
jtoolman
Senior MemberPosts: 5,317
Re: "Dirty" prints from an Epson 1400
In reply to Bunzer, Dec 16, 2013
Are you referring to the rectangular pad that the head parks on when you power off the printer?
This is not a true sponge but a porous grid with a rubber gasket on upper edge onto which the head seals on when you park the head.
It is supposed to be normally fairly dry during printing.
When you or the printer runs a cleaning cycle or ink purge during the installing of an ink cart, the head parks on to the pad. The purge pump produces a vacuum which sucks ink out of all the color nozzles and the ink is deposited directly onto the purge pad. Then the head un-parks itself and slides to the left to clear the purge pad and the Purge pump sucks the purge pad dry! The waste ink travels via one or two tubes to the waste ink pads deep inside the base of the printer.
If you are constantly seeing wetness on the purge pad then the printer is NOT draining ink out of it.
That is why you are getting those smudges.
Without being there to see the printer, all I can suggest is that you apply some Windex solution ( Window Cleaner with ammonia ) to the pad and let it soak for a while. If there is a slight clog inside the purging system the solution may be able to clear it out.
Watch this:
http://shopping.netsuite.com/s.nl/c.362672/it.I/id.222/.f
Joe
My main printers ( there are more though )
2200/CX7400/R1900/R2000/R2400/R2880/PRO3800/R340/R380/1400/Artisan 725/Canon Pro9000MKII/Canon PRO9500 MKII / PRO-100
My videos!
PRO-100 Printing out of various sources
http://www.youtube.com/watch?v=fiYfoDpKk5Y
PRO-100 Setup and Basic Use:
http://www.youtube.com/watch?v=LlV7cqqladQ&feature=youtu.be
New way to refill EPSON OEM carts:
http://www.youtube.com/watch?v=BU6fi9VCOo0
01 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Intro
http://www.youtube.com/watch?v=gccxLvfknuE&feature=youtu.be
02 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part One
http://www.youtube.com/watch?v=9zJepnArTdo&feature=youtu.be
03 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part Two
http://www.youtube.com/watch?v=TEeDpEIUkkQ&feature=youtu.be
04 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Refilling
http://www.youtube.com/watch?v=lRr-rUu9hkU&feature=youtu.be
05 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Printing
http://www.youtube.com/watch?v=QaQju7xOKy4&feature=youtu.be
Cleaning the Purge Pad and Wiper on the Epson PRO 3800
http://www.youtube.com/watch?v=iKzxAm9QtWo
Basic Epson R2000 Maintenance
http://www.youtube.com/watch?v=wRZU1_XD7xE
Calibrating your monitor and Printing to the R2000
http://www.youtube.com/watch?v=-2X7MSd-ebE
Refillable 3800 3880 cart sticking problems
http://www.youtube.com/watch?v=rDi1lhDoWjM
Gloss Optimizing Prints
http://www.youtube.com/watch?v=9iRUoUwwSlA
Printing out of Photo Shop to Epson and Canon Printers
http://www.youtube.com/watch?v=mPV75Ak0R1g
Printing in LR-2 this time to the EPSON R2880
http://www.youtube.com/watch?v=huZ6BlXQqew
Multi Image printing in LR
http://www.youtube.com/watch?v=7xoJFJVemo8
Basic Printing in Qimage Ultimate
http://www.youtube.com/watch?v=uvrEAam6H_U
Canon PGI-9 Cart Refilling by the "Dribble" method
http://www.youtube.com/watch?v=mGBzHSQx5bU\
Refill Canon PGI 9 via Freedom Method
http://www.youtube.com/watch?v=VjgQIWLw10M
Refilling and resetting R2000 China Carts
http://www.youtube.com/watch?v=hh2wuzwezxM
Refilling Epson OEM carts - Thorough, Long Winded Version!
http://www.youtube.com/watch?v=fB8QspjBbhk
Taking out the CURL on prints done on from roll paper
http://www.youtube.com/watch?v=Q8Zj9dtzeU0
Taking out the Curl - TWO.mpeg
http://www.youtube.com/watch?v=VataFqqN-Jo
R2000 Push Buttom Reset Carts
http://www.youtube.com/watch?v=xzYreszSdAM
Creating a Color Profile & Printing on the Canon Pixma PRO 9000 MKII using Color Managent
http://www.youtube.com/watch?v=D0N-jgaJY94
Print Room Visit + Filling and Priming Refillable fro Epson 3800
http://www.youtube.com/watch?v=0ARPQ74_9N0
Color Management PART 01
http://www.youtube.com/watch?v=ScojQ7dWAFU
Color Management PART 02
http://www.youtube.com/watch?v=hqda4F9YlLU
Color Management PART 03
http://www.youtube.com/watch?v=IhmkI5EcPbI
Epson Stylus 2200 using refilled OEM carts and Roll attachment
http://www.youtube.com/watch?v=WEVDIPt_0tU
Zone8
Forum ProPosts: 16,372
In reply to jtoolman, Dec 16, 2013
jtoolman wrote: Are you referring to the rectangular pad that the head parks on when you power off the printer?
Agree with Joe (although I use a 5% Ammonia solution - Windex is not a known brand in my part of Spain and the active ingredient is Ammonia that you really need) BUT also, would query whether you have fitted a waste ink tube/bottle as if that is fitted, the ink in that pad area gets drained away, so any in that pad from a cleaning cycle will tend to stay and build up instead of being drained, which could be your real source of the problem.
I have checked my pad and found after a clean, the pad has a sort-of foamy top - which over a few minutes disappears. Using a kitchen roll paper pad can soak that away (which you seem to have tried) but as said, you need to fit a waste ink bottle - it's very easy to do. Remove right hand side as you view from front as described in video - you can then see size of tubing required - any bottle will do but preferably use a glass one for weight - plastic ones can move about and possibly spill. Location for bottle is same level as that on which printer is based. This video shows exactly what to do. Tubing and bottle are very cheep cheep - tubing will cost very little and am sure you can find a used bottle.
http://www.youtube.com/watch?v=WcIOmKBmCsQ
BTW - get printhead into Change Cartridge position then remove power supply - meaning NOT switch off or head will re-park. You can then move head freely and after checking RH parking pad mentioned - check on extreme left side too and use a paper pad to soak up any there. When finally finished, just replace power cord (or re-plug into mains socket - of course!) and printer will set up per normal.
Zone8: Although I am a handsome genius, when I stand in front of a mirror, I vaguely recognise the ugly idjit standing on the other side!
LINK: For B+W with Epson 1400 (and other models) using black ink only PLUS other useful tips:
http://www.photosnowdonia.co.uk/ZPS/epson1400-B&W.htm
Cleaning DSLR Sensors, including Kodak DSLR Factory Cleaning method:
http://www.photosnowdonia.co.uk/ZPS/KodakDCS-sensorcleaning.htm (Includes links to "bassotto's" images)
Solving back/front focus problems on Sigma and most other DSLRs
http://forums.dpreview.com/forums/read.asp?forum=1027&message=35565277
PDF format list of lenses you can print or download - covers Italian Flag YES/NO for DCS 14n but applies to others. http://www.photosnowdonia.co.uk/ZPS/ItiFlagLensList.pdf
Bunzer
Bunzer OP
Sorry for not getting back sooner. I've watched the video and decided to get my hands dirty.
The head wiper was pretty dirty. The sponge was again thick with ink. I tried soaking up the ink but became impatient and removed the whole block for external cleaning (I've done this once before). I gave it a good wash, and checked the two connecting tubes for blockages, and they seemed inky but clear. I also removed the side panel to look at the main tube, which seemed very clean.
Then it all went wrong. As I was refitting the sponge block, I lost grip on the right side tension spring and it disappeared (I know I know). I tried tipping the printer and shaking etc. But I couldn't hear the spring, so it seems to have become wedged somewhere. Oh dear.
Anyway, I rebuilt the printer and am using it now. It hasn't burst into flames yet, and the print quality seems okay for now.
I didn't clean the underside of the carriage, nor the cartridge taps. I wondered if one of the cartridges was leaking, but as they're all new in the last week I thought I'd wait and see if things improved.
Bunzer
Bunzer OP
In reply to Zone8, Dec 16, 2013
Cheers for that.
I don't have a drain bottle. The only mod I ever did was fit a continuous ink system a few years ago, which I ditched after 12-18 months due to poor colour reproduction. So it's back as it was.
What makes me slightly uneasy is that the larger tube on the right side of the unit looks very clean compared with the smaller tubes coming out of the top sponge unit. I thought maybe there was a blockage somewhere in between, but it's impossible to see without taking everything to pieces. Maybe I will, now that I've lost a spring (see other post).
The 1400 is printing okay again after a good partial clean, following a video tutorial. I'll see how it goes. If things deteriorate further I may just wait until the ink runs out, bin the lot, and treat myself to the latest model.
Gesture
Veteran MemberPosts: 3,360Gear list
Sounds like you're pretty knowledgeable of possible clog points and where ink builds up. You could download WicReset/iWicReset and see what it reports for waste ink saturation percentage.
In our next lifetimes, on all printers, Epson will have the ink drain to a user cleanable salvage tank. Then, we can find out what goes next. Amazes how long the plastic gears and carriage bands seem to last.
jtoolman
These are things that need to be performed every couple of months!
Oh Dear is right. If you are able to, you really need to find that spring.
Hope it lasts.
What are Cartridge Taps?
Joe
My videos!
Bunzer
Bunzer OP
What does that spring do? It seems pretty stable without it, but obviously I can't see what's happening when the heads come over the top.
When I say "taps", I mean the nozzles in the bottom of the cartridge unit which pierce the bottom of the cartridges. I didn't want to take out the cartridges so soon after replacing them all, in case they didn't fit tightly enough when I replaced them.
jtoolman
OK you mean the ink stems. The are tapered so you don't have to worry about them not sealing.
Joe
My videos!
