EM-1 Owners have you tried this?
Started Dec 15, 2013 | Discussions
David Gore Veteran Member • Posts: 4,512
I have owned my EM-1 for 3 weeks and was just playing around with it tonight when I discoverd the FRAMES mode on the Mode dial...Spent an hour or so playing around with all the options...I had no idea You could have so many different frame options....to my knowledge the EM-1 is the first Olympus camera to offer this unique feature but I'm not sure...At any event,if you haven't discovered it yet give it a try.This camera continues to amaze me.
DaveLemi
DaveLemi Regular Member • Posts: 327
Re: EM-1 Owners have you tried this?
I found it and immediately assigned myset 2 to it.
 DaveLemi's gear list:DaveLemi's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +6 more
fotophool Veteran Member • Posts: 4,164
OK, I'll bite.
What is the Frames option and what, exactly, does it do?
fotophool
My Flickr Pics
David Gore OP Veteran Member • Posts: 4,512
It allows you to select from a variety of multiple exposure type frames including B&W.....So many choices,I had a lot of fun playing around with them all....just have a look and enjoy if you have the EM-1
BTW...I was using the 45mm 1.8 and experimenting with TV shots .
Its ts actually called "Photo Story" on the mode dial....pretty cool
Here is some info:
Olympus say the photo story feature will bring out the user's artistic abilities and powers of expression when shooting. We look at the feature a little more closely to see how it exactly works and how a photographer could put the feature to use.
What exactly is the feature?
Well, photo story allows you to capture a scene from multiple viewpoints and combine them into a single image, a bit like a story board. It's great for events such as birthdays or gatherings of friends, where lots of things are happening at once.
Which cameras feature Photo Story mode?
Currently, the Olympus XZ-10 and PEN E-P5 are the only two cameras to feature the mode, as it is relatively new.
How do you access it?
Photo Story is one of the options on the mode dial of your camera. There are different themes to choose from, including standard, speed, zoom in/out and fun frame. As both of the cameras have a touch screen, you then simply touch inside the frame to take the shot and fill a section of the story.
What can you change?
Photo Story is a really flexible feature, that you can easily personalise by using type, effect, frame aspect ratio and number of images according to the chosen theme. The finished image can be checked in live view, and you can then continue to shoot various types of images.
Photo Story is ideal for capturing moments that you want to remember vividly, as the multiple viewpoints make it easier for you to put yourself in the captured scene. It's great for spur of the moment opportunities, for example a bottle of champagne being opened. In speed setting, simply drag your finger across the screen to capture one image after the other, capturing the bottle mid pop.
For more information on the PEN E-P5 and XZ-10, visit the Olympus website.
David Gore wrote:
Here is some info:
Maybe you could post an example?
fotophool
My Flickr Pics
twenty200
twenty200 Regular Member • Posts: 466
I did this too.  I love this camera, but I'd have been happier if the dial only had M, A, S, P, Video, and U1, U2, U3, U4 for user defined MySet setups.  I might not even need Movie, since the option to record video is available in M, A, S, & P.
I'm glad the EM1 has all of the features it has...  even the silly stuff like Art Filters (though I'll probably never even touch most of them).
This is the world, the way I see it: http://twenty200.com
 twenty200's gear list:twenty200's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 14-150 F4-5.6 II
cfh25 Senior Member • Posts: 1,070
...or as the rest of the photographic world..
...calls it - collage
http://www.panoramio.com/user/50820
tgutgu Veteran Member • Posts: 3,627
To me, it is the most superfluous feature of the E-M1. A waste of time even to try it. I have no clue, how this one could find its way into a camera of this level. I use the dial position for a Myset and would have preferred if Olympus had given dedicated dial positions (C1 ... C4) for each Myset.
Thomas
 tgutgu's gear list:tgutgu's gear list
Olympus E-M1 Olympus E-PL7 Olympus E-M5 II Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +30 more
There are many templates to choose from.This is the 2 frame one which I think is kind of neat.
http://www.pbase.com/dsg2/image/153786789/original
Phil Rose Veteran Member • Posts: 3,778
There are so many
…really basic and photographically important firmware options that this camera could benefit from, yet Oly chooses to spend resources on this kind of thing?
I know, "different strokes for different folks". To me a feature like this is "cute" but is little better than if they'd use our precious firmware space to include pacman or tetris on that "pro" camera screen...
Phil
 Phil Rose's gear list:Phil Rose's gear list
Olympus E-10 Olympus E-1 Olympus E-3 Olympus E-M1 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +6 more
Deleted010614 Regular Member • Posts: 248
Thomas
I agree but there are a lot of people buying this camera with with more money than sense who think an expensive camera will take good picture for them. Those folks will want this kind of point and shoot feature. Most people actually who know what to do with a tool like this would rather scratch the offensive logos off the dial with a knife and pait C1, C2... in their place, myself included.
GIGO
Wow, that's neato! Who needs photographic knowledge or artistic talent when you have this neat feature. Olympus should just remove PSAM and have more dial positions for junk like this.
GIGO
Lawrence Keeney
Lawrence Keeney Veteran Member • Posts: 6,642
Re: There are so many
I wish they had limited the features of this camera to those of a film camera. All I want from my camera is for it to produce images of great quality. I don't want any fluff in my cameras.
 Lawrence Keeney's gear list:Lawrence Keeney's gear list
Canon EOS 5D Mark III Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
CharlesTokyo Contributing Member • Posts: 705
It is pretty well implemented. I've played with it some and came across impressed. It was on one of the XZ series cameras first.
If you use the app on the iPhone you can add some stamps to the photos afterwards.
 CharlesTokyo's gear list:CharlesTokyo's gear list
Ricoh GR Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +22 more
mrmiguel
mrmiguel Regular Member • Posts: 187
I have reassigned all the "fun" stuff on the mode dial to the custom presets. Funny how there are four spots that are entirely superfluous that can be used for that.
It's a neat feature, but I already have a collage app I prefer on the iphone and it has a ton of options.
 mrmiguel's gear list:mrmiguel's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix DMC-GM5 Rokinon 7.5mm 1:3.5 UMC Fisheye CS +9 more
Ohhh stamps! Now I get it, we take a point n shoot picture with our "pro ;-)" camera and have fun with it on our phone stamping it up. Its like a camera for scrap bookers and 6 year olds! N i i i i i ce!
GIGO
