Fotodiox Thumb Grip for GX7 - get yours now!
Started Dec 14, 2013 | Discussions
Birk Binnard
Senior MemberPosts: 1,818
Dec 14, 2013
What an amazing addition/improvement!
Based on a posting I saw here I ordered mine from Amazon:
http://www.amazon.com/gp/product/B00D62VZBW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
The grip virtually transforms the camera (no, this is not hyperbole!) - not only does it make the camera rock-steady when held, it totally enables single-hand shooting - even with my Panasonic original/heavy 14-140 lens.  Here are some notes about the grip:
1. It replaces the black plastic hotshoe cover that ships with the GX7 and attaches with no tools or set screws.
2. The grip is black (as is my GX7) and when attached there are no nasty shiny parts showing.
3. Even with the Panasonic add-on eyecup installed (which I have and also highly recommend) the grip installs with just slightly more than moderate pressure.  Once installed it will clearly not ever fall out or off.
4. As I noted, the grip is a huge improvement in handling comfort and feel.  I was really surprised at how much nicer the camera is to hold with the grip installed.
5. The grip does NOT interfere with the popup flash or the MF/AF/AE Lock control.
6. The grip does NOT interfere with the flip-up EVF.
7. The grip appears to be made from powder-coated machined aluminum and is very light weight.  It has no effect on the camera balance.
I know there are other grips available on EBay for 1/3 to 1/2 the price of this one but I would not want to risk them.  This one is just perfect.
Birk Binnard
www.birkbinnard.com/photography;
Panasonic Lumix DMC-GX7
jeffharris
Veteran MemberPosts: 6,284Gear list
Re: Fotodiox Thumb Grip for GX7 - get yours now!
In reply to Birk Binnard, Dec 14, 2013
Yep, I got one a few months back for my now sorely neglected GX1. So when I got my GX7, it migrated and I found that it works great!
It's $15 bucks well spent! The eyecup is another fantastic $15 add-on and a WHY the F didn't Panasonic include the thing as the default?
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +26 more
gteague
Senior MemberPosts: 1,455Gear list
still able to use the fn4 button next to the evf?
and where did you guys get the eyecup? show oos at panasonic site and haven't seen it elsewhere.
/guy
"The world is going to pieces and people like Adams and Weston are photographing rocks!" ~Henri Cartier-Bresson
 gteague's gear list:gteague's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
Birk Binnard
In reply to gteague, Dec 15, 2013
Yes, this works OK although it does take a little extra pressure
I think the Panasonic store is the only place to get the eyecup.  It was on sale there for $15; hopefully they will bring it back soon.
Birk Binnard
gteague
In reply to Birk Binnard, Dec 15, 2013
tks mucho for the info. i placed my order for the thumbgrip. the existing grip is no prob with the smaller lighter lenses but the accessory should be perfect to counterbalance the 75/1.8.
and i don't intend to use the evf unless forced to it by circumstances, but i'd like to have the eyecup handy in case a situation arises so i placed a backorder order. $13.75 w/tax. i guess it ships free as no shipping costs popped up.
thanks again,
/guy
Paulmorgan
Veteran MemberPosts: 4,919
Birk Binnard
Any of the thumb grips listed on Amazon will do, some are even cheaper.
Enir4
Senior MemberPosts: 2,359Gear list
Can you tell me the part number of the eyecup? I don't find it in Panasonic Spain. In which way is it different than the standard eyecup that comes with the camera?
Enrique
Birk Binnard
 Enir4's gear list:Enir4's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Samyang 8mm F2.8 UMC Fisheye +4 more
FrankS009
Veteran MemberPosts: 3,703Gear list
Does the thumb grip protrude? Does it make it more difficult to slip the GX7 into a pocket, or a small bag or compartment?
F.
When no-one else is there, the camera becomes my means...to say to a wider audience, "Did you see that?" David duChemin
 FrankS009's gear list:FrankS009's gear list
brentbrent
Senior MemberPosts: 1,827Gear list
In reply to Enir4, Dec 15, 2013
Enrique
Here is the eyecup listing, part DMW-EC1, at B&H: http://www.bhphotovideo.com/c/product/998484-REG/panasonic_dmw_ec1_eyecup.html
Though they are now again showing it as available for pre-order, they had it in stock about a week ago. I ordered it and it was apparently delivered to my office today.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH +9 more
Enir4
In reply to brentbrent, Dec 15, 2013
brentbrent wrote:
Enrique
Thanks. Is it bigger or deeper than the eyecup that came with the GX7?
Enrique
Brent
Birk Binnard
In reply to FrankS009, Dec 15, 2013
Yes - about 3/8", which is about 1/8" less than the extended eyecup, so in my case there is no net increase in body depth.
And yes, the extended Panasonic eyecup is larger & deeper than the native camera - this is what makes it a big improvement.  The difference is not a lot, but just enough to make the extended eyecup work really well.
I don't do that (when I'm out shooting I carry the naked camera on a neck strap) but I doubt there would be any problem with putting it in or out of a case or bag.
Birk Binnard
jhinkey
Senior MemberPosts: 2,762Gear list
In reply to Paulmorgan, Dec 15, 2013
Birk Binnard
I don't know about that - these thumb grips come in all shapes and sizes and to me many of them look like they will not work well on the GX7 as they drop down too low over the back of the camera or might be too long.
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-LX7 Nikon D800 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GH3 +21 more
WushuMR2
New MemberPosts: 20Gear list
In reply to Birk Binnard, Dec 22, 2013
Hey, is there a difference between the "Type A" grip you listed
http://www.amazon.com/Fotodiox-Mirrorless-Digital-Cameras-Type-A/dp/B00D62VZBW/
and this one? http://www.amazon.com/Fotodiox-Thumb-Mirrorless-Digital-Cameras/dp/B00DZZHPHI/
The second one looks like it extends further, and might be a better fit?  I have shorter-than-average fingers for a guy.
 WushuMR2's gear list:WushuMR2's gear list
Sony RX100 Olympus PEN E-P2 Nikon D7000 Nikon 1 V1 Olympus PEN E-PM2 +3 more
gteague
In reply to WushuMR2, Dec 23, 2013
i purchased the first one and it's not quite long enough. it stretches to just inside the /MF/ label. but if it was about 3/8" longer it'd start to interfere with the operation of the /AF-AE/ button.
the best i can measure, the one i have is 1-5/8". in the comments for the 2nd item someone says it's 'just over 2-1/4" long'. if true, it would cover the /AF-AE/ button completely and perhaps interfere with the operation of the rear dial as well. according to my measurements, it needs to be about 1-7/8" long.
another note, it's an extremely tight fit into the hot shoe. the first time i tried to take it out i nearly panicked and started looking for a crowbar but some patience and a wooden popsicle stick finally persuaded it to come out. not sure if i'll try again though because when i stretch my thumb to contact the grip it stretches my hand out of proportion and i can no longer hit the shutter button.
/guy
jeffharris
In reply to Paulmorgan, Dec 23, 2013
Some of them leave too little space between the camera and thumb grip and block deployment of the pop-up flash.
There was another thread on this issue a week or so back. I immediately tried my Fotodiox thumb grip and found that there was ample clearance for the flash. So, in this case, cheaper isn't better. $15 is hardly a wallet buster.
mdmiataman
Forum MemberPosts: 55Gear list
In reply to Birk Binnard, Dec 23, 2013
Amazon carries it,..
 mdmiataman's gear list:mdmiataman's gear list
Canon PowerShot G12 Canon ELPH 310 HS Nikon D5100 Panasonic Lumix DMC-GX7 Nikon AF-S DX Nikkor 35mm f/1.8G +1 more
jhinkey
In reply to mdmiataman, Dec 24, 2013
Could someone post a few pictures of their GX7 with the Fotodiox thumb grip installed?
Thanks -
John
jhinkey
In reply to jhinkey, Dec 24, 2013
Thanks -
John
Never mind here it is:
http://www.flickr.com/photos/tysonrobichaud/10732736113/
John
