The Moon.
retyazhi
Junior MemberPosts: 32
The Moon.
4 months ago
Pentax K-3, FA100-300/4.0-5.6 @ 270mm, 1/200, f14, ISO100.
Pentax K-3
Brad99
Senior MemberPosts: 2,924
Re: The Moon.
In reply to retyazhi, 4 months ago
That's got to be the best moon shot I've seen at under 300mm.  3-D!
retyazhi
Re: The Moon.
In reply to Brad99, 4 months ago
Thank you!
dave
Junior MemberPosts: 47Gear list
Re: The Moon.
Excellent job.
Pentax K5ii Canon 5D
 dave's gear list:dave's gear list
Canon EOS 5D Pentax K-5 II Sony Alpha 7
britcam
Senior MemberPosts: 1,572Gear list
Re: The Moon.
Very clear, very sharp. Great to see such a result from the K3 ...
Kind regards
britcam - Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Ricoh GR Digital IV Pentax MX-1 Pentax K-01 Fujifilm X-E1 +13 more
hanhait
Senior MemberPosts: 1,013Gear list
Re: The Moon.
It looks like surrounded by stars, but I suppose these are sharpening artefacts (?). Can you tell what post-processing you did - if any ?
 hanhait's gear list:hanhait's gear list
Pentax K100D Pentax K-5 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Sigma 70-300mm F4-5.6 APO DG Macro +5 more
lock
Veteran MemberPosts: 5,721
Amazing, just amazing..
And you caught it with all the bright stars around it. May I thank you for sharing this with us ?
Lock
Joseph Tainter
Veteran MemberPosts: 8,124
Re: The Moon.
Well done.
Joe
retyazhi
Re: The Moon.
In reply to hanhait, 4 months ago
Thank you all for your kind comments!
Yes, I did some editing in Adobe Camera Raw and then in Photoshop. However, I suppose that the stars are real. It would be hard to draw each one of them
Here is another edit of that image. I did some WB correction and added a little of colour boost. What edit do you like more?
Bob Corson
Senior MemberPosts: 2,012Gear list
Re: The Moon.
Highly unlikely they are stars. I have taken a lot of moon shots and the moon always outshines the stars so  . . .
the first
t
Bob Corson
To truly see one must open their mind as well as their eyes
 Bob Corson's gear list:Bob Corson's gear list
Pentax K-30 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro Pentax smc DA 18-55mm F3.5-5.6 AL WR +4 more
Conjure
Regular MemberPosts: 259
Re: The Moon.
well done!
I prefer the first one.
the stars cannot be real because the dark side of the moon is not transparent.
miles green
Senior MemberPosts: 3,324Gear list
In reply to Conjure, 4 months ago
Exactly!
So delete the "stars" where the dark side of the moon should be hiding them, and you have a really cool image.  Otherwise it just looks "fake" to me.
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
noel2
Regular MemberPosts: 333Gear list
Re: The Moon.
Those are not stars ! They would have to be of first magnitude or brighter to be seen so close to an almost full moon....
What you see is "noise", as one should expect for a sensor with small photosites.
noel2
Re: The Moon.
Nice demonstration !
lock
Whether fake stars or not, I still like it.
In reply to noel2, 4 months ago
I have seen plenty of fake(d) pictures receiving lots of applause. There are complete guides on the net to help remove or add features to a scene to simply improve composition. So I do not mind him brightning up noise. It did give me the illusion of the stars around the moon......
Btw, couldn't we ' make'  it real by using two exposures: one on the moon and one longer exposure for the stars?
Lock
leopold
Forum ProPosts: 11,973Gear list
Re: The Moon.
noel2
Re: Whether fake stars or not, I still like it.
In reply to lock, 4 months ago
Lock
You certainly could, but would have to overexpose the moon and you would then get a halo of diffused light in the field.
retyazhi
Re: The Moon.
THIS IMAGE IS NOT A FAKE!
At first, one should know that the Moon is not perfectly round! http://wiki.answers.com/Q/Is_the_moon_perfectly_round#slide6
Yes, I did some corrections to the image but it was nothing close to the copy/paste.
As for the note that the stars from the image is actually a digital noise, I will say - maybe. However, I'm more inclined to the thought that the dots are the stars. If it was noise, it would be more homogeneous I think. Also, look at the surrounding of the moon. It looks like there are less stars there. I didn't do anything to that area too.
Another thought about the stars in the area where there should be the moon. Why can't it be the hills of the Moon that are not in a shadow?
Britney Elvis
Veteran MemberPosts: 4,634
Come on...
In reply to leopold, 4 months ago
Not Stars....     please, we own Pentax, but we are not completely stupid.
I do think it might be the moon though.
Fess up...
gus
"It is not necessary to understand things in order to argue about them."
~~ Pierre Beaumarchais~~
retyazhi
Re: Come on...
In reply to Britney Elvis, 4 months ago
I'm telling you once again. The image above is the original .dng file that was processed in Photoshop's Adobe Camera Raw. Then it was opened in Photoshop where I did only three things: cropping, resizing and adding some sharpness. (I didn't use any other images with the moon or the stars to make this image).
As for believing me, it's up to you.
