xpro1 stitched pano with xf 60mm
Started Dec 14, 2013 | Discussions
M Kitzman Regular Member • Posts: 142
Handheld, 9 images with fifty percent overlap stitched in Photoshop. xf60 is quite impressive! Final image is 175 mb.  Nice to be able to shoot in jpeg with great quality.  Who needs a 36 mb sensor?
Cheers. mokiphoto.com
Fujifilm X-Pro1
M Kitzman OP Regular Member • Posts: 142
Re: xpro1 stitched pano with xf 60mm
Same scene as pano, Auraria campus in Denver. Shot with 14mm.
Dennis2958 Contributing Member • Posts: 518
Nice job!  I tried several panos in camera with the xpro1 and it just didn't work.  Too many minor flaws.  The fact that your overlap is 50% and you had 9 shots impressed me.  I blew your image as much as I was able and found it flawless.
I have since stoped trying to make in camera panos.
dennis
 Dennis2958's gear list:Dennis2958's gear list
Fujifilm X-Pro1 Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
Thanks Dennis. I should mention that holding the camera in the vertical position helps immensely. The 175mb image reveals an astonishing amount of detail. Regards, Morey
cheddargav Veteran Member • Posts: 4,493
Great job with that, thanks for sharing!
www.twitter.com/gavphotography
 cheddargav's gear list:cheddargav's gear list
Canon EOS 5D Mark II Canon EOS 6D Panasonic Lumix DMC-GX7 Canon EF 35mm f/1.4L USM Canon EF 85mm f/1.8 USM +4 more
marco1974 Senior Member • Posts: 1,588
Agreed! - one of mine here
X-E1 + XF 60mm:
Marco
 marco1974's gear list:marco1974's gear list
Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R XF 90mm
Re: Agreed! - one of mine here
Equally well done!............BTW your camera time is about 1 minute faster than the clock in the tower.
Excellent capture..super sharp. Did you use a special panoramic head for your shot? Thanks
(unknown member) Regular Member • Posts: 362
He said it was handheld
I was referring to the pano of Dennis, I know mine was handheld.
No, but I did use an L-bracket so as to be able to rotate the camera around the lens axis.
Marco
Segaman
Segaman Contributing Member • Posts: 696
Can we do the same with xe2.
You talked about holding the camera vertically, tell me how you do your stuff, i am new to panoramique scenes, thx
 Segaman's gear list:Segaman's gear list
Canon EOS 6D Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4L IS USM +1 more
