Has anyone verified Qwntm's test for K-3?
Started Dec 13, 2013 | Discussions
Roland Karlsson
Forum ProPosts: 23,440Gear list
Dec 13, 2013
Hi there,
Lots of threads on the issues of K-3. I have to admit I am now lost. I cannot remember any post showing a verification of Qwantum's assertion that the problem is HIGH NR. I.e. a test where he did turn HIGH NR on and off and compared the result.
Some says they cannot repeat it - but shows no images. At least what I have seen.
But has anyone succeeded in repeating it?
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
Pentax K-3
KL Matt
Veteran MemberPosts: 5,555
Re: Has anyone verified Qwntm's test for K-3?
In reply to Roland Karlsson, Dec 13, 2013
Roland Karlsson wrote:
Hi there,
Should be easy enough... all you have to do is focus poorly, shoot, turn off the high ISO noise reduction, refocus accurately, and Bob's your uncle!
Tim A2
Senior MemberPosts: 1,099
Hi there,
If I understand correctly, Qwntm's test uses auto NR and not high NR. He says that auto turns on high NR in only a certain kind of light, so when somebody does not verify his result, he says it is because they did not have the right kind of light.
Roland Karlsson
Re: I am serious
In reply to KL Matt, Dec 13, 2013
Please, I asked this seriously. I really want to know. And I do not plan to buy any K-3 right now just to do the test myself.
Roland Karlsson
In reply to Tim A2, Dec 13, 2013
No - I do not think so. I think he used NR HIGH and NR OFF.
zakaria
Senior MemberPosts: 2,217Gear list
I am also interested in but you can find a prove that the k3 is amazing tool if you go the other forum there are many amazing photos taken with this camera.
pentaxian .
 zakaria's gear list:zakaria's gear list
Pentax K-5 IIs Pentax K-3 Pentax K-3 II Fujifilm X-E1
KL Matt
Re: I am serious
If you have a camera shop that carries Pentax near you, you could do the test yourself, shouldn't be too hard.
But may I ask why you really want to know? There is something really fishy about the vehemence with which he's pursuing this. It's like a crusade. One wonders what the point is. Perhaps there is some motive. I wouldn't ascribe any significance to it at all, personally.Maybe, just maybe, he got a bad one. But I doubt it.
We should invite some kind people from the d800 etc. forum to come over and have a look at this mess and see what they think just for kicks. Bet they'd all have flashbacks. It's a very sharp sensor, people are seeing ghosts.
Matt
Rosember
Senior MemberPosts: 1,680Gear list
I tried to but could not reproduce his findings. He changed or added new setting to the description and new theories from time to time. In the end I gave up. I cannot confirm his findings but I think he might be right that there is an issue under certain settings (which I don't use). All his findings only concern jpegs, not Raws. My K-3 seems to work flawlessly.. I am very impressed by the K-3, especially  by the low light AF, the SR, the DR and colour accuracy at high ISO, and the newly designed build-in grip which helps to stabilize the cam. A very fine upgrade from my K20D.
 Rosember's gear list:Rosember's gear list
Pentax K20D Pentax Q Pentax K-3 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 35mm F2.8 Macro Limited +4 more
Tim A2
"To reproduce what I've found, set your lens to 135mm, ISO 400-800 or higher, shoot something at 1/500th of a second with High ISO noise reduction on AUTO (default) and then with High ISO noise reduction set to off, and watch the blur magically go away at 100% peeping...." / Qwntm
"I have observed that in flat light conditions, the AUTO setting will employ VERY HIGH ISO noise reduction even at ISO's as low as 400, resulting in completely blurry images when viewed at 100%. Yet the same scene photographed in more contrasty light will receive little High ISO noise reduction applied by the AUTO setting. When High ISO Noise Reduction is set to “OFF” image detail is preserved and the camera produces results one would expect, very very sharp." / Qwntm
Your point that no one has reproduced his test is well taken.
There is a thread devoted to shots taken with NR set to high.
http://www.dpreview.com/forums/thread/3590631
Roland Karlsson
In reply to Tim A2, Dec 14, 2013
Hmmmm ... seems I have been reading his posts to fast.
It says nothing about setting the NR to HIGH. This can be interpreted in two ways - either he means that AUTO may use more NR than HIGH, or that he has not bothered to test HIGH.
Thanx - I shall read that.
Roland Karlsson
In reply to Roland Karlsson, Dec 14, 2013
Yes! That is the thread I remembered. There he sets it to HIGH and OFF and compares. So - if that is correct - then he has a point.
So - what was your point?
Roland Karlsson
Re: I am serious
In reply to KL Matt, Dec 14, 2013
KL Matt wrote: If you have a camera shop that carries Pentax near you, you could do the test yourself, shouldn't be too hard.
well ...
  1. I dont have any shop with a K-3 nearby
  2. Making tests is not all that easy
  1. I am just curious.
  2. I sometimes use JPEG. I which case I seldom change default settings.
He seems to be a person that gets deeply involved and emotional.
This is not about sharp sensors. Its about in camera software.
Now, of course, if I get that K-3 (which I may or may not this spring) I will of course shoot some tests comparing NR OFF and NR HIGH and LOW. Just to see what one suits me best.
awaldram
Forum ProPosts: 11,872Gear list
Re: I am serious
Well 4000 images in my observations
There many ways to get blurred Images the vast majority caused by lack of understanding how features work.
1 panning to un-smoothly will reset SR during shot
2 Expanding AF will fail to select AF point during snap shooting (read 1st actions)
3 Hold Af if mis-set will stop Auto focus achieving sharp images
4 High NR will soften image (well Der !! )
There are many others but all the above have caught me out and some (4 especially ) are just obvious and not worth the forums time being wasted, If you don't like Pentax's NR levels in auto then use custom and select what you consider appropriate.
There's no smoking gun just a well though out camera that is obviously to much camera for some.!
Shock horror I was able to give  my correctly configured K3 (in P) total strangers and they happily shot off sharp shot after sharp shot.
The K3 as delivered (default) will happily shoot sharp shots but seems some like to customize when they don't know what settings alter then complain, making out its  anybodies fault but their own !!
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
Bob Corson
Senior MemberPosts: 2,316Gear list
It is in that post where he talks of setting NR to High. That is part of the problem test shots were not all shot the same way.
Bob Corson
To truly see one must open their mind as well as their eyes
 Bob Corson's gear list:Bob Corson's gear list
Pentax K-30 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro +5 more
Roland Karlsson
Re: I am serious
In reply to awaldram, Dec 14, 2013
Shock horror I was able to give a correctly my configured K3 (in P) total strangers and they happily shot of sharp shot after sharp shot.
In the old days it was much easier.
There was no SR, so you HAD to hold on steady yourself.
There was no AF, so you had to see to it that you focussed yourself.
There was no software, so the film you had in the camera was the limit.
awaldram
Re: I am serious
You should see the scans from my eos100 I was shocked to find only 1-2 in 10 where critically sharp , seems our expectations are tougher as well as the ability to see error.
With the K3 I can see focus error nose to eye from 30mm F2.8 shot 10-15 ft away its insane
Tim A2
But the test (more of a demonstration) in that thread, had a different purpose. It was simply to show how destructive high NR and hence auto mode is when High NR is enabled by the auto mode. here is his conclusion.
"THUS, logically we can conclude that if HIGH is a possibility for the AUTO mode to choose, and we have our camera set to AUTO, then some of our shots could experience random obliteration of the detail." /  Qwntm
That is clear now.
Roland Karlsson
Tim A2 wrote:
That is clear now.
No - sorry - I still don't get what your point was.
In my thread I asked if anyone had verified his finding the high NR had that kind of destructive effect on details that he claimed.
Now, have you verified that or have you a test that shows him wrong?
Tim A2
Tim A2 wrote:
That is clear now.
I see the misunderstanding now. I had no idea you were talking about his demonstration of how destructive high NR is.  My impression is that no one thought it needed to be verified. High NR will certainly degrade the sharpness.  The degree of destruction would depend on the scene and lighting. To reproduce his demonstration one would first have to reproduce the scene he shot including the lighting and that  is not practical.
il_alexk
Senior MemberPosts: 2,251Gear list
Yes, the problem was confirmed in this review
Of course, see this review by Neocamera:
"The Pentax K-3 matches the K-5 IIs in terms of image-quality at low ISO which is quite impressive considering its 50% extra megapixels. At ISO 400, the K-3 begins to show noise-reduction softness but its output remains equally usable thanks to the added resolution. At ISO 800+ though, the K-3 starts falling behind, giving a full-stop lead to the K-5 IIs by ISO 6400."
http://www.neocamera.com/camera/pentax/k3/samples/indoor
 il_alexk's gear list:il_alexk's gear list
Ricoh GR Pentax K-5 IIs Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +4 more
