Edit dng
Started Dec 13, 2013 | Discussions
Dervast Senior Member • Posts: 2,400
Edit dng
Hi all,
I can capture with my small sx220hs  dng photos (I applied the chdk patch) but when I open it, it looks really noise and yucky... how I can edit it in Linux and windows?
Regards
Alex
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,269
Re: Edit dng
Dervast wrote:
Hi all,
Regards
Alex
The reason your images look noisy is that with a RAW file, and a DNG file is a RAW file, none of the normal JPG processes have been applied.  Noise reduction, exposure changes, contrast adjustment, and saturation adjustments are some of the commonly applied JPG adjustments.
You need a RAW file editor. The most common ones are Aperture for Macs and for Macs or Windows you have Adobe Lightroom, Adobe Photoshop's Adobe Camera Raw, Adobe Photoshop Element's Adobe Camera Raw, ACDSee, and Paint Shop Pro. The Adobe Camera Raw add-on for Photoshop is the same as the Develop module of Lightroom while ACR for Elements is a sub set.
With a RAW file editor you will be able to adjust the WB and exposure to suit yourself as well as reduce the noise and make other changes. Once yo learn how to edit RAW files the end result is better than a JPG take at the same time.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 16,648
A good reply, BUT. . .
You only mentioned the commercial products that have to be purchased.  I would suggest that the user also consider the Open Source products as well.  In addition to being legally free, they often have the advantage of offering versions for PCs, Macs, and Linux as well.
Two that I'm particularly impressed with are RawTherapee, and Lightzone 4.  There are other Open Source titles that also have quite a following.
I still like soup. . .
Now that you've judged the quality of my typing, take a look at my photos. . .
http://www.flickr.com/photos/7267302@N03/
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +11 more
Dervast OP Senior Member • Posts: 2,400
Re: A good reply, BUT. . .
Hi
thanks for all the ansnwer.
Perhaps I can try later upload a sample here to show you how it really looks like.
The problem is that after using a program commercial or opensource.. how should I work on it?
Any tutorials on how to apply for example noise reduction to remove these numerous of dots appearing over my screen?
Regards
Alex
PhilM oz Senior Member • Posts: 1,272
Re: Edit dng
Dervast wrote:
Hi all,
Regards
Alex
Firstly make sure you are looking at noise and not bad pixels.
CHDK changed a while ago to default to DNG version 1.3. This no longer physically fixes bad pixels in the camera; but instead writes a special opcode to the DNG to tell processing software how to fix the bad pixels. Unfortunately only Adobe software recognises this opcode and does the bad pixel fixing - and not all Adobe software does it. If you have a recent version of Lightroom, Elements or Photoshop they should load the image and fix the bad pixels. If you use another program like RawTherapee it probably won't.
You can also try changing the DNG version to 1.1 in the CHDK settings, and then generating the bad pixel file in the camera. CHDK will then fix the bad pixels before saving the DNG file; but it takes a bit longer.
Posting a sample image or a link to a DNG file might help.
Having said that, in my opinion, unless you're willing to invest a lot of time and energy, you may find it hard to get results as good as the built in JPEG engine.
Canon have done a very good job over recent years with their in-camera processing.
In addition to the noise issue, you will also need to contend with lens correction. To cut costs recent cameras (not just Canon) have lenses with quite severe distortion especially at the wide end. The faster processors allow them to do lens correction is software on the JPEG image. Duplicating this lens correction can be quite hard.
I'm one of the CHDK developers and I've looked at a lot of RAW images from many Canon P&S cameras. While I shoot RAW exclusively on my DSLR, I rarely use it on P&S cameras unless the camera has native RAW support (G12, G1X, etc).
Phil.
Re: Edit dng
Hi
I am using latest photoshop and looks like it corrects most of the problems my shots have... I thought there were also files to load in photoshop that were dedicated to my sx220hs
Regards
Alex
