Which flash is everyone going to get or use on A7/A7R?
Started Dec 13, 2013 | Discussions
Sush15
Sush15 Regular Member • Posts: 378
Is the general consensus that HVL-F20M is good enough for everyday use or are there other brands of flash that people are using?
Thanks in advance!!
 Sush15's gear list:Sush15's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha 7R II Sony E 10-18mm F4 OSS Sony FE 35mm F2.8 Sony FE 70-200 F4 +2 more
Sony Alpha 7
secondclaw
secondclaw Regular Member • Posts: 245
Re: Which flash is everyone going to get or use on A7/A7R?
I was planning on buying HVL-F20M but I'm having second thoughts. Primarily:
1 - It has no off-switch. I'm not sure what it means in practical terms, but it still sounds silly.
2 - When folded it seems like it will stick out too much - it would be nice if it could 'hug' the camera when folded.
3 - It can't be rotated in Portrait mode without special flash brackets.
It is however cheap enough that I may get it anyway, as I can't see any other small alternatives.
 secondclaw's gear list:secondclaw's gear list
Canon EOS 5D Mark II Sony Alpha NEX-7 Sony Alpha 7R Canon EF 70-200mm f/2.8L IS USM Canon TS-E 17mm f/4L +10 more
Sush15
Sush15 OP Regular Member • Posts: 378
I was not aware of that limitation for portrait mode, so thank you!
I agree with the rest, I am also concerned as to how bulky it could be even when folded and not sure I like not having an off switch.
edwardaneal
edwardaneal Veteran Member • Posts: 9,101
actually it turns off when you fold it - that is the on off switch
I use one on my nex-7 and it lays pretty flat when folded - certainty more compact than any other flash would be
now this is a real issue, but for me the small size makes up for it
I got mine last year when sears put them on sale for $75 - - how can you go wrong ?
 edwardaneal's gear list:edwardaneal's gear list
Sony Alpha NEX-7 Sigma 60mm F2.8 DN Art Carl Zeiss Touit 1.8/32
Sush15
That's a really great price!, its pretty much $149 everywhere now
secondclaw
Hah - for 75 I'd buy it right now ...
Don't get me wrong, the flaws I listed are possibly offset by small size, but I wanted to look around for any other options before buying one. And it can be bought from Amazon warehouse deals for 136 or so .
icycool123
icycool123 Regular Member • Posts: 165
I have both the hvl-20m and hvl-60
Pat Whittingham
Pat Whittingham Regular Member • Posts: 164
The A7/A7R is deserving of better than the model 20 if your only flash. I have the HVL20AM with adaptor, HVL-F43M and HVL-60. The 20 is a good trigger however for wireless flash with an outboard 43/60
I feel the 43M is a good choice for a number of reasons including portrait orientation, LED light for video and adequate illumination for group shots. If you can find an HVL-F43AM at a bargain price, this is also excellent. The 58/60 are too large for my use on the A7/7R but I use the 60 on an A99 where it is well matched.
 Pat Whittingham's gear list:Pat Whittingham's gear list
Sony RX1R II Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Sony Alpha 7R II +14 more
KwhyChang
KwhyChang Veteran Member • Posts: 3,525
Agree with everything said plus it has a switch for bounce or forward flash. Also on the side there's a switch for whether your using a wide angle lens or a long focal length (tele)
Got mine from Amazon marketplace for $130.
Dave
 KwhyChang's gear list:KwhyChang's gear list
Sony Cyber-shot DSC-RX100 III Nikon Coolpix P900 Sony Alpha 7
MIRANDA1
MIRANDA1 Regular Member • Posts: 392
Using a HVL-F20M, just the right size for family type stuff.
PaulR
PaulR Regular Member • Posts: 481
Is the HVL-F43AM even compatible with the multi interface shoe on the A7R?  I haven't had much luck figuring out which flash goes with the new A7/A7R.
 PaulR's gear list:PaulR's gear list
Sony Alpha NEX-7 Nikon D600 Sony Alpha 7R Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN +4 more
TriniArt2
TriniArt2 Regular Member • Posts: 424
Same as I used on my nex-6.  No TTL
Metz 58-AF-1
Yongnuo YN-460
Calumet(Godox) 400
I use the Metz on camera in A mode...set the flash to desired f stop then match with camera and shoot away. The flash provides variable output to keep desired f stop at most distances. No TTL or the like. Can also switch to pure manual mode and use the Yongnuo or Calumet.
Still waiting for third parties to offer sync/high speed triggers and flashes for the new sony multi shoe.
 TriniArt2's gear list:TriniArt2's gear list
Canon EOS 550D Sony Alpha 7R Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8L Macro IS USM Rokinon 35mm f/1.4 +11 more
yangmesh
yangmesh New Member • Posts: 18
Yes, I am currently using A7+F43AM combo with Sony AD2MAA Adapter, everything works including TTL functions. A7 automatically detect flash once attached. got my F43AM for $189.
 yangmesh's gear list:yangmesh's gear list
Sony Alpha 7 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony FE 35mm F2.8
yangmesh
One thing particular need to address is A7/r doesn't fit well with heavy flash unit, the flash shake a bit no matter how hard you tighten the knot, maybe its just me.
PaulR
$189 seems like a very good price.  Where did you find that?
edwardaneal
did I mention the size?
here is the 20 next to my iPhone 4s
It has flaws, and it isn't the most powerful, but it you want a great small flash to go with  a great small camera - - - please show me something better
seriously - I am a flash nut - I almost always shoot with fill flash when shooting people  in bright sunlight and this little gem is amazing - and when you don't need it, just slip it in a pocket
JMO
Brian Caslis
Brian Caslis Senior Member • Posts: 2,926
I agree, the 20 is simply too underpowered for a main flash. I use the HVL-F43M. Enough power and not too large for the A7, Unlike the 43AM, the 43M has the right hot shoe and fits directly on the A7 without an adaptor.
 Brian Caslis's gear list:Brian Caslis's gear list
Fujifilm X-T10 Fujifilm XF 35mm F2 R WR Epson Stylus Pro 3880
edwardaneal
5
depends on your needs - I hate flash at night and as the only light source, but I love flash as an addition to natural light in the day - as such the little 20 makes a great fill flash
If I shot events where my flash were the only light source I would agree 100% the 20 is just not enough, but in reality I really don't think any on camera flash is enough in these situations and I would never use it at an event as my only option -
some people seem to think that flash is only for when it is dark - - I almost always use it when it when the sun is at its brightest
as a photographer, trying to be an artist - the light and how I use it is the most important aspect of what I do - it isn't the camera, it isn't the lens and it really isn't me - - the light and how I see it is what makes it art
here is a shot - with flash in the middle of the day - its just a snap, but without flash it would have sucked
Brian Caslis
As you will note I said the 20 was too weak for a main flash. Meaning you are depending on the flash to provide the light. If only serving as a fill, then of course most any flash can work. But indoors I'd much rather use a flash than shoot at ISO 3200.
For some great flash work, check out people like Joe McNally. Fantastic photographer who uses flash for almost everything.
yangmesh
Cowboom, the unit i received was almost brand new, comes with box and everything.
