Canon S120 vs G15
Started Dec 13, 2013 | Discussions
CMartin348 New Member • Posts: 2
Canon S120 vs G15
I currently have a Canon S100, which was great for the first few months and then dust or dirt got into the lens and I started to get a blur on all shots that were zoomed in. Night shots ended up with light spots all over the place. I've done a lot of reading on these two cameras, but I wanted to ask questions.
I'm taking a trip to Europe in two weeks and am looking to replace my S100. These are the biggest things I'm looking for:
- I want to be able to take good night shots. I'll be in Paris for New Years Eve... lots of great architecture and I'd love to be able to capture it at night.
- Low light shots... churches, etc.
- I want a camera that is durable and easily portable, hence looking at these two models.
- Under $400 new.
I don't care at all about having Wi-Fi and I tend not to take videos, so that's pretty irrelevant too. I'm focusing mainly on image quality, low light situations, and portability.
What do you guys recommend?
Thanks,
Casey
Canon PowerShot G15 Canon PowerShot S120
Dale Buhanan MOD Veteran Member • Posts: 3,996
Re: Canon S120 vs G15
Even though both cameras have the same sensor, the G15 has the faster lens at f1.8-f2.8, which gives it an advantage for low light shots.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
John McCormack Veteran Member • Posts: 5,076
The G15 (which I own) will do better in low light. If you want a wider field of view, the Panasonic LX7 will get you 24mm at f/1.4 and f/2.3 at 90mm (it's longest zoom). And the cost has dropped to about $308. at the big online retailers.
CMartin348 OP New Member • Posts: 2
Are there any major downsides to the G15 in your eyes, having owned one? I'll check out the panasonic. Thanks!
crashpc Veteran Member • Posts: 5,092
I don't like its ergonomics compared against bigger cameras, but it definitely delivers what it should... Maybe IMiss some strong and saturated handheld HDR mode.
Why does he do it?
 crashpc's gear list:crashpc's gear list
Canon EOS M Canon EF 50mm f/1.4 USM Canon EF 100mm f/2.0 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF-M 22mm f/2 STM +1 more
PaulRivers Veteran Member • Posts: 7,419
It's size is the main difference between it and the s120. The s120 is "about the largest you can comfortably carry in a jeans pocket all day". The g15 is more "can be crammed into a jeans pocket, but it's always rather awkward".
If size isn't a problem - I'm not the other poster - but the s120 doesn't have any advantages over the g15. It's main advantage is it's size.
Also, fyi, there are other cameras the same size as the g15 with better low light capabilities - Panasonic lx7 (f1.4 lens), Sony rx100 (f1.8 lens, but noteably larger sensor, best for it's size) - or more zoom while otherwise being the same (Nikon p7700).
Depends on which focal lenghts you use. Canon goes to 140mm with f/2,8. How about RX100...
Why does he do it?
Teppo Hytönen Senior Member • Posts: 1,066
For S120 and G15 it's basically size in favor of S120, and better external controls and better low-light shooting due to faster lens in favor of G15. G15 is more versatile with accessories as well, but when you want to travel light, that's of course not that much of a consideration.
The RX100 indeed has a slower lens than G15. But thanks to the extra resolution and sensor size, you can use roughly one stop higher ISO with the RX100 and keep the level of detail. That partially offsets the 1,5 stops of lens advantage the G15 has. Indeed worth noting though that RX100 ends at 100mm while G15 goes to 140mm, so to get equal field of view means you'd have to crop with the RX100, meaning if you crank up the ISO you'll lose in terms of detail. Yet of course at the wide end the RX100 wins due to the large sensor and almost equally fast lens. Also costs more, though.
For what it's worth, I went with the G15. The RX100 would probably have been nice and might've picked it, but effectively it would've been about 150 euros more expensive, which I found a bit too much at this time. I'd say that all of them are pretty good cameras, though - however personally I'd go with S110 over S120 for the same reason as one would go with G15 rather than G16... big price difference for not that much benefit.
Teppo @ Finland
 Teppo Hytönen's gear list:Teppo Hytönen's gear list
Canon PowerShot G15 Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Sigma 150mm F2.8 EX DG Macro HSM +1 more
Jennyhappy2 Senior Member • Posts: 2,362
Re: Canon S120 vs S110
One key difference in the S110 to the S120 is the S120 has DIGIC6 which has increased overall performance resulting in a faster focus.  Also the S120 starts at 24mm while the G15/G16 starts at 28mm.
Teppo @ Finland
 Jennyhappy2's gear list:Jennyhappy2's gear list
Sony Cyber-shot DSC-RX100 III
Teppo @ Finland
Heh I like how you wrote that (more expensive) RX100 somehow keeps up with G15. That´s enaugh for me, but that was not my point. My point is that it really needs to know, what one does need to do with it. One time, G15 will win, second time, it will be RX100 or even different camera. It needs thinking to choose the right one. That´s why there is no just one cam in that size or price range.
While I see that RX100 is better wide, I see that G15 still holds sufficient IQ and results when wide open (enaugh for me). But I need something more on tele. That way I need G15 more that RX100. http://www.picfront.org/d/93l2
Another person would need it opposite way, And that way of comparison, G15 will be killed easily. It all depends...
Why does he do it?
Hm, content inside that link just disappeared... http://www.picfront.org/d/93nA
Why does he do it?
ericN2
ericN2 Forum Pro • Posts: 16,509
Presumably the Canon (or equivalent) Adaptor Tube with a tele lens on it..Looks good..what make tele lens ?
/eric
Staffordshire, UK
/eric
Staffordshire, UK
Many choices. For me, I got SONY VCL-DH1758 for free
Why does he do it?
