SOLVED: Importing images from CF cards into iPad
Started Dec 13, 2013 | Discussions
Boomanbb
Boomanbb Senior Member • Posts: 1,290
Hello,
I bought an iPad Air to use as a portable image viewer and lightweight editor thinking I could use one of the rare Lightning to CF reader dongles. Turns out that the only company I trusted to buy from stopped selling the device. Turns out, it is easy to read any kind of memory card. You just need enough power to do it.
You will need a powered USB hub, the USB Camera Connection kit and of course your card reader. The picture should say it all. Here it is, the iPad reading images from one of the most power hungry CF cards made, the 1GB Microdrive!
Check back later when I finish my battery powered version of this project.
Ben
Disagree without being disagreeable
 Boomanbb's gear list:Boomanbb's gear list
Canon EOS 7D Canon EOS M Canon EOS 7D Mark II Canon EF 135mm f/2.0L USM Canon EF-S 10-22mm f/3.5-4.5 USM +16 more
John Russell NZ Regular Member • Posts: 226
Re: SOLVED: Importing images from CF cards into iPad
Hi, that looks fairly complicated!. I have just bought a apple lightening sd card camera connector for iPad 4, but it doesn't recognise my sony memory stick. Any suggestions?. Thanks, John.
 John Russell NZ's gear list:John Russell NZ's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6
seeblue Senior Member • Posts: 1,426
The Apple Lightning to USB Camera Adaptor only works with supported cameras.
The Apple Lightning to SD Card Camera Reader only works with SD cards.
Third party hardware, software hacks, etc. are unsupported. The simple answer is some of them may work some of the time, none will work all of the time. Any of them could possibly damage your device or void your warranty. If you’re a tinkerer, tinker away, but $50 to $100 later, you may have nothing that works.
For your requirements I’d look to a wireless solution like a Kingston Mobilelite wireless hub. It will accept card readers (among other inputs). OTOH, it’s also really easy to transfer files wirelessly from a PC/Mac to your tablet without spending any money at all.
Boomanbb
Boomanbb OP Senior Member • Posts: 1,290
Its actually very safe and very easy. You will do absolutely no damage to your iPad connecting a hub to it and it is the only way to connect certian midi devices for instance. Follow the information in the Apple kb for additional details. I will have a cleaned up version of the setup in a day or two for you too see.
http://support.apple.com/kb/HT4101
Ben
Boomanbb
Depending upon how much power the media draws, you may be able to read it by plugging a cheap unpowered USB hub into the Camera Connection kit and then plugging your card reader into the hub's USB port.
That worked for me with CF cards of 4GB or less. I needed a powered hub to read larger capacity cards.
Ben
Boomanbb
New pictures of final enhancements
Now using a Li-Po battery to power the hub. Found an inexpensive folio case for the Air and velcro adhesive strips to hold the hub and battery on the back. The whole thing works like a champ and really expands the types of devices I can now use with my iPad. The hub doesn't draw power until a device is plugged in.
Ben
pavi1 Veteran Member • Posts: 6,279
This works great for third gen iPad and all my CF cards. I do not have a micro drive and never will so do not know how or if it will work with a micro drive.
Everything happens for a reason. #1 reason: poor planning
WSSA #44
Menneisyys Senior Member • Posts: 1,432
pavi1 wrote: I do not have a micro drive and never will so do not know how or if it will work with a micro drive.
It won't, given that there are currents on the order of 190 mA, peak 310 mA. (See http://en.wikipedia.org/wiki/Microdrive ) and Apple have artificially made "high-current" peripherals like this useless - to avoid people connecting for example USB memory sticks to import videos from.
Very typical of Apple.
Boomanbb
Well, I can tell you that I can easily read a microdrive with this powered hub setup since the battery pack is supplying the power. Not that I would want to use that slow card, rather it was a demonstration that by using a powered hub you can access devices previously off limits to the iPad.
Ben
Ben
I've been speaking about a not externally powered solution - something that Apple have deliberately disabled after the 3.2.0 "fiasco" in iPad 1. (3.2.0 still allowed for "high" power peripherals. Then, Apple noticed they really don't want to power external peripherals, including all kinds of USB sticks, to protect their lucrative $100 / capacity doubling storage business. This is why they introduced the 100 mA restriction in 3.2.1 and all iPad firmware versions ever since.)
