Adapters Contax Lenses to Nikon Bodies
Started Dec 13, 2013 | Questions
Kevin Sullivan Forum Member • Posts: 91
Hi,
My cameras are D7000 / D5100 / D90 / D50 however I have a 35mm film system and that is Contax does anyone know if there is a manufacturer in the UK that makes an adapter to allow me to use the Contax lenses on the Nikon bodies and if so will I get full metering
Thanks in advance
Kevin
 Kevin Sullivan's gear list:Kevin Sullivan's gear list
Nikon D800E
Nikon D50 Nikon D5100 Nikon D7000 Nikon D90
Michael Benveniste
Michael Benveniste Senior Member • Posts: 2,441
Re: Adapters Contax Lenses to Nikon Bodies
If you insist on a UK manufacturer, I think you are out of luck, but there are a couple of solutions available to UK residents.
The first is to deal with Leitax in Spain for a conversion kit and/or installation. If your lens model permits, you may even be able to get full metering with all of your bodies.
http://www.leitax.com/Zeiss-Contax-lens-for-Nikon-cameras.html
The second is to use an adapter such as this one which can be ordered through Amazon UK. This sort of adapter gives you a choice. You can either use it with the built-in 1.4x teleconverter and obtain infinite focus and indifferent quality, or you can remove the teleconverter and lose the ability to focus to infinity.
http://www.amazon.co.uk/Fotodiox-Lens-Mount-Adapter-Yashica/dp/B008BBI9FS
I miss the days when I used to be nostalgic.
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D200 Nikon 1 V1 Nikon D800 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +33 more
Kevin Sullivan OP Forum Member • Posts: 91
Hello Michael,
Many thanks for your response, my apologies for my delay in answering but I am recovering from a stinking cold.
I have had a look at your solutions but they are not what I was after, I am looking for an adapter a bit like the old Tamrons, where the adapter one side was on the camera body and the lenses could be mounted and removed from the other side, so if I wish I can return to film quiet easily.
I have done a Google to n avail so any other leads will be welcomed
Kevin
Nikon D800E
henrikkhach New Member • Posts: 7
Hi everyone,
I had the one produced by Fotodiox, never buy that, it has a poor quality optic on it which causes blurry and non focused images and destroys the Contax lenses quality. I'm regretful of buying this product
