Downtown Los Angeles, Disney Concert Hall - 5D MkIII w/ Tokina 11-16
Started Dec 13, 2013 | Discussions
Greg V Regular Member • Posts: 396
Hey folks,
A few shots from last night outside the Disney Concert Hall in downtown L.A. Thankfully had a bit of moonlight working for me.
Greg V.
www.gregvmusic.com
Canon EOS 5D
aftab
aftab Veteran Member • Posts: 9,018
Re: Downtown Los Angeles, Disney Concert Hall - 5D MkIII w/ Tokina 11-16
Beautifully done. Liked all of them.
Life is short.
Travel with passion.
http://www.flickr.com/photos/catch45/
 aftab's gear list:aftab's gear list
Canon PowerShot G1 X II Panasonic Lumix DMC-FZ1000 Canon EOS 5D Mark III Nikon D600 Canon EOS 7D Mark II +6 more
SeaScout851 Veteran Member • Posts: 6,176
Wonderful shots!!!
I was not aware that the Tokina 11-16 would work on full frame.  I've had the 11-16 for a couple of years and use it on my 50d and 7d.  I've recently purchased a 5d III and was concerned it might cause problems on that body.  Any notes I should be aware of using this lens on the 5d?
Andy.
Greg V OP Regular Member • Posts: 396
Many thanks Aftab!
Greg V.
www.gregvmusic.com
SeaScout851 wrote:
Wonderful shots!!!
Andy.
Thanks very much Andy! The 11-16 basically becomes a prime on the FF 5D3. If you try and go wider than 16mm it will heavily vignette. Also, as I'm sure you know, being a WA the lens flares a lot. So be sure and use the lens hood esp when multiple light sources are nearby.
Greg V.
www.gregvmusic.com
Greg V wrote:
SeaScout851 wrote:
Wonderful shots!!!
Andy.
Greg V.
www.gregvmusic.com
Thanks Greg.  Currently the widest lens I have for the 5d is the 24-105.  But now I'm looking forward to trying the 11-16 at 16 which should result in the equivalent of 10 on an apc sensor camera.
The Davinator
The Davinator Forum Pro • Posts: 16,583
Greg V wrote:
SeaScout851 wrote:
Wonderful shots!!!
Andy.
Greg V.
www.gregvmusic.com
Great info Greg.  Never thought of trying.
 The Davinator's gear list:The Davinator's gear list
Canon PowerShot G3 Canon PowerShot SX150 IS Canon EOS D30 Canon EOS 10D Nikon D2X +18 more
