Auto ISO & minimum shutter speed
Started Dec 13, 2013 | Questions
D Mac
D Mac Forum Member • Posts: 90
Not sure if this has been asked already, but if I put the camera in auto-ISO  with a minimum shutter speed of 1/125 and then put the shutter dial to automatic, is that supposed to keep the shutter speed from dropping below 1/125?  I've  tried a couple test shots with those settings but the shutter speed drops below 1/125th.
 D Mac's gear list:D Mac's gear list
Fujifilm X100S Nik Silver Efex Pro Adobe Photoshop Lightroom 5
Limburger
Limburger Senior Member • Posts: 6,507
Re: Auto ISO & minimum shutter speed
You basicly work with aperture priority. When the light runs out for propper exposure it only then will go slower than you have set it.
You can try by choosing a wider aperture or get more scene luminance.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100
a l b e r t Senior Member • Posts: 1,435
When you hit the highest Auto ISO value and the exposure is still under, the camera will try to reduce shutter speed to keep exposure correct.
 a l b e r t's gear list:a l b e r t's gear list
Fujifilm FinePix F31fd Fujifilm FinePix X100 Fujifilm X10 Fujifilm X-E2 Fujifilm XF 35mm F1.4 R +7 more
bigpigbig Senior Member • Posts: 1,721
Let me see if I can get my head around this.
I choose and Aperture and put the SS dial to A (aperture priority mode) then Auto ISO (let's say 3200). If the minimum SS is set to 1/125 then will the camera start at ISO 100 (or 200 in RAW) and as long as the SS is faster than 1/125 it will shoot. If the SS would need to be lower than 1/125 at ISO 100 it will set the shutter speed to 1/125 and increase the ISO up to 3200 at which point:
IT WILL DECREASE SHUTTER SPEED??
this seems wrong. If I am shooting a subject that requires a 1/125 shutter speed to avoid motion blur, it seems I would rather have an underexposed photo at 1/125 and ISO 3200 than a blurry photo.
 bigpigbig's gear list:bigpigbig's gear list
Fujifilm X-E1 Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +12 more
Limburger
It makes perfect sense. The camera wasn't set to underexpose but to try keeping 1/125s as long as possible at given aperture and scene luminance. By dialing in -EC you tell the camera it's ok to underexpose (when hitting your upper iso and lower shutter limits) and it by then will do so.
Cheers Mike
dengx Senior Member • Posts: 1,020
A few days ago I've explained it here:
http://www.dpreview.com/forums/post/52610244
Regards
Cheers Mike
Thanks Mike.
But what "makes sense" is always personal (unless physics or math is involved). To me, I would only ever set a minimum shutter speed and Auto ISO in variable lighting or luminance scenarios when the shutter speed minimum is CRITICAL to getting in focus images. People walking on a sidewalk for example. Dialing in EC to raise shutter speed seems to defeat the purpose of "Auto" with MINIMUM SHUTTER SPEED.  What does the camera do if I set the shutter speed to 1/125, aperture to "A" and Auto ISO 3200 in a case of insufficient light and maximum aperture? I am guessing it underexposes. No? I would hope it doesn't go up past ISO 3200, I can do that in post.
Sorry, I am in a hospital bed at the moment and can check for myself. ACL reconstruction, good fun.  :/
But I would use minimum shutter speed, for me, in a similar way to manual mode when minimum SS is critical and variable light or luminance makes it difficult to shoot in manual Mode. I don't want to be shooting away and find that the SS has dropped below a value that assures my subjects are in focus (not blurred). If I have to keep looking at the shutter speed it defeats the purpose (for me) of going to Auto in the first place.
What am I missing? Why and how would you use it? Scenarios?
Yes, it underexposes in that case.
Hope you'll get well soon!
Regards
Limburger
Hey, first I hope you will be out of hospital soon. Hospital is no fun but ACL (had to look it up not knowing what it was) seems to be not life threatening...anyways hospital is no fun unless you work there.
As for the auto iso and such, well... why not go full manual. It's an automated mode but only works in good light.
In full auto 1/125 is 1/125 no matter the exposure.
You're missing nothing imho, it's an overestimated conveniance mode.
Cheers Mike
Regards
Thank, that's good..
Six months of rehab should give me time to sort out the best way to use Auto ISO.
Cheers Mike
most of time I shoot in manual mode. But occasionally letting the camera do the metering is helpful. for example, a city street with shady areas and sunny areas.
D Mac
D Mac OP Forum Member • Posts: 90
Thanks, makes sense to me now.
