Weathered-sealed lenses for the Nikon D7100?
Started Dec 13, 2013 | Discussions
Smiller4128
Regular MemberPosts: 435Gear list
Dec 13, 2013
Hello everyone, I'm really enjoying my D7100 that I got just a little bit ago but just had a couple of questions. With it beginning to snow near me where I am, I've been traveling up to the cold and taking pictures. But I had one curious question? It seems that the D7100 is weathered-sealed and I'm curious as to what extent that is? I've seen the Olympus E-M1 drenched underneath a kitchen sink and realize that this is probably an insane extreme, however if I'm able to go out in a decent rainstorm and still not have to worry about the camera being damaged then that's just another huge plus! Also, which lenses would be weathered-sealed along with the camera? All I have right now is the Nikon 16-85mm so I'm hoping that will have some weather-sealing but thought I'd come here and ask first?
 Smiller4128's gear list:Smiller4128's gear list
Olympus E-M5 II Fujifilm X-T10 Olympus 12-40mm F2.8 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R
Nikon D7100 Olympus E-M1
Mako2011
Mako2011 MOD
Forum ProPosts: 19,224
Lighjt mist
In reply to Smiller4128, Dec 13, 2013
Light mist and a sprinkle or two. Do not use the camera (unprotected) in a regular rain for any length of time. For the most part...All the Nikon Gold Ring lenses have extra weather sealing above and beyond the less expensive lenses.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Johnny Liu
Forum MemberPosts: 61Gear list
Re: Weathered-sealed lenses for the Nikon D7100?
Only the Nikon 14-24mm, 24-70mm, 70-200mm, and the super telephotos are properly weather sealed. I doubt the D7100 is as well sealed as the OM-D either, I wouldn't use it under heavy rain if I were you.
Johnny Liu
www.facebook.com/JOHNNYLIUPHOTOGRAPHY
 Johnny Liu's gear list:Johnny Liu's gear list
Nikon D700 Nikon D7000 Nikon AF-S Nikkor 28mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G Special Edition Nikon AF-S Nikkor 85mm f/1.8G +2 more
trac63
Contributing MemberPosts: 586
To me "weather-sealed" means nothing. It is not the same as "water-resistant".
You may be able to get your Pentax K-3 or Olympus E-M1 slightly more wet than your D7100 before incurring any water damage. Or not. As far as I know, none of these manufacturers will guarantee the water resistance of any of their cameras.
wildlifr
Senior MemberPosts: 1,153Gear list
No indication that I know of...
...that it's any less weather sealed than E-M1. I've used mine in light rain and had snow laying on it with no problems. I do try to keep the water away from the camera/lens interface if it's a lens with no gasket.
 wildlifr's gear list:wildlifr's gear list
Nikon D7100 Nikon D750 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Teleconverter TC-14E II Sigma 17-50mm F2.8 EX DC OS HSM +9 more
wildlifr
Improved weather sealing over the D7000
And there are plenty of videos on youtube showing the D7000 being tested under a shower head, so I wouldn't worry too much about the body.
geoffrb
Contributing MemberPosts: 639Gear list
Hi
I got a D90 briefly wet in a sudden Hong Kong storm last spring, despite drying it thoroughly, it died a slow death, yet the 16 - 85 lens survived.
Could be I was just unlucky with the non-weather sealed  D90 and lucky with the 16 - 85. This may give some idea about what the lens can take, or not.
I have replaced it with a D7100 body but I'll take no chances with that, weather-sealed or not.
Geoffrey
 geoffrb's gear list:geoffrb's gear list
Nikon D750
GPW
GPW
Regular MemberPosts: 292Gear list
Get yourself a Lens Coat (Rain Coat), they are excellent for shooting in rain and snow.
 GPW's gear list:GPW's gear list
Nikon D300 Nikon D7200 Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +3 more
sshoihet
Senior MemberPosts: 2,528Gear list
I don't worry too much, as long as I can keep water off the front element I'll be shooting.  My D7000 and D7100 have gotten wet many times...I just make sure to take them out and let them dry off when i get home.
My 16-85 has been rained on a lot, snowed on, had glue poured on (don't ask) and it's stood up very well in the 2.5 yrs that I've had it.
This is my D7100 and Tamron 17-50 a few weeks ago...it was dark and I didn't realize how much snow was on it
 sshoihet's gear list:sshoihet's gear list
Canon PowerShot S95 Nikon D7000 Nikon D7100 Canon EOS M Nikon D600 +14 more
geoffrb
In reply to GPW, Dec 13, 2013
Rain coats work really well, alas they're not something you always carry around. I keep a plasic bag and rubber band ( for around the lens ), this too works well and takes up next to no room.
Nikon D750
britcam
Senior MemberPosts: 2,406Gear list
In reply to trac63, Dec 14, 2013
Pentax K5 weathersealing ....
http://www.youtube.com/watch?v=Eo61t5fH6Qw
Kind regards
britcam - Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Ricoh GR Digital IV Pentax K-5 IIs Fujifilm X-A1 Fujifilm X-E1 +8 more
alasta
Contributing MemberPosts: 545
In reply to Smiller4128, Dec 14, 2013
This is a subject that has fascinated me for some time, because I personally consider it quite crippling to have to turn away photographic opportunities due to weather. I'm really not a fan of rain covers because I find that even the better designed ones make it awkward to access controls.
Nikon is cagey about the weather resistance of its consumer lenses and there appears to be a range of opinions among users, but I support the view that you should be fine with the D7100 and a gasket equipped lens (including the 16-85mm) as long as you don't expose it to extreme or prolonged weather conditions. I have seen many anecdotes of people using this type of equipment in light or moderate rain and very, very few cases where damage has occurred.
As an extra safeguard it would be a good idea to dry the equipment after its been exposed to moisture. If you have a dehumidifier at home it would be effective for this purpose, or otherwise put the camera, lens and some silica gel in a plastic bag with the zoom fully extended for a while after use.
Remember that anything you do is at your own risk.
trac63
In reply to britcam, Dec 24, 2013
Kind regards
britcam - Rich S
And?
Doesn't mean you can't damage your camera that way, or that Pentax will repair or replace it under warranty.
Also, there's nothing to stop Pentax from paying to have that video shot. Not saying that they did, but it wouldn't really cost them very much, would it?
ISO_800
Regular MemberPosts: 288
Kind regards
britcam - Rich S
Wasn't that Pentax troll Heie banned from here?
starman1969
Senior MemberPosts: 3,584Gear list
In reply to Smiller4128, Dec 24, 2013
I don't normally go out in wet weather with my camera but there are some great photo opportunities in the rain, so it could be worth making an effort.
I don't have a specialist cover for my cameras so I tend to just try to keep under cover (by side of buildings etc) if it is wet. If, however, it is very wet I simply cut the bottom out of a normal carrier bag & poke lens through bottom. My cameras have got quite wet from time to time but they still run no problem. Carry some high absorbent kitchen roll strips to help dry the camera & lens.
They are watching us......
 starman1969's gear list:starman1969's gear list
Sony Cyber-shot DSC-RX100 III Nikon D600 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +9 more
David A. Hamments
Senior MemberPosts: 1,379Gear list
Although it's not a D7100, my D7000 with 80-400VR attached took a full frontal hit from a wave while hanging from my hip on a black rapid strap.  There was so much water, I was soaked from the mid chest down to my toes and dripping wet after the wave receded.  I felt my camera (and lens) were toast, but took a towel from my wife's beach bag and wrapped it immediately, soaking up the external water.  When I couldn't see any more water in any of the cracks or crevices, I turned the camera on to find it fully functional as if nothing had happened!   I can't imagine it getting wetter than that in the rain, and I expect the D7100 to be even better with its upgraded weather proofing to D800 levels.
Cheers, D. Hamments
My Flickr Page: http://www.flickr.com/photos/dhamments2013/
 David A. Hamments's gear list:David A. Hamments's gear list
Nikon 1 V2 Nikon D7100 Nikon D750 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 +20 more
