Another Moon!!! D7100 NOISE Hmmmmm
Started Dec 13, 2013 | Discussions
Hooper Photography Forum Member • Posts: 69
Ok, I love my 7100 BUT am wondering what would cause noise in my photo of the moon when I am shooting at ISO100. Just wondering. So see in the blue all the noise, someone please explain
Moon Noise
 Hooper Photography's gear list:Hooper Photography's gear list
Nikon D750
Nikon D7100
CaptainAmerica Forum Member • Posts: 86
Re: Another Moon!!! D7100 NOISE Hmmmmm
JPEG compression artifact?
Hooper Photography OP Forum Member • Posts: 69
Oh, I should have said, this was from a raw image. So in raw it had noise.
Nikon D750
blue_cheese
blue_cheese Senior Member • Posts: 1,722
According to others, the D7100 has no problems with noise in blue skies and base ISO.... so perhaps they can chime in.
I assume that it was a heavy crop and that you did not push the exposure? Did you try applying some sort of noise reduction, it looks like it may be fairly easy to clean up as it is mostly in luma.
"There are two sides to every issue: one side is right and the other is wrong, but the middle is always evil."
- Ayn Rand
ZorSy Veteran Member • Posts: 3,408
is this view at 400% or more? Or, you must have 2500mm lens, not the  500mm as the exif shows...
 ZorSy's gear list:ZorSy's gear list
Nikon D80 Nikon D7100
Jostian
Jostian Senior Member • Posts: 2,130
cropping to this extent will reveal artifacts on any photo regardless of brand... no surprises here
Jostian
 Jostian's gear list:Jostian's gear list
Fujifilm X30 Fujifilm X100T Canon EOS 7D Mark II Sigma 120-300mm F2.8 EX DG OS HSM Canon EF 24-105mm f/4L IS USM +3 more
JeanLeGrand Senior Member • Posts: 1,255
Pushing +1EV doesn't help either.
Honest criticism is hard to take, particularly from a relative, a friend, an acquaintance or a stranger.
 JeanLeGrand's gear list:JeanLeGrand's gear list
Nikon D80 Nikon 1 V1 Nikon 1 J1 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +18 more
Ill post the raw image so when  you view at 100% you will see it. Will be later today!
Nikon D750
starman1969
starman1969 Senior Member • Posts: 3,672
Doesn't look to be too much wrong with it to me, but it could do with a bit more processing to lift extra detail.
Have you ever thought about subtracting a Dark Frame?
Saying that though, dark frames are usually only used for higher ISO's, or lengthy exposures.
They are watching us......
 starman1969's gear list:starman1969's gear list
Sony Cyber-shot DSC-RX100 III Nikon D800E Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +9 more
rhlpetrus Forum Pro • Posts: 24,478
Why did you expect no noise at ISO 100?
Every image has noise, and more so in underexposed areas, which will become quite evident when you lift them up. Is this unprocessed? My guess is that you increased exposure in PP, no?
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
