Nikon colors in RAW
Started Dec 13, 2013 | Discussions
DeCorday
DeCorday New Member • Posts: 22
Nikon colors in RAW
Not sure if this is the proper place for this question...
So I've been shooting a Nikon D200 for about 6 months now... easily put over 10k frames through the thing. I love it, it's bulletproof, but I'm already thinking of upgrading because the high ISO performance leaves so much to be desired. Also I'd like to go FX within the next year or two.
Here's the question: When I go through my old shots from my ancient D70s, I'm really taken with the colors, compared to the D200. This surprised me, as they are both CCD sensors. In the future, I'd love to get a camera with color akin to the D70. The D70 regularly puts out RAWS that come out of Lightroom with little to know post processing with colors like this:
or this:
or this:
When I look online for discussion of the D70's color, most people seem to find it too desaturated and look for more vivid cameras. Me, I love this and wish I could get images like this out of my D200.
The question is, if I'm looking to upgrade, what should I expect out of CMOS sensor RAWs, color-wise? further deviation from what strikes me as a very film-y D70? Should I quit worrying and just beef up my chops in post?
 DeCorday's gear list:DeCorday's gear list
Nikon D70s Nikon D200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +6 more
Nikon D200 Nikon D70 Nikon D70s
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,089
Re: Nikon colors in raw
I think you have to try more options in your raw developer. ACR as all raw developer I know (NX2, DxO, just to mention two I also use) has option to choose your developing profile. If you like more saturated, even if you would like to simulate the default from another camera, all is possible.
Best regards,
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
(unknown member) Senior Member • Posts: 4,624
Re: Nikon colors in RAW
Just a few thoughts from an amateur.
Surely the color profile, even RAW, is a result of some processing. Thus, with the correct profile, you can get what you want from any camera, more or less, no? Yes, some more processing involved, but, the D70 was processed also, just more to your liking. What that says is, you need to find the RAW developer and profile to match your likes.
No?
Here, D300, processed with Leica M9 profile (just trying, but been using D3 profile with excellent results), in Capture 1 mainly, then slightly finished in Photo Ninja.
Looks quite film-like I think, from what I remember of film prints.
No?
Amateur photographer. Enjoy.....believe in yourself..
 Bajerunner's gear list:Bajerunner's gear list
Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
hirejn Regular Member • Posts: 341
RAW files by nature do not include processing like contrast, sharpness or color enhancements like JPEGs. You can't change RAW recording. RAW is unprocessed data from the sensor so there's no in-camera tweaking you can do. Think of it like a film negative. The film is what it is. You can change only how you develop it. RAW file are similar. I think RAW files have become better with new cameras and you won't find desaturated files.
If you want to take better pictures, become a better photographer. --
Joel Nisleit Photography
http://www.joelnisleitphotography.com/
 hirejn's gear list:hirejn's gear list
Nikon D300 Nikon D100 Nikon D200 Nikon D700 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +8 more
issac sam Junior Member • Posts: 34
Hi
D70 was my first Digital Body & I used it for paid assignments (people, Architecture, product). At that time, I loved its output. Progressed through several Nikon DSLRs and currently use a D800. Comparing the colors with the D70s colors, I always wonder about the desaturated look from it.
To me it looks awful. Only positive was its sort of 3D look which simply is not seen in any of the current DSLRs (both Nikon & Canon included). But that's just about it which looked good.
~Issac Sam
DeCorday
DeCorday OP New Member • Posts: 22
issac sam wrote:
Hi
~Issac Sam
That "3D" look is a much better way of describing what I'm talking about...
So, ok. I won't get that out of the box with any new DSLR. Have you had any luck replicating that feel in post?
Trevor G Veteran Member • Posts: 6,541
Before you replace the D200 whuy don't you shoot a series of scenes back to back with both cameras, at default settings?
I'm wondering if you changed one of the Picture Control settings in the D200, or maybe more than 1, and didn't realise...
It's sometimes better to start again from a position of knowledge rather than supposition.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
b2martin_a Contributing Member • Posts: 601
What camera profile are you using in Lightroom to convert the images for the D70 and D200?  The Default profile is Adobe Standard, but I don't get good results using this profile.  The D70 and D200 cameras do not support Nikon Picture Control Profiles, but Adobe supplied Picture Control profiles for both cameras - they are named Camera Neutral, Camera Standard, etc.  Lightroom does not read the profile you have selected in the camera, it will use it's default of Adobe Standard unless you select something else.
DeCorday
I'm importing with Camera Mode II on both, which I assume is a different setting for each camera based on some kind of Adobe-magic.
DeCorday
I am almost certain that they are both running in mode II with very few settings deviating from default, but I will check. My understanding was that these options only affected JPEG output... am I mistaken?
rhlpetrus Forum Pro • Posts: 24,486
I don't have any problems getting great colors from the D7000.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
I don't understand what you mean when you are importing with Camera Mode II.  I assume you are talking about importing into Lightroom, but Lightroom will not read what camera profile you have selected in the camera.  It will use what you have set as it's default for the camera and if you have not changed it Lightroom will use Adobe Standard.
The camera profile you have selected in the camera will be used by the camera to generate jpg images.  If you open the NEF files with Nikon software (View NX2 and Capture NX2) it will use the profile you selected in the camera, but you can change it if desired.
Adobe does not have matching profiles for the camera profiles available in the D70 and D200.  The profiles available in Lightroom are Adobe Standard, Camera D2X Mode 1, Camera D2X Mode 2, Camera D2X Mode 3, Camera Standard, Camera Neutral, Camera Portrait, Camera Landscape, and Camera Vivid.  The profiles with names of Camera xxxxxx are matching profiles for Nikon Picture Control Profiles that are available in the newer cameras - I believe starting with the D300.  You change the camera profile under the Camera Calibration tab in Lightroom.
DeCorday
Sorry, I should have been more precise... With the D200 I'm using "Camera D2X Mode 1" or "Mode 2." With the D70, "Adobe Standard"
Ok, now I understand.  I found that the Camera matching profiles used with the D200 were too bright and required reducing exposure.  I modified the profiles using Adobe's DNG Profile Editor to reduce the brightness.  I converted an NEF file to DNG, opened the DNG file in the DNG Profile Editor, selected the base profile under the Color Tables Tab, and then under the Tone Curve tab selected Camera RAW Default as the Base Tone Curve.  I then selected Edit > Export Nikon D200 profile.
I also generated a profile for the D200 that is a close match to the Mode I you select in the camera.
I don't have a D200 now, upgraded to a D700 several years ago.  I use Camera Neutral with a custom tone curve to match Neutral in the camera with contrast set to +1.
DeCorday
Awesome, that's super-helpful. Once I export the profile, is it selectable upon import? do I have to load it into lightroom? (sorry... I'm a bit of a digital newbie)
You do have to save the profile to the correct location and this depends on your operating system.  I am using Windows 7 Professional 64 Bit operating system.  I save the profile to C > Users > (your user ID) > AppData > Roaming > Adobe > CameraRaw > CameraProfiles.  I don't know if you have to close and reopen Lightroom before it will be available.  If you have a Mac, it will be in a different location.  I have been using Camera RAW in Photoshop CS6 and when I installed Lightroom 5 it shows all the profiles I have.
