X-e1 bracketing advice
Started Dec 12, 2013 | Discussions
see change New Member • Posts: 18
I am interested to know what people do to bracket photos with different exposures by one press of the shutter button and is there a way to get more difference than 1ev between the shots.
To me the 1ev difference is a bit on the weak side. I would have liked a 2ev difference better. Does the X-e2 come with more than 1ev difference between bracketed shots?
Thanks for any answers people care to reply with.
Fujifilm X-E1 Fujifilm X-E2
Red5TX
Red5TX Senior Member • Posts: 1,586
Re: X-e1 bracketing advice
X-E2 is the same as the X-E1: three frames at up to +/- 1 stop.  If HDR is super-important for you, the X-Series probably ain't your camera.
mmckeller Forum Member • Posts: 92
As a former Nikon shooter, I was spoiled with being able to shoot up to 9 brackets.  While the X-E2 will only do three at a time, it's still simple to do 9 from -4 to +4 (or any other combination you like):  First, select bracketing via the Drive button (the full-stop option in this case) - then, turn the Exposure Comp dial to -3.  With one press of the shutter button, you'll get exposures of -4, -3, and -2 (although not in that order).  Repeat the process with Exposure Comp dial set to zero, and then again with it set to +3.  You'll end up with 9 exposures spanning the range of -4 to +4.  Not as simple as Nikon, but still very doable.
see change OP New Member • Posts: 18
yeh I do it manually like this and get what I want but it woud be neat to press down only once and get the same results. I was wondering if I ws missing something but aparently not.
Thanks again.
HDR junkie
HDR junkie Forum Member • Posts: 96
It's true, it takes a little extra work to get a wider HDR support. Either with the trick described in this forum, put exposure compensation to +2 and take the first bracketing then switch to -1, and take the other bracketing (or +1 and -2), or to shoot in raw format, as it is good dynamics on the camera.
It would be easier if you could set EV steps up to 2 or 3 and the number of images to 3 or 5.
Mats
 HDR junkie's gear list:HDR junkie's gear list
Fujifilm X-E1 Fujifilm XF 10-24mm F4 R OIS
ryan2007 Forum Pro • Posts: 12,001
You can bracket exposure several ways after using exposure compensation. Change shutter speed, aperture or ISO.
If you do not know what a full stop is with these items their are or should be on line calculators or descriptions. It is too long to post.
Chrisd999
Chrisd999 Contributing Member • Posts: 883
I agree with the work-arounds already described in this thread. My own personal preference is a 6-exposure sequence with the first 3-shot set with EC set at +1, then dial EC to -2 while it is writing the files to the card, then take the next sequence. It gives me +2/+1/0/-1/-2/-3.
Although I really like the Fuji X system, and I am committed to it in the long run, the lack of proper exposure bracketing range is my number one pet peeve. I'm hoping that this gets fixed in a future FW update from Fuji.
 Chrisd999's gear list:Chrisd999's gear list
Sony RX1 Sony Alpha 7R II Sony 70-300mm F4.5-5.6 G SSM Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS +6 more
Sgt_Strider Senior Member • Posts: 2,207
And how long have we waited for that FW update to address this? It's been forever now and Fuji is still not doing anything about it. I don't even know if they've heard of the complaints yet. I think what we really need is the contact of someone at Fuji who will not only hear our concerns, but forward it to the right individuals to get this sorted out. I created a thread to ask in the past, but no one responded so I'm getting the impression that perhaps the majority doesn't care or that they don't know of such individual at Fujifilm.
