SX280 HS vs SX260 HS (interesting, odd, strange, but possible?)
Started Dec 12, 2013 | Discussions
Joe186
Joe186 Senior Member • Posts: 2,098
Aside from improved handling characteristics and the addition of WiFi features, the SX280 is almost entirely inferior to its predecessor. Sharpness—worse. Color accuracy—worse. Noise reduction—worse. And the performance metrics that didn't decrease have largely stayed the same. Video shooting is decent, but no better than the SX260. Dynamic range has been improved, but not by much. Chromatic aberration is less severe, but the apparent tradeoff is poor sharpness.
If you already own an SX260, or any decent travel-zoom, there's no reason in the world to upgrade to this one. In fact, if you're a brand new customer, we do recommend shopping around for the older, better SX260.
- http://cameras.reviewed.com/content/canon-powershot-sx280-hs-digital-camera-review
Canon PowerShot SX260 HS Canon PowerShot SX280 HS
brianj Forum Pro • Posts: 14,657
Re: SX280 HS vs SX260 HS (interesting, odd, strange, but possible?)
Interesting, I own the SX260 and am quite impressed with it.
On this point:
'the SX280 blurs images starting at ISO 800 and continuing up to the max. Since noise reduction cannot be tweaked or turned off, you're stuck with this limitation'
See my experiment with the sharpness control which slipped off the first forum page unnoticed:
http://www.dpreview.com/forums/post/52675616
I suspect the SX280 could be set to sharpness +1 to solve this excessive NR problem.  In the case of the SX260, default shaprness is just right.
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
