FL-14 + E-M1 + Canon off-camera shoe cord mystery
Started Dec 12, 2013 | Discussions
HMi Regular Member • Posts: 300
Tried to ask over at the u4/3 forum but got no answers.
I've been using the Canon off-camera shoe cord 2 with my Oly cam's and flashes. So far every single combination has worked but now the FL-14 used with the E-M1 do not work. Any ideas to what might be the reason?
The FL-14 works when used directly on the E-M1 and the FL-50 works both with the cord and without when used on the E-M1. The FL-14 works with the cord on the XZ-1 and the E-5.
So why on earth does the FL-14 not work with the cord on the E-M1???
Any ideas appreciated, Håkan
 HMi's gear list:HMi's gear list
Olympus XZ-1 Olympus E-1 Olympus E-5 Olympus E-M1
Olympus E-5 Olympus E-M1 Olympus XZ-1
John Mason
John Mason Veteran Member • Posts: 5,643
great question
I've also used my olympus flashes for years with my Canon cord, but haven't tried the combo since getting the EM1.
I'll try it tonight and see if I can duplicate your problem.
 John Mason's gear list:John Mason's gear list
Olympus E-M1 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +3 more
Pom_ZJ Regular Member • Posts: 176
Re: FL-14 + E-M1 + Canon off-camera shoe cord mystery
Are you using fresh set of batteries?
John Mason
fl600r and em1 - Canon off cord flash - also doesn't work
Just checked, and while the focus assist light on the fl600r lights up when I have press the shutter button, the flash does not fire.
Moving the flash to the camera the flash does fire.
This is very odd, since I had thought that the Canon Off Shoe Flash Cord was simply a electrical connection.  And there are enough matching pins on both ends for this combo.
So, sadly, confirming that the EM1 and FL600r also does not work on the Canon Off Camera Flash cord.
I have a nice stroboframe bracket that I like to use with flash.  I guess the next thing to do is check if Olympus sells such a cable.
John Mason
I suppose I'll order the Olympus FL-CB05 cord
Looks like if I want to use my stroboframe with my EM1 and FL600r I'll need to get the Olympus FL-CB05 cable.
Too bad.  I've always been able to use the Canon off shoe flash cable for years for this purpose on either my Canon or Olympus cameras.
goblin Veteran Member • Posts: 3,084
Re: I suppose I'll order the Olympus FL-CB05 cord
- Wasn't there a setting in the menu on older flashes which was telling the flash whether it is being used with a cable or directly ? Some "CBL" option comes to mind...
- Is this setting present on the newer flashes ?
If it is not, then the Oly cable won't work neither.
Do you have a way to check your Canon cable and your FL600r on a camera other than the E-M1 ?
 goblin's gear list:goblin's gear list
Ricoh GXR P10 28-300mm F3.5-5.6 VC Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus E-1 +41 more
Godfrey Forum Pro • Posts: 29,012
Re: fl600r and em1 - Canon off cord flash - also doesn't work
It might be a resistance or impedance issue. I remember that a couple of my Canon cords would not work correctly, and one of them didn't fit the shoe as nicely as the Olympus cable on the E-1 and L1. I haven't tried any of them on the E-M1 yet with the FL36. I don't have any of the newer flash units to test with.
Phil Rose Veteran Member • Posts: 3,778
I posted a couple of months ago about not being able to get TTL operation when using my (3rd party Canon-style) cable for the FL -36 with an E-3. The discusion then centered around possible (im)proper matchups at connector pin-positions (e.g., someone claimed they could get TTL to work but only with some "jiggling" of the connector--but that never worked for me).
Now I'm  suspicious that an impedence issue might actually be the cause. With my cable, the flash trigger operates OK, but the FL-36 displays only the manual mode.
Phil
 Phil Rose's gear list:Phil Rose's gear list
Olympus E-10 Olympus E-1 Olympus E-3 Olympus E-M1 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +6 more
BTW, goblin is correct...
As mentioned in goblin's post, there is a flash "setup" procedure whereby--among other things--you can tell the flash if it's being used on- or off-camera ( assume that "off" means a cable). For my FL-36, I tried using both options but it made no difference in respect to enabling a TTL (or FP) mode when used with my 3rd-party cable.
Phil
Gerry Siegel
Gerry Siegel Senior Member • Posts: 1,526
I just tested as you did, the Canon style off shoe cord (Vello brand) with my FL 50.  Since it works fine in all modes and fires and turns on and off, you do have a curious problem to report.
My neighbor always says the first thing in troubleshooting is to thoroughly clean and polish the contacts.  I am doubtful about the other speculations....a flash is a flash.  It should be no different from all other Olympus and Panasonic flashes.  That doesn't help....but do try cleaning all the pins.  Can't hurt.
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic Lumix DMC-GX7 Olympus E-M1
Gerry Siegel
And I even tried the Canon Vello brand B and H cable with my really old FL 20  mini flash----with full functionality, surprise. Contacts are still there and match up....  Vello btw makes a good product at a reasonable price vis a vis the Olympus cord, which is why I am using it after Oly cord became de soldered on me.
John Mason
Ha - not any more :)
Up until 2 weeks ago I could have tested it on an e1, e30, e5 or 5d3.  They are all gone now.
hmmmm - I do have an ep1 on loan to one of my kids.
That's an interesting thought about the menu.  I'll take a look.  It's just a simple hard wire connection.  I can't think of any reason is shouldn't work, so your menu though might be the just the ticket!
John Mason
cbl on or off menu choice - no change
I found the cable on or off menu choice - page 36 of the fl-600r manual and it made no difference.
The camera is aware the flash is there as my shutter speeds are locked down between 1/60th and 1/320th, the assist light will come on with a 1/2 press, and the flash changes from A to TTL A mode when I turn the camera on.
It's just the firing of the flash that does not work.  I also tried in the flash menu - auto mode, fill flash and some other modes.  I turned up underexposure to force the flash to fire.  I've tried A and M modes.  Of course, without the cable with the fl-600r on the camera, the flash works as expected.
I'm guessing it's as posted earlier, just some sort of electrical issue like impedance that is enough out of spec to not work on the EM1.
Jouko Senior Member • Posts: 1,355
Canon OC-E3 cable works with Em1
Just tested with FL50R and FL36R... Only one problem: I had to take off also the second part of the shoe and AP2-connection covers. The AP2-cover protects the "hole" under the hot shoe, and the rubber part of the OC-E3 shoe hits the cover...
PS. Just tried to take of the rubber... Easy. Works too, and the AP2-cover can stay on place. I'll stick with this combo. Better to protect the inside...
Jouko
'The best camera in the world is the one you have with you when you need it'
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
Re: Canon OC-E3 cable works with Em1
My cable is probably a diferent brand (Pixel) than yours, so I'm having trouble understanding: what is the "rubber part" on the cable shoe that you're referring to?
Phil
http://pirose.zenfolio.com
Some kind of weather sealing...
It is a rubber seal surrounding the "real" hot shoe. Not glued or anything, you can just take it off and put it back. No other function as far as I can quess without a Canon camera - and I have hard time quessing any more purposes for it.
The cable woks fine without it, locks to the place fine etc. Attaching maybe a bit more easier.
Jouko
Three ways to fail...
I've continued to ponder the limited (i.e., manual and auto works, but TTL unavailable) functioning of my FL-36 flash when used off-camera with a 3rd-party cable. This is true with both my E-3 and E-M1. Flash works fine directly on the cameras. Many others have reported similar  (mal-)function when using various 3rd-party Canon-type flash cables (these include some Canon camera users). From the various reports and discussions that I've Googled I've noted several aspects of cable construction that might cause the problem of variable/limited compatibility.
(1) Is there a protective diode in the cable circuit (included to protect against high-voltage trigger)? The OEM Canon (and presumably Olympus?) cable does indeed have such a diode at the flash/hotshoe end. My Pixel FC-311 cable does not contain a diode. I don't know this could be a factor in the TTL incompatibilty, and I mention it only because it's an electronic part that's missing from some cheap cables (like mine).
(2) Are the pins shaped so as to make good contact? One user with TTL compatibility issues pointed out the fact that the 3rd-party cable "pins" have broadly rounded ends and might not be able make contact with the slightly recessed contacts of the ISO-standard camera hotshoe (i.e., not contact as well as the relatively "pointed" ends of the OEM Oly pins). This might explain why some Oly users report needing to wiggle the cable end around before getting TTL ability.
(3) Finally, the issue of wire gauge/length (and resistance). My Pixel FC-311 cable has a 3-meter long cord length and  a measured 2.0 ohms resistance for each conductor wire. One owner  of an OEM (official) Canon cable reported a value of a mere 0.4 ohms for his. So due to either the wires' gauge or length, it's possible that some 3rd-party cables simply present excessive resistance in the camera-to-flash communications circuits. If that's the case, then the reason for some success with a 3rd-party cable might (partly) be due the shorter cable lengths some are using.
I'm highly suspicious that the issue with my particular cable is that it's just too long (10 ft?) considering the wire gauge that's used. I'd be interested to learn if someone who owns the FL-CB05 cable has measured the pin-to-pin resistance (just the small pins and not the central one which has a diode in the circuit). I expect it to be well under 1 ohm.
Phil
emersonik New Member • Posts: 4
Weird combination
I have 2 cameras (EPL1 + EM1), 2 TTL flashes (FL-600R + Metz 50 AF-1) and 2 Canon extension cords (1,5 meter Yongnuo FC-681 + 10 meters SLR Kit).
Every combination used to work fine, even with 2 flashes and 2 cords simultaneously.
One day I was using the EM1 + FL-600R + SLR Kit combo and the flash suddenly stopped firing. The flash was still turning on/off with the camera, the TTL function was working too, but the flash did not fire at all.
Then I swapped cameras/flashes/cords and realized that that specific combination was the only one that stopped working. Every other combo works as it used to be.
Now I'm very confused.
Gerry Siegel
Re: Weird combination
Cords sir are just strings of wire and in my opiniion are almost expendable consumables.  So my first thought is to try a new Canon compatible cord.  The configuration is so close that I substitute one for the original which de soldered on me.  Ten feet is getting pretty long and I doubt the clip or non clip setting is at fault although non clip is the way to set off camera Oly flashes.  My advice= Buy a long coiled, I think it is 3 feet, the longer model anyway of the Vello brand Canon off camera cord.  It has a nice lever lock and is well made.  But  like all hunks of  braided wire that get stretched in use, other than cleaning contacts I would go for a new twenty dollar coiled cord by Vello from B and H if you can find one.  Good price.  Good company. Good luck.  What else can one say.....the old Oly cord is so so and no great value In my humble view.  These guys take stresses and strains....like the ropes mountain climbers use they always start with virgin lines. each climb to be really safe....good luck and best to you.....sometimes as with my FL 36 a small difference in location of the wide panel not locking into something can screw up the functionality....just want to say that I get baffled a lot and it can be a toss of the dice..aloha
Thank you.
