MFT, APSC, FF lens equivalents
Started Dec 12, 2013 | Discussions
monashee Junior Member • Posts: 32
Hello, I am considering a MFT camera and have been looking at the lens lineup which seems pretty complete. However, I read something that if true, I need to consider. It is the relationship between FL, Fstop and DOF between the various sensor sizes. I always knew about the FL relationship, i.e. multiply by the crop factor:
FF 36mm = APSC 24mm = MFT 18mm
But then I read that this same factor needs to be applied to the Aperture.
FF 2.8 = APSC 1.8 = MFT 1.4
So for example, if a guy with a FF is shooting his 36mm @ f2.8 @ 1/60 then a guy with a mft would need to shoot his 18mm @ f1.4 @ 1/60 to obtain the same results (angle of view, exposure and DOF). And an APSC guy would need to shoot his 24mm @ f1.8 @ 1/60.
Is this basically correct?
Richard Weisgrau Veteran Member • Posts: 3,530
Re: MFT, APSC, FF lens equivalents
No, it is not correct. Focal lengths are constant regardless of formats that are variable. Aperture is the focal length divided by the a constant (like 8.0, 5.6. 4.0. etc). A 100mm lens at f/4.0 has an aperture diameter of 25mm no matter what sensor format it is directing light to. The so-called crop factor is relative and was intended to give 35mm film users a means of understanding the relationship of digital formats to 35mm film for still cameras.
Richard Weisgrau
www.drawnwithlight.com
www.show-my-house.com
Elemental Photography Contributing Member • Posts: 840
http://www.sansmirror.com/articles/pick-a-size.html
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic Lumix G 20mm F1.7 ASPH +7 more
MAubrey
MAubrey Senior Member • Posts: 1,598
Richard Weisgrau
Where did the OP say anything otherwise?
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Voigtlander 35mm F1.2 Nokton Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Chatokun
Chatokun Regular Member • Posts: 447
6
Richard Weisgrau
You're attacking an equivalence post by giving a technical answer that hardly helps the person asking. I know people are upset by equivalence, but this isn't a troll, it's someone asking a genuine question. This is just aggressive for no good reason. This is a person considered m43 and asking for help, not a FF troll trying to stir up trouble.
Now, on to the OP:
Somewhat close, but off on some things. First, as regards angle of view and DOF, you are indeed correct, they do correlate that way. Technically speaking, DOF is a function solely of the aperture and the focal length, sensor size only has something to do with it if you're trying to keep the save FOV. Still, from a simply results based perspective, what you said is close enough to correct to not matter.
However, exposure is off. If ISO is kept the same on all 3 (say 200), then the FF will be 2 stops darker than the MFT, and the APS-C the appropriate distance from both (3/4 a stop darker than mFT, 1.25 stops brighter than FF I believe?). So you'd either need to change the ISO or the shutter speed to match. Technically speaking however, this shouldn't be that much of an issue: if the sensors have the same efficiency(ie, same company in same generation), then making the ISO compensate should result in about the same noise. Of course, not all these companies use the same sensor companies or generation of sensors, so there may be differences.
Simply put: angle of view and DOF: close enough to yes, exposure: no, unless you adjust ISO.
 Chatokun's gear list:Chatokun's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LX100 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 +12 more
GBC Contributing Member • Posts: 979
It was angle of view, not focal length he asked about.
monashee OP Junior Member • Posts: 32
I apologize for my somewhat confusing OP. But I think I have an answer:
To summarize: i don't need to buy faster MFT lenses in order to maintain the same low light capability that I would have with an equivalent focal length FF lens (all else being equal).
Assuming SS, ISO and ambient light level is the same for both pictures, then if a picture taken with a FF 36mm set at f2.8 is properly exposed then a picture taken with a MFT 18mm set at f2.8 will also be properly exposed. However, my DOF will be larger on the MFT.
Did I get it right?
Anders W Forum Pro • Posts: 21,465
It is partly correct but not entirely. F/2.8 and 1/60 on FF is equivalent to f/1.4 and 1/60 on MFT with regard to DoF, the impact of diffraction, and total light accumulation of the sensor.
But it is not equivalent with regard to exposure. Exposure refers to the amount of light per sensor area unit (e.g., per square mm). In this regard f/2.8 and 1/60 on FF is the same as f/2.8 and 1/60 on MFT. At the same exposure, however, the FF sensor accumulates approximately four times as much light on account of covering about four times as large an area.
If you consider things from a more practical point of view, the MFT camera is likely to do about as well as the FF camera for equivalent photos (photos with the same DoF and same shutter speed, but with the different f-stops and different ISO settings required to make DoF the same). However, if you frequently want to shoot at f-stops wider than about f/2.8 on FF (corresponding to f/1.4 on MFT), then an FF camera is likely to serve you better since there are few lenses for MFT that are faster than f/1.4 and since these lenses are unlikely to perform as well at, say f/1, as an FF lens at f/2.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,724
m43 is 3.7 times less than FF (and that is if you really believe that image is off 36mm x 24mm, where actually the image might be from a less area..) so the crop is not 2, but 1.9
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
In order to get as noise-free an image, the MFT lens would have to be faster. Otherwise, the FF image would be better with regard to noise while simultaneously having less DoF (possibly less than you would want).
Yes, if the FF image is correctly exposed, then the MFT image will be as well. And yes, the DoF of the MFT image will be greater.
Did I get it right?
Again, partly. For me personally, MFT is fine since I rarely want more shallow DoF than I can get with fast MFT primes like the 45/1.8 and the 75/1.8. However, if you frequently want more shallow DoF than you can get with lenses like these, FF might be a better idea.
Thank you Anders.
A larger DOF is actually beneficial to my application so I have no concerns about that.
exdeejjjaaaa
then you might want just go for Sony 1"  P&S w/ 20mp... more DOF, more sensels, still good sensor tech.
But not an interchangeable-lens camera and restricted to the aperture range from about f/2.5 (short end of zoom range) to about f/7.1 (long end of the zoom range) if we translate to MFT equivalent f-stops.
ApertureAcolyte
ApertureAcolyte Contributing Member • Posts: 994
Best to think of your lens like this:
DOF = As per focal length.
FOV = About double the rated focal length due to smaller image circle.
Aperture = Is as written or given. Aperture is not halved on m43. This is a myth made by people who do not correctly understand lenses.
Therefore, a 45mm has similar DOF to a standard prime, but the FOV of a 90mm lens. Aperture has nothing to do with it.
 ApertureAcolyte's gear list:ApertureAcolyte's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
exdeejjjaaaa
not everybody needs interchangeable-lens camera ( w/ hand made UV filters to fix camera-lens mating )
good for DOF, who says that m43 is the sweet spot
Richard Weisgrau
The OP asked: "Is this basically correct?
I answered the question he asked.
Richard Weisgrau
Richard Weisgrau
"Attacking!" Wow. I thought I was answering the question he asked " Is this basically correct?
Richard Weisgrau
Angle of view is a result of focal length combined with the size of the focal plane.
Richard Weisgrau
JeanPierre Martel Senior Member • Posts: 2,844
Angle of view: FF 36mm = APSC 24mm = MFT 18mm
Taken from the same place, if they have the same number of Megapixels, a 36mm lens on a fullframe camera and a 18mm lens on a m4/3 camera will shoot the same image.
Bightness: FF F/2,8 = APSC F/2,8 = m4/3 F/2,8
If the lenses have the same aperture, a picture taken on a fullframe will be as bright (or as dark) as the picture taken by a lens with the same aperture on a m4/3 camera. All of them will send exactly the same number of photons per square mm on their respective sensor.
DOF: FF F/5,6 = m4/3 F/2,8
In order to get the same shallow DOF, the aperture on a m4/3 lens has to be twice as big. But the ISO will be higher on the FF camera precisely because the aperture has to be narrower.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
Sure. But the OP seemed interested in one.
The filter you refer to is surely not "hand-made" but it's a nice thing to have when needed.
I wasn't saying it is for everyone. For me it is though. For you too, it seems.
