Which wide-angle lens for D7100?
Started Dec 12, 2013 | Discussions
Ceridan
Ceridan Regular Member • Posts: 310
Hi!
I consider getting wide-angle lenses for my D7100 (to add to my 35mm f1.8 and 18-200 f3.5-5.6). So far from what I had read, the best all around combination is 10-24? Offers the right range.
I'd like something, which focuses quickly with my camera. And filter mount is a plus to use a protective UV filter.
So far there are two 10-24 lenses I know about:
Nikon 10-24mm f/3.5-4.5 (rather expensive)
Tamron 10-24/3.5-4.5 (cheaper, but quality?)
And there are also other candidates to consider:
Sigma 10-20mm f/3.5 (both for FF and DX?) (not so sharp as 10-20mm?)
Tokina AT-X 11-16mm f/2.8 (good for low-light!)
Sigma 10-20mm f/4.0-5.6
Tokina 12-24mm f4
Sigma 8-16mm f/4.5-5.6 (can't use a lens protective filter?)
Any thoughts?
(p.s.: I know there are many threads about it and I read some of them
 Ceridan's gear list:Ceridan's gear list
Nikon D750 Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S Nikkor 35mm f/1.8G Nikon AF-S Nikkor 20mm f/1.8G ED Nikon D40 +3 more
Nikon D7100
stevenjames
stevenjames Senior Member • Posts: 1,145
Re: Which wide-angle lens for D7100?
I have about a dozen f2.8 & f1.8 Nikon lenses and two third party lenses, one of them was my choice for wide angle - The Tokina 11-16mm. Its solid as a rock and great images.
Steve
www.StevenJamesPhotography.com
 stevenjames's gear list:stevenjames's gear list
Fujifilm X100S Nikon D7200 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Tokina AT-X Pro 12-24mm f/4 DX II +9 more
chuhsi
chuhsi Contributing Member • Posts: 958
my 11-16 is awesome, especially because i like to shoot in low light. the only drawback is the very limited zoom range.
 chuhsi's gear list:chuhsi's gear list
Nikon D3S Nikon Df Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-120mm f/4G ED VR +6 more
unknown member
(unknown member) New Member • Posts: 10
I have the Sigma 10-20 used on a D90 and D7000.  Its very good.
Just make sure you catch any lady's backside plum in the middle of the frame or she wont speak to you ever again.  Wide by name, wide by result
Zenjitsuman
Zenjitsuman Contributing Member • Posts: 790
Another vote for the Tokina Ver. II, FOV is 16-24mm on FF.  Can be used from 15mm of FF.
 Zenjitsuman's gear list:Zenjitsuman's gear list
Carl Zeiss Biogon T* 2,8/25 ZM Voigtlander 15mm F4.5 Super Wide Heliar Voigtlander 21mm F1.8 Ultron
Capt Bart
Capt Bart Junior Member • Posts: 28
I have the Nikon 10-24 on my D7000, and it is amazingly sharp.  I have blown up low light images of a sunrise to 24x36, and it still looks sharp.
 Capt Bart's gear list:Capt Bart's gear list
Nikon D7000 Nikon D810 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 50mm f/1.4G +5 more
nkistrup
nkistrup Senior Member • Posts: 1,650
Add the Samyang 10mm f2.8 that is scheduled to be released next month.  Could be a flop, or the best UMA lens for the APS-C crowd; too early to tell.
Renting the Sigma 8-16 this weekend, partially because I something wider than 17mm & more important to determine how much wide angle that I happy with (vs. overkill).
 nkistrup's gear list:nkistrup's gear list
Canon PowerShot G12 Olympus XZ-1 Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED +3 more
David A. Hamments
David A. Hamments Senior Member • Posts: 1,422
Steve
+1 for the Tokina 11-16.... it's sharp wide open and gets better out to the corners with mild stopping down to about f4. Great for low light settings like museums and other indoor locations. Built like a tank and as long as you have another zoom to cover the 16mm and up range, I'd highly recommend it!
Here's an example at 16mm (11mm was too wide) ...
Cheers, D. Hamments
My Flickr Page: http://www.flickr.com/photos/dhamments2013/
 David A. Hamments's gear list:David A. Hamments's gear list
Nikon 1 V2 Nikon D7100 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Teleconverter TC-14E II +20 more
herbymel
herbymel Senior Member • Posts: 5,289
Used it that way for the D800 till I was able to get the 16-35...did a pretty good job, and I plan on lending it to someone else so they can do a little wide angle work before they decide if they want to go that way for their next lens purchase.
 herbymel's gear list:herbymel's gear list
Nikon D810 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +7 more
