Is the FZ series dead ?
Started Dec 12, 2013 | Discussions
inti4444
Contributing MemberPosts: 998
Dec 12, 2013
I don't want to spoil the party.
After seeing some footage with the sony rx10, it seems like there is no competence with the fz series.
Don't get me wrong I especially bought the fz200 (continuous 2.8 aperture), but I knew it was an intermediate step until.....
Can the fz series really improve more with that sensor size, i hope so, but the sensor size has it's limit.
What do you think?
Gaston
Panasonic Lumix DMC-FZ200 Sony Cyber-shot DSC-RX10
Ronomy
Senior MemberPosts: 3,633Gear list
Re: Is the FZ series dead ?
In reply to inti4444, Dec 12, 2013
What do you think?
Gaston
I don't think so...small sensors will keep getting better and you need the small sensor if you want a small portable super zoom. The RX10 doesn't have the reach that the FZ200 has so its not a super zoom. Its more like a Bridge camera and expensive too. Not in the same market as a super zoom. IMHO.
 Ronomy's gear list:Ronomy's gear list
Canon PowerShot SD800 IS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
trevmar
Senior MemberPosts: 2,454
In reply to Ronomy, Dec 12, 2013
A recent interview with a Panasonic manager named the FZ series as a money-maker for Panasonic. I think it will stay, although I wonder what they are going to do to improve the FZ200. Maybe f2.7
Also, don't confuse the f2.8 of the RX10 with the f2.8 of the FZ200. Because of the larger sensor, the bokeh (and the consequent need to focus carefully) is much more prevalent in the RX10.
sherman_levine
Veteran MemberPosts: 9,559Gear list
I'm not sure I have the patience to wait 5 seconds for the RX10 to traverse the zoom range
Sherm
 sherman_levine's gear list:sherman_levine's gear list
Panasonic Lumix DMC-FZ1000 Nikon Coolpix P900
Robiro
Veteran MemberPosts: 5,657Gear list
All their best engineers have been assigned to micro4/3. Compact cameras are being neglected. Sad but true.
They could make a killer FZ50 mark II camera by putting LX7's sensor into it and using latest viewfinde, lens and touchscreen technology they developed while building m43 cameras and lenses. If they only wanted to. But they would not. Because they can rob you of more money by forcing you to switch to m43. Sad but true.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Panasonic 12-35mm F2.8 +4 more
Robiro
What do you think?
Gaston
But how? You can not possibly increase the pixel size. It is tiny and will remain tiny on a tiny sensor. They could improve the light receiving capability of those sensors by little bit but that's about it. They are hitting the ceiling of what is physically possible. Actually, they already passed it and they know it but keep quiet because people keep buying cameras based on how many megapixels they have.
LearningForeverIHope
Senior MemberPosts: 1,592Gear list
In reply to Robiro, Dec 12, 2013
So the FZ200 is the work of a lesser engineer ? Way to go Junior!
 LearningForeverIHope's gear list:LearningForeverIHope's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro Canon Pixma Pro-1 +2 more
GeraldW
Veteran MemberPosts: 6,839Gear list
I strongly disagreed with I-R comparison to the FZ200.  Just because the RX10 is a similar size and shape doesn't mean they are in the same class of cameras.  If you recall, when the RX10 was announced, DPR referred to it as a "superzoom".  200 mm equivalent focal length does not make it a superzoom.
The small sensor superzooms like the FZ150, FZ200, and SX50Hs are in their own class and valued for their reach.  The original superzooms (think of the Canon S3IS, Sony H1, and the Panasonic FZ7) had fast lenses, small sensors, and focal lengths of around 420-432 mm.  In my mind, that sets the threshold for qualifiying as a superzoom.  They are NOT bridge cameras, even though they look very similar.
Bridge cameras were first seen around 2003-2004 with the likes of the Canon Pro 1, Nikon 8700, Sony 828, and Olympus 8080.  They had a mini-DSLR look, a larger 2/3" sensor, and fast lenses of very high quality.  They were also expensive ($1000 for the Pro 1 at introduction) and very solidly built.  Sounds a lot like the RX10, doesn't it?  They were called Bridge cameras because they bridged the gap between the point and shoot models and the very expensive DSLR's of that era.  In order to be called a Bridge Camera, they have to bridge between something and something else.  The RX10 does that; but the FZ200 does not.
OK, with my rant out of the way, do I think the FZ200 and similar cameras are doomed.  No way!  They fill a real need for a high quality long zoom at a good price.  The compact travel zooms are creeping into superzoom focal length ranges; but they don't have the lens quality or the image quality of the true superzooms.  I do think there is room for more improvement.  Canon does a much better job of processing in their SX50HS than Panasonic did with the FZ200.  In fact, the FZ150 did a better job.  The FZ200 is unique because of its constant f/2.8 lens, high resolution EVF,, and better ergonomics.  If it had the SX50's sensor and processor, it would be a world beater; as it is, it's the best superzoom on the market today.  It's biggest problem is the relatively high price in its class.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot A720 IS Canon PowerShot S95 Canon PowerShot ELPH 330 HS Canon PowerShot G15 Canon PowerShot SX50 HS +1 more
Ronomy
What do you think?
Gaston
Small sensors with better noise control. Technology gets better and better all the time. Manufacturing processes get better and signal to noise ratios get better.
Robiro
What do you think?
Gaston
Those are MOS sensors these days. They have AD converters on the chip. There can be only so much photons hitting the tiny pixel. You can't increase the number. Physically impossible.
They could eventually develop better micro-lenses sitting on top of those receiving areas in individual pixels, but by how much better? 5% 10%?
There are optical limits to one can do with such a small sensor area. Once the signal is converted to digital, there are no more noise losses. The noise is a result of not enough photons hitting the individual pixels. And those pixels can not be made bigger because the sensor size is fixed.
Robiro
In reply to LearningForeverIHope, Dec 12, 2013
No. From time to time the boss graciously allows 2 or 3 of them to take a leave and spend a few weeks toying with non-4/3 stuff...
Sir Corey of Deane
Contributing MemberPosts: 951Gear list
In reply to trevmar, Dec 12, 2013
It certainly seems a money-maker for Wall Street Photo!
 Sir Corey of Deane's gear list:Sir Corey of Deane's gear list
Panasonic Lumix DMC-FZ18 Sony Cyber-shot DSC-H2 Fujifilm FinePix F300EXR Panasonic Lumix DMC-LX7 Kodak EasyShare CX7300 +10 more
Hatstand
Senior MemberPosts: 1,190
New sensor technologies
With these technologies, for a start:
Panasonic-Fuji organic sensor
Panasonic microsplitters
There will doubtless be more developments in future to improve sensors. These (or similar) will end up in all types of cameras of course, not just superzooms - but the benefits to superzooms (and other small-sensor cameras) are greater.
RX10 is a non-starter as a competitor to the FZ200, due to max focal length of only 200mm.
To achieve bigger focal lengths the camera/lens either has to become a LOT larger and heavier, or the sensor has to become smaller. Which is precisely why superzooms have such small sensors in the first place.
Ronomy
What do you think?
Gaston
Never say never!
Plus there was an announcement this year the Panasonic had new sensor technology to improve dynamic range.
Technology gets better and better all the time.  They probably already can make these sensors better but its too expensive.  Give it time.
Ronomy
Re: New sensor technologies
In reply to Hatstand, Dec 12, 2013
DOH!
Aberaeron
Senior MemberPosts: 3,949Gear list
What do you think?
Gaston
I think it is an incremental upgrade at a different price point. They do make more than one model you know.
 Aberaeron's gear list:Aberaeron's gear list
Fujifilm X20 Sony SLT-A57 Panasonic Lumix DMC-G6 Sony DT 35mm F1.8 SAM Panasonic Lumix DMC-ZS1 +15 more
Robiro
Still, the number of photons hitting a tiny pixel on a tiny sensor SHALL STAY THE SAME. We are only talking about better ability to capture them and count them. Of course, there will be improvements with this new technology. The question is - by how much.
Greynerd
Senior MemberPosts: 5,096Gear list
I think you will find the party for the RX10 is for pretty rich kids and probably is a different one to the one where you find many of the FZ200 owners. We are in the UK talking about a £1,000 camera versus a £400 camera. I am at a loss to see any basis for comparison.
This is an enormous premium to pay for what is still only a middle size sensor and with not particularly long reach. The RX10 is very much a luxury item in my view. Lottery win kit for me I am afraid.
What do you think?
Gaston
 Greynerd's gear list:Greynerd's gear list
Olympus TG-310 Panasonic Lumix DMC-ZS30 Olympus Stylus XZ-10 Panasonic Lumix DMC-FZ70 Olympus Stylus 1s +7 more
Me Tarzan
Senior MemberPosts: 1,392Gear list
Gaston, I own the FZ150 and it's a gem although I still drool over adding the FZ200 to my sack of tools.
Maybe I'm just easily satisfied, but the 150 along with the Panasonic G1 and the LX5 are keeping me content for the moment.
I haven't looked at the Sony you mentioned, but the last Sony I bought is a BOMB. Water color issues among multiple issues. Made me trust Sony less. I've never been disappointed with a Panasonic.
Cheers, Gaston and happy holidays.
Frank
Aberaeron
Are billions of photons either way, significant? I don't believe anyone has seriously claimed a shortage of photons hitting a sensor, have they? The trick is, surely, to make efficient use of all those photons.
Who knows what the future holds. The trend is to miniaturisation in most things though, packing more bang for the bulk [and the Buck].
