My E-M1 HDR question: please help if you can
Started Dec 11, 2013 | Discussions
RealPancho
RealPancho Senior Member • Posts: 1,291
The HDRs I've gotten from my E-M1 are too bright. I thought the principle reason for using this feature was to avoid lost shadow and highlight detail. I've tried but haven't found a way to shift the "midpoint" of the HDR bracketing to a lower exposure. Is it possible to do this?
Furthermore, the camera seems to be outputting both a single jpg and raw version of any HDR photos, with the raw having less room for PP manipulation, and worse blown highlights. I'm scratching my head. In some cases, I seem to able to do better without the HDR, and simply brightening the shadows and darkening the highlights in LR5. But I know this won’t always work, and I’d like to able to shift the HDR bracketing “left” a bit, if you get my meaning.
In the example below, I've posted the straight out of the camera HDR JPG, and processed versions of that same JPG and its corresponding ORF. Next, I have another, non-HDR shot of the same scene, first straight out of the camera (JPG), then as a processed ORF. What seems strange to me is that there are unrecoverable highlights in the HDR ORF that are easily pulled out of the HDR JPG and the non-HDR shot.
Please offer whatever wisdom you may have to share in this regard. Of course, any other comments are welcome as well. Or, uh, at least tolerated.
SOOC HDR JPG
Processed HDR JPG
Processed HDR ORF (lost detail in highlights on wall)
SOOC non-HDR
Processed non-HDR
Frank
 RealPancho's gear list:RealPancho's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +6 more
Olympus E-M1
Florida Nature Photographer Senior Member • Posts: 7,798
Re: My E-M1 HDR question: please help if you can
I can help if you are interested in HDR that isn't "in camera" but I didn't want to risk sending your thread in a direction you didn't want it to go.
 Florida Nature Photographer's gear list:Florida Nature Photographer's gear list
Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 12-40mm F2.8 Topaz Adjust +3 more
jkrumm Veteran Member • Posts: 9,016
I'm pretty sure the ORF is not HDR and that's why it has some blown highlights. Notice also that you are shooting at iso 200 vs. 100 with your other ORF, and you had to us 1/500  in the second one to avoid too many blown highlights because iso 100 is the same iso with a more linear tone curve (gives it much higher contrast).
It would be cool if the camera made HDR orfs, some kind of extra-malleable high-bit blend. Looks like your jpeg hdr post-processing came out pretty good.
John Krumm
Juneau, AK
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,242
p. 59 in the manual
The RAW file is a reference file, the JPG is the result of the HDR exposures blended in-camera.
From p.59 of the manual (EN):
  • In the case of HDR1 and HDR2, the HDR-processed image will be saved as a JPEG file. When the image quality mode is set to [RAW], the image is recorded in RAW+JPEG. The only image recorded in RAW is the image with suitable exposure.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
pdelux Contributing Member • Posts: 512
Technically you executed the shots well, personally I dislike all of the processed images as they look somewhat cartoonish, but this is to be expected from some HDR and some scenes.
I do not have any experience with the EM1, but I know that processing externally, different applications will give vastly different results when blending HDR scenes (from ultra realistic, to dreamy fantasy-scapes)
Maybe you need to try a different HDR app?
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
GlennAA11 Regular Member • Posts: 175
Did you try dialing the exposure compensation down?
 GlennAA11's gear list:GlennAA11's gear list
Nikon 1 V1 Olympus OM-D E-M5 Nikon D600 Olympus E-M1 Nikon AF Nikkor 50mm f/1.8D +15 more
RealPancho
RealPancho OP Senior Member • Posts: 1,291
No problem. Any assistance is welcome. The thing is that I've only dabbled in HDR, and have always come away dissatisfied. That was why I was enthused with the potential for a simpler, in-camera approach.
Frank
RealPancho
Re: p. 59 in the manual
Thanks, Bob. You know, I read that at one point and then probably disregarded it because it didn't address what I was looking for. My mistake. And this definitely answers the question regarding the raw file, although I'd take exception to the camera's idea of "suitable" exposure. It's frustrating that the exposure compensation seems to be disabled when in HDR, which is the main thing I was hoping to find a way around.
...Bob, NYC
Frank
RealPancho
I hear what you're saying, but this was really late in the day, and the scene was pretty warm and vivid.
Yeah, that's what I was hoping to avoid. I've only dabbled in HDR, and haven't been too enamored of the results, nor patient enough to properly master the techniques. I think I'm looking for the lazy man's way out.
Frank
RealPancho
Yes. It doesn't work in HDR mode.
Frank
I used the Merge to 32-bit HDR Plugin for Lightroom to produce this. You could also use L/R Enfuse but it doesn't do 32 bit only 16 bit. I took a five bracket exposure, merged them, then adjusted the highlights and shadows etc. in Lightroom to do this. I was quite pleased with the results and I had a lot of flexibility to make it look like I wanted creatively.
All you need to do is highlight the five versions of the photo, right click, merge to HDRSoft, and wait. It produces one .tiff that you edit just as if it had come out of the camera.
You can see below representative samples of what I started with.
DLBlack Forum Pro • Posts: 11,887
Because of no exposure comp in hdr mode I ended up placing the camera in manual mode after a few test shots to figure out the exposure. Then do the in-camera HDR.
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II +31 more
Bob Tullis
There's a lot to absorb, and it usually only sticks when putting each of these things into practice. (Been there, forgot that).
Yea, I know what you mean, Frank. It strikes me as something that wouldn't have been included in a pro model, except for marketing considerations - those that consider in-camera HDR being absent as a deal-breaker. I'm not complaining, but I feel 1/2 of the mode dial settings are there for the same reason.
...Bob, NYC
Roxy1945 Senior Member • Posts: 1,420
Use Photomatix Pro. Its simple  and does a good job.
I'm just glad there are enough of them that are throwaways that I can program with 4 MySets. I don't have to overwrite any useful dial positions, as a result.
Bob Tullis
Well a pro camera might have Cust1, Cust2 as mode settings instead of art, scene. . . here everyone can have it their way. Which is why I'm not complaining [g].
...Bob, NYC
bgalb
bgalb Senior Member • Posts: 1,752
I'm not sure if HDR mode lets you use spot metering or not. If it does, then you could meter on one of the lighter parts of the scene using AEL and see if that helps balance out the final jpg better. I would try it myself right now, but my camera sits here with the 100-300 lens on it and I am too lazy to go upstairs and change lenses.
I haven't tried in camera HDR yet, but didn't hold out much hope for it based on other comments I have seen on the forum.
 bgalb's gear list:bgalb's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GX85 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +6 more
bgalb
Oops!  AEL isn't going to work!
RealPancho
Now, why didn't I think of that? I'll give this a shot tomorrow. It sounds like it might work. Thanks.
Frank
lnikj Regular Member • Posts: 190
Frank
I'm afraid I will go off at a slight tangent ...
At the end of this thread I posted some comparison shots of in camera HDR vs tone mapping & exposure fusion: http://www.dpreview.com/forums/thread/3588044?page=2
[I note now from comments above that I too had misunderstood the nature of the 'RAW HDR', but I had posted the out of camera jpegs anyway.]
As I pointed out there I think that in camera HDR is really a step too far at the moment. Computer based algorithms take minutes to align images, deghost, remove noise etc and then generally give you hands on control before the end of the process of where you want to set white and black points, and sometimes mid tones too.
When I took those shots I saw the camera process the images in a few seconds. That's a tiny little camera taking a few seconds vs my quad core taking a few minutes.
Whilst I expect the E-M1 might have made a better fist of things if I had shot on a tripod I still don't think it could ever have matched what could be done on a computer.
[One thing to perhaps note from the comparison shots with regard to your question is that there is not that much difference between the levels of the in camera HDRs and those of Photomatix/Contrast Optimizer & LR/Enfuse when set on their defaults. Marginally brighter I guess but not massively so.]
I'm afraid that you might have to wait a little longer before cameras have the processing power to give you the IQ you want for in camera HDR though I agree that having provided this feature Oly could have made it a little easier to control at the time of shooting.
 lnikj's gear list:lnikj's gear list
Olympus XZ-1 Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1
