70D auto light optimizer only affects jpgs right?
Started Dec 11, 2013 | Questions
Wolfkc Regular Member • Posts: 143
ALO is effectively disabled for RAW? How about Hightlight Priority?
 Wolfkc's gear list:Wolfkc's gear list
Fujifilm XF1 Canon EOS 70D Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 10-20mm F4-5.6 EX DC HSM Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +3 more
Canon EOS 70D
RS_RS Senior Member • Posts: 1,725
Re: 70D auto light optimizer only affects jpgs right?
ALO does not affect RAW file data, only the embedded JPEG. HTP does affect RAW file data.
skanter
skanter Forum Pro • Posts: 10,600
As a RAW shooter, I ignore a good portion of these type of settings. It simplifies matters making these decisions after the fact, and for me, a much better way to work.
Sam K., NYC
 skanter's gear list:skanter's gear list
Adobe Photoshop Lightroom 5 Canon EOS 70D Sony a6000 Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM +10 more
R2D2 Forum Pro • Posts: 16,416
+1  Same here.
Sony RX100 II Canon PowerShot G3 X Canon EOS 70D
Sam K., NYC
Up to a point. If you use the embedded JPEG to review images then it is quite a good idea to choose settings that make it as useful as possible, even if the RAW data is what will be used back at the ranch.. For me, ALO is not something I use, but I do apply an appropriate level of in-camera sharpening so as to be able to assess focus accuracy as easily as possible. HTP is a different matter, since it does affect the RAW data, and I use it when needed.
rdspear Veteran Member • Posts: 4,388
RS_RS wrote:
Sam K., NYC
I'm the complete opposite.  I have the JPEG settings such that the histogram best represents the actual RAW file histogram. This requires turning many of hte settings to their minimums, meaning the JPEG would actually look terrible.  A good looking JPEG will give you clipping blinkies and a maxed histogram with a full stop of RAW headroom remaining. I look at the JPEG for framing only.
 rdspear's gear list:rdspear's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF-S 10-22mm f/3.5-4.5 USM +19 more
rdspear wrote:
RS_RS wrote:
Sam K., NYC
No, you are completely the same, in the sense that you choose settings o make the JPEG as useful as possible to you. I said nothing about making it good-looking.
birdbrain
birdbrain Veteran Member • Posts: 3,475
Re: 70D auto light optimizer only affects jpgs right? Depends.
If you use Canon's DPP then opening a RAW file where ALO was on the image displayed will have ALO applied, you can turn it off or adjust the amount within DPP.
Opening the file in any other RAW converter and there will be no ALO applied to the image.
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/sets/
 birdbrain's gear list:birdbrain's gear list
Sony Cyber-shot DSC-RX10 II Canon EOS 5D Mark III Canon EOS 6D Canon EOS 7D Mark II Canon EF 16-35mm f/2.8L II USM +13 more
