X100S & Lens moving?
Started Dec 11, 2013 | Discussions
Bob Ring Regular Member • Posts: 128
I just got a used X100S.  Question when you clean the lens does it move a little?  I cleaned mine with a soft lint free cloth & it kind of wiggled.  Seems odd to me! Thanks,
Bob
Fujifilm X100S
Pudden Tame Forum Member • Posts: 70
Re: X100S & Lens moving?
That is a scary thought.  The lens on my X100S has no movement whatever.  Do you have a filter on the lens and could that be moving?
Bob Ring OP Regular Member • Posts: 128
No filter.  It's actually the lens moving like rocking a little as if it's on little shock absorbers or something.
If you put your thumbs on the black area around the glass element where the text is on either side I can 'rock' my lens.  The outside (silver area) does not move just the inside.
Randy Benter
Randy Benter Veteran Member • Posts: 3,145
That is OK; it is supposed to rock a bit. Also watch when you AF the camera and you will see that black area moves during focusing so it is not supposed to be rigidly fixed to the body.
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Nikon D7200 Fujifilm X-T10 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
Thanks Randy.  That makes a lot of sense. Kind of a duh moment but it never hurts to ask!  Bob
fitzy Junior Member • Posts: 49
Panic over Bob..mines the same
 fitzy's gear list:fitzy's gear list
Fujifilm X-T1 Fujifilm 16-55mm F2.8R LM WR
