Nikon D7100 and Noise at High ISO
Started Dec 11, 2013 | Questions
alfio lora
New MemberPosts: 6Gear list
Dec 11, 2013
Hello everyone,
In certain reviews on the Nikon D7100 and noise handling at high ISO, they show sample pics with very good handling even at ISO as high as 3200.
I have used mine at ISO 2500 and notices a LOOOTTTTT more noise than those sample pics. does not perform the way I have seen in the reviews.  I use the Nikon 28-300mm FX lens and shoot manual.  Is there any special trick on lowering noise at a certain high ISO that I may not know about ?
I greatly appreciate eveyone´s help !!
alfio
 alfio lora's gear list:alfio lora's gear list
Nikon D7100 Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Adobe Photoshop Lightroom 5
Nikon D7100
Leonard Migliore
Forum ProPosts: 12,487Gear list
How are you looking at the images?
In reply to alfio lora, Dec 11, 2013
alfio lora wrote:
Hello everyone,
Are you looking at 100% views? Then the D7100 is going to look noisy indeed. But it's a 24 MP camera; at any reasonable viewing size, you won't see anything at all.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
alfio lora
Re: How are you looking at the images?
In reply to Leonard Migliore, Dec 11, 2013
Hi Leonard,
I am not cropping, this is whats strange,  I am viewing them at regular size. It is quite confusing.
alfio
Alleg1
Contributing MemberPosts: 836Gear list
Re: Nikon D7100 and Noise at High ISO
alfio lora wrote:
Hello everyone,
alfio
Some general suggestions which might help...
1) Make sure you are not underexposing as this creates noise; many people try to keep the ISO level down to avoid noise, but if this is overdone it can lead to worst noise through underexposure.
2) Noise can be reduced to an extent in post processing, using programs such as "Neat Image" or "Noiseware" amongst others.
3)If you shoot Raw, noise reduction can be applied in Raw conversion rather than relying on in camera settings, so it can be better controlled.
 Alleg1's gear list:Alleg1's gear list
Nikon D100 Nikon D300 Olympus E-510
tjwaggoner
Senior MemberPosts: 1,096Gear list
alfio lora wrote:
Hello everyone,
alfio
A lot of test shots you see online are shot in good light but use high iso. This is misleading to a lot of people I think. They do this to make test scenes identical for all settings on all cameras.
Constructive Criticism is always welcome, however please understand that I am not a pixel peeper.
 tjwaggoner's gear list:tjwaggoner's gear list
Olympus E-10 Panasonic Lumix DMC-LX7 Canon EOS Rebel SL1 Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +1 more
RhysM
Senior MemberPosts: 2,163
To get the best low noise performance out of the sensor you need to nail the exposure, any under exposed images will show up noise when pushed in post production.
bobn2
Forum ProPosts: 39,500
In reply to tjwaggoner, Dec 11, 2013
tjwaggoner wrote:
alfio lora wrote:
Hello everyone,
alfio
The exposure should be the nominal exposure for the ISO set, if the test is done properly, so the light is the amount of light for that ISO. The 'good light' question is more that in low light scenes there tends to be proportionately more shadow, and in many cameras shadows suffer proportionately more than the brighter areas, because the electronic noise is visible there. The usual tests still give a guide as to how the camera will perform in low light scenes, just concentrate on the quality of the darker bits.
Bob
Draek
Senior MemberPosts: 2,028Gear list
There's some, most if not all based on the simple fact that more light means less noise, and conversely less light means more noise, regardless of ISO. Thus:
- Overexpose if you can without blowing the highlights, but certainly never underexpose. Overcast days are a common culprit since few metering systems deal well with them, and a -1EV underexposure turns your ISO1600 shot into something mildly worse than a normal ISO3200 shot. Even if you don't brighten it, since you're still pushing the whole of the image into the noisier shadows.
- Watch out, and compensate if you're able, for White Balance. Think about it: to bring the yellow light of a tungsten bulb back to white, the camera needs to boost the blue channel to bring it up to par with the green and red ones, right? but, that same boost is what happens when you raise the ISO, so one way of looking at it is that your reds and green pixels might be working at the ISO400 you set, but your blue pixels are working at ISO1600 instead (this isn't exactly accurate from an engineering standpoint, but it's close enough). This issue is also why cameras, specially compacts, show large amounts of speckled noise when shooting outdoors at night, even at base ISO; most cities still use sodium lights for street lamps, which produce light only in a very narrow spectrum near yellow, much narrower and yellowish than even tungsten -- thus, effectively the only blue the sensor is taking in comes from the moons and stars. So, what's the ideal for a camera? something as close to daylight as possible -- LED panels and strobes produce less noise than tungsten bulbs for the same apparent illumination, for instance, due to this issue.
- If you can, don't shoot with the lens wide open. The reason is that lenses have not only f-stops, which determine DOF, but also t-stops, which determine how much light reaches the sensor. At typical f-stops (say, f/8) the difference is within measuring error, but in many lenses, specially fast primes, the difference can be of 0.5EV or more due to issues like vignetting, incident angle of the light, etc. So how come the exposure still seems to follow the "halve one, double the other" rule? easy: most cameras' firmware compensates for the difference when shooting with fast lenses wide open by silently raising the ISO. Of course, this isn't too relevant outside of tripod shooting since f/1.4 and ISO1250 (appearing as 800) is still better than f/2.8 and ISO3200, but it's something to keep in mind when comparing against online samples. And remember, even if you get unchipped manual lenses which the camera won't compensate for, vignetting and problems with the incident angle will still happen, throwing you back to the issue of underexposure in the corners as per above.
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
alfio lora
In reply to Draek, Dec 11, 2013
Excellent advice and input from everyone, Thank you very muuuuchhhh !!  I will use them
alfio
Jack Hass
Regular MemberPosts: 392Gear list
In reply to Draek, Dec 12, 2013
This is an absolute farce. Overexposure assumes you have room for a slower SS, and if you had room for a slower SS in the first place, why not just use a lower ISO with a normal exposure which would lessen the chance of blown highlights and still offer less noise???
The rule of thumb for experienced photographers is always use the slowest SS possible, which means you must know your subject to obtain the nominal IQ. With the slowest SS possible, you will be able to either under expose by using lower ISO in camera, pulling it up in post, or, use the appropriate ISO in camera for proper exposure. Either way, you can move the little exposure sliders around all you want and it doesn't change the amount of light being recorded, but to risk highlight clipping because you think you found some tricky way to beat physics just shows your ignorance.
I remember reading this "trick" in the sony forum a while back, when people were complaining about noise when the 24mp apsc sensor was new. When people claim you can overexpose using longer SS, it shows they weren't using proper technique in the first place. Perhaps you should spend less time programming "software" and more time learning good photography technique, at least before you try giving advice to strangers.
Jack Hass
In reply to Alleg1, Dec 12, 2013
Again, completely untrue. Noise is determined by the amount of light hitting the sensor, which is determined by SSxAperture. ISO isn't even really part of the exposure "triangle", it is just a digital boost to the visual brightness of an image (keep in mind, be it PP boosting or in camera ISO, the "brightening" of an image brightens both the color and noisy pixels, hence why noise is more apparent at higher ISO). Some people shoot at base ISO all the time, and only adjust SS/Aperture as needed. Then they boost "exposure" in post by pulling it up to whatever suits their taste visually, which is, again, essentially what your camera does with ISO.
Always at the expense of sharp details, as averaging is all that can be done with software for now.
Very true, and some believe this is also true with ISO.
Draek
In reply to Jack Hass, Dec 12, 2013
Because most cameras typically offer 1EV increments for ISO when set manually. And, in my experience, it's either equal or better to overexpose then pull than underexpose then push with respect to noise.
Nope, it's you who's showing his ignorance, by making quite a few assumptions about sensor design and image processing which do not necessarily hold in the real world.
Ever heard of these long-coveted "ISOless" sensors? ever wondered how those that aren't "ISOless" behave?
Or perhaps you should get an actual clue about how things really work before mistakenly "correcting" someone else.
Alleg1
Thanks for your comments, but I have to disagree about the noise issue. The problem of underexposure and noise is well documented.
Kodachrome200
Contributing MemberPosts: 762Gear list
there is a difference in the sort of gain used in post processing and changing iso, the deleterious effects of using relying on gain in post are well documented.
 Kodachrome200's gear list:Kodachrome200's gear list
Ricoh GR Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Sigma 12-24mm F4.5-5.6 EX DG Aspherical HSM +3 more
Kodachrome200
I have to agree with Draek. while you are correct that experienced photographers may try to use the slowest shutter speed they can. they also realize that just about any amount of movement means slowing the shutter down is going to lower resolution. so will hand holding. also when shooting alot of the time you can constantly be fiddling with iso and shutter speed to get the shot you want so to say that experienced photographer never waste an iota of iso on shutterspeed. well thats just not true. Also you are dead wrong about how experienced photographers expose. IT IS absolutely optimal to expose as brightly as possible with without clipping the highlights. as Draek said there is no such thing as an ISOLESS sensor
Allan Olesen
Senior MemberPosts: 3,357
Yes, but a lot of times it is documented by people who don't understand what they are seeing, and consequently they draw the wrong conclusions. And basically, the problem is that they don't even understand their own decision making process.
I often see recommendations like: "You can get good photos with camera X at ISO3200 if you just set your exposure compensation to +1 EV and darken the photo later."
Well, let us look closer into that recommendation with some Q and A:
Question 1: Why do we pick ISO 3200?
Answer: Because a lower ISO would require more light than we can get into the camera with the shutter speed and aperture we can accept under the given circumstances.
Question 2: What happens if one sets the EC to +1 EV?
Answer: The camera will reduce the shutter speed or open up the aperture to let in more light.
Question 3: But if we were already at the limit of acceptable shutter speed and aperture, won't we get an unacceptable shutter speed or aperture when we do that?
Answer: Yest we will. That is why the recommendation is meaningless.
Question 4: And if we really did have room for reducing shutter speed or opening the shutter speed 1 stop, couldn't we achieve exactly the same if we had just picked ISO 1600 and no exposure correction?
Answer: Yest we could. That is why the recommendation is meaningless.
At lower ISOs where some (a lot, actually) cameras have lower noise at the same shutter speed and aperture if you increase the ISO, it can make sense to increase the ISO as long as you don't get unwanted clipping of highlights. But such choices can be made much more consciously if one first thinks about aperture and shutter speed and then thinks about ISO. The idea of first thinking about ISO leads to misconceptions as the one I described above.
alfio lora
In reply to Kodachrome200, Dec 12, 2013
Carefully analysing what everyone is inputing. there is correct information from everyone, but I believe that darks show noise more than whites it is absolutely true, and if we can expose to to the limit without clipping whites, then when we blow up the shadows, the damage will be less.
I believe what was said about using the "perfect" light in those sample pics showing ISO performance could also be misleading. High ISO performance should be shown with tons of dark areas ,  there is where we can really see what the real output is
alfio
Jack Hass
In reply to Allan Olesen, Dec 20, 2013
I may be late to respond, but this is exactly what im talking about. Why would anybody start with ISO??? You wouldn't know what ISO you needed to begin with unless you had your SS/aperture set already. Unless of course, you can meter with your eyes and know exactly what settings are needed with what ISO.
If you are already at the slowest SS you can use, and are already wide open, then the only thing left to do is raise ISO. So the suggestion is to rais ISO a stop to get that +1EV exposure, only to pull it down in post in hopes to get less noise? Perhaps somebody can post two shots showing the benefits.
Jack Hass
In reply to Kodachrome200, Dec 20, 2013
There is no isoless sensor? Here is a thread discussing it, and Here is another. Furthermore, if the ramblings of your peers are not enough to convince you, here is another very math heavy explanation from http://www.josephjamesphotography.com. Here is a simple quote explaining the situation as it applies to our thread:
"Unlike film, the sensitivity of the sensor is fixed -- that is, the ISO setting does not affect the efficiency of the sensor. However, for sensors with noisy ADCs (Analog to Digital Conversion units), higher ISO settings result in less read noise than lower ISO settings. For example, the read noise for the Canon 5D3 at base ISO (100) is 33.1 electrons, drops to 18.2 electrons at ISO 200, and continues to drop until it finally levels off at around 3 electrons at ISO 3200. On the other hand, some sensors, like the Sony Exmor sensor in the Nikon D7000 and D800, have the same read noise throughout the entire ISO range. These types of sensors are referred to as "ISOless", although it's worth noting that even "non-ISOless" sensors usually become ISOless after some point in the ISO range."
So as was already discussed, certain sensors like canon can benefit ever so slightly at higher ISO than low ISO because the read noise is a fraction lower, although this difference is hardly visable. If  you however have an isoless sensor, one whos read noise is not increasing with ISO level, there is NO advantage to overexposing with higher ISO. Which means you should not risk highlight clipping for no reason. It seems nobody here was aware of these sensors being available today, let alone 2 years ago, which begs the questions, what the eff have you guys been doing? Handing out advice which clearly contradicts reality because you didn't know what sensors were available? These sensors are in more cameras than they aren't, which means we have some people in this thread who are very behind in their knowledge.
Jack Hass
In reply to Alleg1, Dec 20, 2013
Again, another person who is not informed. Read my above post. Welcome to modern photography.
