No new 7dMk2 in the near future
Started Dec 11, 2013 | Discussions
elfroggio
elfroggio MOD Senior Member • Posts: 2,537
Hi,
Canon has just released a new firmware for the 7d, v2.0.5 dealing with an FTP bug in file transfers.
http://www.usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_7d#DriversAndSoftware
Canon would not make a new firmware (it's very expensive coding, testing, releasing...) if the new 7dMk2 was coming in the spring...
http://www.sritch.com
Street Photography: The Dogs of Vancouver, BC
Canon EOS 7D Nikon 1 V2
RS_RS Senior Member • Posts: 1,706
Re: No new 7dMk2 in the near future
10
elfroggio wrote:
Hi,
It's a bug fix, not a feature enhancement, and tells us nothing about a possible 7DII.
Sports Shooter Contributing Member • Posts: 999
elfroggio wrote:
Hi,
I hope Canon hasn't got something in the firmware to stop us using third party batteries and Sigma lens
I read horror stories in the Nikon camp
 Sports Shooter's gear list:Sports Shooter's gear list
Canon PowerShot G9 Canon EOS-1D Mark III Canon EOS 7D Canon EOS-1D Mark IV Canon EF 85mm f/1.8 USM +10 more
yehudakgtbnet Senior Member • Posts: 1,188
Thank you for the heads up.
elfroggio wrote:
Hi,
I loaded the new firmware, a very easy procedure. It erases the time data.
Yehuda
 yehudakgtbnet's gear list:yehudakgtbnet's gear list
Canon EF 24-105mm f/4L IS USM
elfroggio
elfroggio OP MOD Senior Member • Posts: 2,537
RS_RS wrote:
elfroggio wrote:
Hi,
Yes it does. To release a new firmware would cost Canon between .5 to a full million dollars.
  1. Define the requirements
  2. Assign a team
  3. Make the fixes
  4. Do some preliminary testing like does it work or not, does the bug fix breaks something else
  5. Translation in other languages
  6. Beta testing to a few dozen people, wait for their results
  7. Remove all the debugging code
  8. Some more testing to check that removing the debugging code doesn't break anything
  9. One last set of testing
  10. Releasing the firmware
  11. PR/media releases
  12. Update all the websites where people can download
You do not want to incur these type of costs for such a marginal bug that affects very few people: FTP/USB with the Wireless File Transmitter WFT-E5A, since the last update was Sep-2012
grayskyz New Member • Posts: 12
I think it's interesting that people think they know what a multi BILLION dollar multi national company is going to do based off a firmware release. I'm sure the financial analysts as well as the competition are freaking out right now because this ftp bug fix is going to railroad EVERYTHING!!!!
C/
 grayskyz's gear list:grayskyz's gear list
Canon EOS-1D Mark III Canon EOS 10D Canon EOS 5D Mark III Canon EOS 70D
Philip Kendall
Philip Kendall Contributing Member • Posts: 789
7
What's your source for that number? I know what a hotfix costs my employer (a large enterprise software company), and it's significantly different from that.
 Philip Kendall's gear list:Philip Kendall's gear list
Canon PowerShot SD1000 Canon EOS 550D Canon EF 50mm f/1.8 II Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS II
(unknown member) Senior Member • Posts: 2,853
Based on past patterns, we have to wait at least two days.
8
You don't have any information that supports your numbers or your conclusion.  A revision is the most minor fix that anyone makes to firmware and they make changes right up until the moment a camera is about to be replaced.  The last firmware for the 5D Mark II was released on 2/28/2012.  The 5D Mark III was announced two days later.  TWO DAYS!  So if we're going to make wild, baseless extrapolations from almost zero information then I think what we've learned here is that we have to wait at least two whole days before Canon will think about announcing the 7DII.
elfroggio wrote:
Hi,
 howardroark's gear list:howardroark's gear list
Canon PowerShot G1 X
Dale Buhanan MOD Veteran Member • Posts: 3,996
elfroggio wrote:
Hi,
Thanks for the tip, Syv.  I just got it.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
bigfatron Contributing Member • Posts: 657
Re: Based on past patterns, we have to wait at least two days.
elfroggio wrote:
Hi,
So on that precedent then we can only conclude the 7D Mk 2 will be announced on Friday
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III +4 more
Canoman21 Regular Member • Posts: 206
elfroggio wrote:
Hi,
Who said anything about a 7D 2 coming in the spring anyway. Certainly not Canon?
 Canoman21's gear list:Canoman21's gear list
Canon EOS 40D Canon EOS 60D Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +13 more
Canoman21 wrote:
elfroggio wrote:
Hi,
Just the latest rumour says so, which was I think in about November after the last rumour never materialised in late September/October.
altair8800 Senior Member • Posts: 1,732
Dale Buhanan wrote:
elfroggio wrote:
Hi,
Yes, thanks for nothing!
Loren Charif Veteran Member • Posts: 3,697
I was thinking the same thing, but howardroark's post re:the 5dII makes sense, too.  Besides, there are probably tons of 7D's that will need the firmware fix whose owners will not upgrade to the MkII.
I'm not giving up hope...yet!  But, while I'm waiting, I continue to watch used 1DIV prices, just in case
Loren
Yes, I also watch used 1DIV prices, but they are not going down much, if at all.
rdspear Veteran Member • Posts: 4,386
5
You define it as a "marginal bug" and then claim it costs a million dollars to fix?  The Canon SW dev team doesn't have offices on 5th avenue in NY.  My support team releases 10-15 defect fixes every month, in addition to all support responsibilities, for $60k/month. And I guarantee to software is more complex than a camera's firmware.
I think this says nothing about a future camera release.
 rdspear's gear list:rdspear's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF-S 10-22mm f/3.5-4.5 USM +19 more
NancyP Veteran Member • Posts: 5,280
Once updated to 2.05, you can't revert to 2.03
Maybe there is something that shuts down third party batteries.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Mark B. Forum Pro • Posts: 19,375
elfroggio wrote:
Hi,
If it added significant new features as the last firmware did, I'd agree.  I don't think bug fix firmware rules out a succrssor.  It doesn't really mean anything one way or the other.
elfroggio wrote:
RS_RS wrote:
elfroggio wrote:
Hi,
  2. Assign a team
  3. Make the fixes
Being a bit dramatic aren't we??
bigfatron wrote:
Canoman21 wrote:
elfroggio wrote:
Hi,
Exactly that. 'The latest rumour'..... any fool can start a rumour .....the biggest fool is the one who actually believes it.
Until it's announced by Canon the CR1, CR2 canon rumors means diddly squat.
I am sure it's coming but I reckon Canon will want to have had the 70D out in the wilderness for, at least, another six months to push the sales along before they unload the 7D2 ......if it ever happens.
I am in no hurry.
