X10 not creating RAW image
Started Dec 11, 2013 | Questions
shu246
New MemberPosts: 6Gear list
Dec 11, 2013
X10 arrived yesterday.  NICE.
Kudos to DPReview - the go-to place for the straight skinny on digital cameras.
So - how can I get the camera to create a RAW image?  Desire to make RAW image only ocassionally.  In Setup Menu, selected RAW = off.  Per Page 55 of User Manual, pressing RAW button should create both RAW and jpg for the next shot.
Instead, display shows 4x4 grid of icons for ISO, DR, WB, etc.   Pressing shutter release takes creates jpg image only.
 shu246's gear list:shu246's gear list
Fujifilm FinePix E550 Zoom Panasonic Lumix DMC-FZ20 Fujifilm X10 Epson Stylus Photo R2000
Fujifilm X10
dual12
Regular MemberPosts: 382
Re: X10 not creating RAW image
In reply to shu246, Dec 11, 2013
I don't have that camera, but typically when a feature doesn't execute the way you think it should, you're in a mode that doesn't allow use of the feature.
Derek49
Regular MemberPosts: 185Gear list
You have the latest firmware installed on your X10 - this turned the RAW button into a Quick Menu button. Fuji produced an addition the to the orginal manual.
You can download it here:
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/x/x10_manual_02.pdf
Raw can now only be switched on via the setup menu.....
Enjoy your new camera !
 Derek49's gear list:Derek49's gear list
Fujifilm FinePix F40fd Panasonic Lumix DMC-TZ5 Sony Cyber-shot DSC-R1 Fujifilm X10 Fujifilm X-S1 +5 more
Lightpath48
Senior MemberPosts: 3,337Gear list
In reply to Derek49, Dec 11, 2013
+1 to Derek's comment. To get a faster route to the raw menu you can also assign it to the Fn button. If you want the Fn button for something else, you can go to the raw menu under set up, and then use the back button to exit out. The next time you hit the menu button you'll be back there.
 Lightpath48's gear list:Lightpath48's gear list
Sony Cyber-shot DSC-RX10
shu246
shu246 OP
Got it.  Thanks.  Hadn't unsealed the Owner's Manual that came with the camera; had been working with the .pdf from Fuji's website while waiting for the camera to arrive.
The X10 sure is a little fella; dainty little buttons.  But a lot of mojo!  Hot shoe and optical view finder.  What's not to like?
Shu
Trevor G
Veteran MemberPosts: 6,535Gear list
In reply to shu246, Dec 12, 2013
Also bear in mind that RAW is only available on P A S M and Auto.
There could also be some times when it is not even available then, but you can check the chart in the back of the manual (downloadable if it wasn't included) to see those.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
