Downsizing / Downsampling / Resizing or whatever you call it...
Started Dec 11, 2013 | Discussions
Elyharbour
Senior MemberPosts: 1,299Gear list
Dec 11, 2013
OK guys...as some of you know I've been down-(sampling or -sizing) my XF1 HR 12MP JPEGs to be directly comparable with the 6MP EXR hardware images for forum comparison. I usually do this in  FastStone Image Viewer, but sometimes in Lightroom.
In FastStone there are various resizing methods (Lanczos 2, 3, etc) and Kim Lettermann recently mentioned bicubic. What are the pros and cons of these methods? Are there any real differences for the sorts of images we're talking about here in the forums?
Thanks.
 Elyharbour's gear list:Elyharbour's gear list
Sony SLT-A57 Fujifilm X-E1 Fujifilm XF1 Fujifilm X30 Sony DT 35mm F1.8 SAM +8 more
Fujifilm XF1
PAUL TILL
Veteran MemberPosts: 9,285
Re: Downsizing / Downsampling / Resizing or whatever you call it...
In reply to Elyharbour, Dec 11, 2013
I always use Bicubic Sharper.
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
Elyharbour
In reply to PAUL TILL, Dec 11, 2013
Nice looking image you're working on there...
CAcreeks
Veteran MemberPosts: 8,452
Re: Downsampling / Resizing or whatever you call it...
Lanczos3 (also called Sinc) is the best algorithm for downsampling if you don't change aspect ratio. If you change aspect ratio, Bicubic (also called Cubic) works better.
I have not investigated upsampling (seldom needed) but believe the answer is is not the same as for downsampling.
There are many other considerations besides the downsampling algorithm, such as JPEG encoding afterwards.
Downsizing is a corporate euphemism for firing employees.
CAcreeks
Some pundits say it's better to use Bicubic, then Smart Sharpen.
I don't use Photoshop and have no opinion one way or the other.
jcmarfilph
Veteran MemberPosts: 7,592Gear list
Bicubic for me...
Here are some results showing superiority of Lsize versus upsampled MSize
Both downsampled to 1920px and LSize is still superior
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
Lloydy
Forum ProPosts: 18,888Gear list
Elyharbour ...
... To size an image down, use Bicubic Sharper.
To size an image up, use Bicubic Smoother.
Here is an article about sizing up - Resizing an image - Up
Thanks.
Cheers, Dave
CAcreeks
Re: Elyharbour ...
In reply to Lloydy, Dec 11, 2013
I don't really give a darn what everybody decides to do, but Bicubic (whether Sharper or Smoother) is definitely not the best method. Here are some examples:
http://bvdwolf.home.xs4all.nl/main/foto/down_sample/down_sample.htm
Elyharbour
In reply to CAcreeks, Dec 11, 2013
Lanczos3 is the default in FastStone, so I guess I'll just leave it as is. I tried the bicubic today and Lanczos2, and couldn't honestly see any difference, but neither did I really know what I was looking for.
PS - I now know not to call it down-sizing
Lloydy
CA ...
... Interesting article but I wonder how long back it was written and which version of CS ?
I downloaded the Rings Gif and resized, up and down, using Bicubic Sharper and Bicubic Smoother and had none of the issues described in the article. I'm using CS6.
I would encourage others to try the same with their own editing software and see what results they get.
Cheers, Dave
CAcreeks
Re: Dave...
In reply to Lloydy, Dec 12, 2013
Excellent test!  Did you start with the large version that was linked into the article?  It is possible that Photoshop resize has improved. I have not used Photoshop since CS2, but my daughter has CS5 on her Mac and I could try it to compare.
Cheers, Dave
Lloydy
CA ...
In reply to CAcreeks, Dec 12, 2013
... Yes, I downloaded the 1000 x 1000 pixel image and then played around with sizing up/down. Would be interesting to see how CS5 fares, or even the latest LR.
Cheers, Dave
Cheers, Dave
Futax
Regular MemberPosts: 344Gear list
In reply to Elyharbour, Dec 12, 2013
Lanczos certainly beats the other algorithms when it comes to the problem of aliasing when you downsample:
http://therefractedlight.blogspot.co.uk/2010/12/problem-of-resizing-images.html
 Futax's gear list:Futax's gear list
Sigma DP1 Fujifilm FinePix F70EXR Sigma DP2 Merrill Canon PowerShot SX50 HS Panasonic Lumix DMC-XS1 +4 more
Elyharbour
In reply to Futax, Dec 12, 2013
An excellent article. Now I understand what is going on. Thank you.
dick
Veteran MemberPosts: 5,082Gear list
A bit off subject, but I think RE-SIZING is the appropriate term.
My dictionary defines RE as, "again: for a second time." That makes sense, because the program has already set the size and we are sizing it again, thus RE-sizing. And that applies to both ways, up and down.
 dick's gear list:dick's gear list
Olympus C-2100 UZ Fujifilm FinePix S200EXR Fujifilm X-S1
CAcreeks
Re: Resize vs Resample
In reply to dick, Dec 12, 2013
Here's what the ImageMagick options say:
  • -resample geometry : change the resolution of an image
  • -resize geometry :  resize the image
Can you explain which does what?
CAcreeks
A good comparison of resampling products
This page was difficult to find with Google search, but seems like it might be helpful for all. At the bottom is a clickable image to compare results from 11 different downsampling methods.
http://bvdwolf.home.xs4all.nl/main/foto/down_sample/example1.htm
Nicolas Robidoux
Forum MemberPosts: 84
For reducing the size of an image, I highly recommend EWA (Elliptical Weighted Averaging) with slightly deblurred (meaning that the filter's extent is "shrunk" from the unwindowed version that's theoretically ideal from a frequency response viewpoint) 3-lobe Jinc-windowed Jinc filtering done through linear light (XYZ or linear RGB with sRGB primaries). Details here: http://www.imagemagick.org/Usage/filter/nicolas/
CAcreeks
In reply to Nicolas Robidoux, Dec 12, 2013
Do you mean "Jinc-filtered Sinc filter" ?
convert {input} -colorspace RGB +sigmoidal-contrast 7.5 \
-define filter:window=Jinc -define filter:lobes=3 \
-resize 500% -sigmoidal-contrast 7.5 -colorspace sRGB {output}
Lloydy
CA ...
... If you look at the bottom of the page it says copyright 2004.
My concern with these examples is that image editing software has progressed in leaps and bounds in the past ten years and posting tests as old as that one do not reflect today's reality.
As mentioned prior, I downloaded the Gif file for the original tests shown and replicated the tests done by the author.
My results showed none of the issues reported.
Post current data please so as not to mislead the discussion.
Cheers, Dave
