Is the AF on the 20mm 1.7 Pany fast enough for indoor events?
Started Dec 11, 2013 | Discussions
Marco Cinnirella
Veteran MemberPosts: 5,088Gear list
Dec 11, 2013
As per my earlier thread last week, I have a theater event to shoot and I have never tried this before.
At my disposal is the Oly 45 1.8, the Pany 20mm 1.7 and the Sigma 60mm 2.8 and in terms of bodies, an OM-D EM-5 and a Panny GX1.
I am presently thinking about the Sigma 60 on the EM5 and the Pany 20 on the GX1 - any idea how these lenses perform in low light when it comes to autofocus? I'm worried that they may hunt quite a lot and that I might miss shots through focus hunting? Thing is, I could really use the 1.7 fast aperture on the 20 so I can keep ISO down to 3200 or 6400 at a push.
Please don't suggest the Oly 75 1.8 or Pany 12-35 2.8 - I have to work with what I already have guys.
Thanks !
"When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence." Ansell Adams.
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Fujifilm FinePix X100 Sony SLT-A77 Olympus OM-D E-M5 Sony SLT-A99 Fujifilm X-T1 +4 more
Panasonic Lumix DMC-GX1
Gravi
Senior MemberPosts: 1,487
Re: Is the AF on the 20mm 1.7 Pany fast enough for indoor events?
In reply to Marco Cinnirella, Dec 11, 2013
I found the AF of the 20mm to be lacking, for my taste. If you shoot subjects at a distance, this might not be too much of a problem, but as you get closer to your subject, or have big changes in focussing distance between shots, the lens struggles.
I guess an AF light might help. The E-M5 has one, the GX1 I don't know.
Gravi
Marco Cinnirella
In reply to Gravi, Dec 11, 2013
Gravi
Yeah but I figure I will probbaly have to turn off the AF light as it will be distracting to performers and audience...
Peng Bian
Contributing MemberPosts: 608Gear list
You guys don't know what you started here. Stop replying to this thread before Anders sees it.
http://500px.com/PBian
 Peng Bian's gear list:Peng Bian's gear list
Sony Cyber-shot DSC-RX100 III Olympus OM-D E-M5 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
Marco Cinnirella
In reply to Peng Bian, Dec 11, 2013
Have I touched on a sore topic? I'm blissfully unaware !
Ulric
Senior MemberPosts: 3,219Gear list
The 20 hunts more slowly than other lenses. The solution is to not let it hunt, but find something better to focus on. Other than that, the difference, if any, is too small to matter (0.1 s or so, the 20 not necessarily the slower lens).
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
DaveLemi
Regular MemberPosts: 322Gear list
In reply to Ulric, Dec 11, 2013
Agreed. If it hunts you're going to miss any action. I've some difficulty focusing on multiple subjects.
 DaveLemi's gear list:DaveLemi's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +6 more
texinwien
Senior MemberPosts: 3,320Gear list
Correct. The 20 hunts more slowly than other lenses because it takes longer to go from closest focus distance to infinity focus than some newer lenses do.
As long as you don't allow it to hunt (half-press to achieve focus, let off if you sense it's starting to hunt, then choose a target with better vertical contrast and half-press again), and as long as you don't need to switch focus often and quickly between objects very close to the closest focus distance and objects closer to infinity, you should be fine.
On the "don't allow it to hunt" instructions - they sound more onerous than they are, really. With some practice, you should get the hang of it, and you'll start trying to lock focus on appropriate targets by default, out of habit, which will help you avoid hunting in the first place (works for any autofocus m43 lens, btw, not just with the 20mm).
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
panos_m
Senior MemberPosts: 1,287
Thanks !
From the lenses you listed I have only the 20/1.7 version 1. AF is generally slow both on GF1 and EM5. In low light without the AF assist light is almost helpless. It hunts endlessly and when it decides to stop somewhere most of the times is not on the target. It is much faster to focus it manually.
Panagiotis
Paul De Bra
Forum ProPosts: 11,999Gear list
No such problem here.
In reply to panos_m, Dec 11, 2013
We had a rehearsal and later concert in a very dark (and very cold) church. At the concert most pictures were shot at 1/40s f/2.2 ISO800 with a bit of help from bounced flash (as the church was really too dark to do anything without flash). I gave my E-M5 with 20mm to someone else to take pictures (I was playing in the orchestra) and there was no issue with AF. I have also used the 20mm at other concerts and as long as you focus on something with clearly defined contrast there is no AF issue at all.
Pictures at http://debra.zenfolio.com/rel-woerden-2013 (concert pics at the end).
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
s_grins
Forum ProPosts: 10,095Gear list
Thanks !
1.7/20 and 2.8/60. It depends on your location and intentions
Looking for equilibrium...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
assaft
Senior MemberPosts: 1,224Gear list
I'm pretty sure that you can safely use the 20/1.7 and the 45/1.8, but with the 20/1.7 it would be easier if you have some distance from your subjects. But I would switch the focusing modes between these lenses. With the 20/1.7 I would use Mode 3 and assign the focus button to one of the function keys. This allows to pre-focus on some clear subject and then to have the focus fixed for all the subsequent shots (of course do it only as long as the dof is deep enough). No danger of hunting and also the shortest capturing time (since no re-focusing). With the 45/1.8 I would use Mode 2, as the dof is usually narrow and requires more accurate focusing. In any approach you take, it's always good to begin the focusing when you are already focused close to your subject. Less effort for the cdaf algorithm to find the position with the highest contrast.
 assaft's gear list:assaft's gear list
Olympus PEN E-PL2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +5 more
brentbrent
Senior MemberPosts: 1,726Gear list
I recently shot a concert using mostly my GX1 with 45mm Oly, but also some wider shots with my G5 with 20mm. Having the two bodies with those lenses worked very well. Near the end I mounted the Oly 75 on the G5 for some closeups. I did not have any problems with the 20mm AF.
I suggest you take all three lenses, and when you get there you can decide which two you are likely to use the most (probably the 45 on the first body, and either the 20 or the 60 on the second body), but you may want to switch lenses on one camera at some point.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH +10 more
Henry Richardson
Forum ProPosts: 14,923
I don't know about the AF of the 20mm on the GX1, but on the E-M5 I found it to generally be okay even in low light. This shows you some photos I made with it in very low light with the E-M5. This link is about the banding problem of the 20mm f1.7, but it shows some Nepal examples taken using f1.7, high ISO, and fairly low shutter speeds (note, I had some better photos, but they were ruined by banding):
http://www.dpreview.com/forums/post/51029028
If you only use it on the GX1 then, I think, you won't see the banding problem. See this post:
http://www.dpreview.com/forums/post/52357014
Henry Richardson
http://www.bakubo.com
Sean Nelson
Forum ProPosts: 11,587
IMHO all of this really depends on how close you are to the stage.  Depending on the distance, I'd take whatever lens gives you a reasonable view of the entire stage, mount it on one of your cameras on a tripod, set it to manual focus, pre-focus, and then just let it run during the entire production.   This will be your "B camera".
Use a longer lens on the other camera to capture close-ups of specific actors and dialogue.  This is your "A camera".
In post-production, you can intercut "B camera" footage to fill gaps in your "A camera" clips where you are zooming or panning to reframe, or where the material is unsatisfactory due to shaking, exposure, focus hunting, etc.
If it turns out that it's the 20mm that's on the "B camera", then you don't need to worry about its focusing since it will be in manual focus mode.
Oh, and if possible get a microphone as close to the actors as possible.   A portable mic/recorder like the Zoom H1 is a great way to do this.
lambert4
Senior MemberPosts: 1,792Gear list
I always found the AF adequate, not as fast as the 45mm or even the 25mm but fast enough, and if you are shooting a stage or event where the subjects are relatively in the same DOF you should be fine.  Where it struggles is constantly moving subjects in low contrast settings in my opinion.
Good luck with it and worst case scenario go manual with it and fire away.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Olympus OM-D E-M5 Olympus E-M1
Anders W
Forum ProPosts: 21,460Gear list
I saw it all right. But informed and helpful people like Ulric and texinwienhave already said pretty much what I would say, so no reason for me to intervene.
Another good piece of advice is that provided by Sean Nelson. I don't know whether the OP intends to shoot video or stills or both, but with the 20, prefocusing once on roughly the point where the actors will be and then switch to MF will work nicely unless the OP plans to be on stage with the actors when shooting. No reason to wait for AF to finish its job wtih any lens when you are shooting at sufficiently far distance for the precise location of the subject not to matter.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
sean000
Veteran MemberPosts: 7,144Gear list
Re: Most theater doesn't require fast AF, but it helps to be close!
I have photographed a number of theater productions during dress rehearsals (as a favor to a director friend of mine who runs a nonprofit community theater). I haven't done this since 2011, so last time I did this I used my GF1 with 20mm f/1.7 and mostly my Nikon D200 with 17-55mm f/2.8. These days I shoot mostly with the E-M5.
You don't necessarily need to worry much about fast AF, but it depends on the performance and how much action there is. I was shooting Shakespeare, so there would be some action... but mostly the actors stood on their marks long enough for me to manually focus if I wanted to. The focal length will depend a lot on where you are. If you can get right up to the stage, then the 20mm will be fine. From farther back you may get more of the set and performers in the frame... which can also be fine, but I prefer to get tighter shots. I used the 17-55mm f/2.8 on my Nikon for most of the shots, and the 20mm on the GF1 for some as well, since I was able to get right up to the stage during dress rehearsals. The reason I used the 20mm was because I sometimes had a telephoto 80-200mm f/2.8 mounted to my Nikon. I'd switch between the two when I need wider.
As for AF: Some say the 20mm f/1.7 performs miserably on the E-m5, but I have never had issue with mine. It autofocuses as quickly on my E-M5 as it did on my GF1, and hunting (even in low light) is never a problem. I use it all the time to photography my two toddlers in very low light. It does exhibit banding at ISO 6400 on the E-m5, and some say they experience that at lower ISOs. But since you already own it, and both camera bodies, you know how it performs on your cameras. As long as you can move around a bit, I think you will do just fine using the 20mm on the GX1 and the 60mm f/2.8 on the E-M5 (Why not take the 45mm f/1.8 as well?). I have not experience with the Sigma, but I would not expect hunting.
The thing about theater is that the lighting can actually be quite bright on the actors' faces for many scenes. With an f/2.8 zoom I was able to stay mostly between ISO 500 and ISO 1200... 1600 or 3200 for darker scenes (like the storm scenes in the Tempest). I recommend spot-metering off their faces and chimping regularly to determine whether you need to dial in a little exposure compensation. Theater lighting can be really tricky. I actually used spot-metering along with manual exposure (most of the time) when I did it. I would keep an eye on the meter, but I wouldn't let the camera decide the exposure for me. If the scene was supposed to be dark, I let it be a little dark. For faster paced scenes I switched to Aperture priority and spot, center, or matrix metering depending on how wide I was shooting.
I highly recommend photographing a dress rehearsal if you can. Offer free digital copies to the director for rehearsal access. That way you can sit back and enjoy the performance on show night.
Sean
 sean000's gear list:sean000's gear list
Olympus Stylus XZ-10 Nikon D70 Nikon D200 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 +13 more
sean000
Re: Definitely shut off the AF Assist lamp
Gravi
Definitely do this, because it will be distracting depending on where you are shooting from. I actually never use the AF Assist lamp on any of my cameras. It doesn't seem to do a thing unless you're shooting in a closet or trying to shoot very low contrast subjects (bad AF targets).  Even when I shoot my kids in light that requires ISO 3200 6400 at f/1.7, I don't find AF hunting to be a problem with the 20mm on my E-M5.
Sean
honeyiscool
Senior MemberPosts: 1,304Gear list
The thing is, though, at some indoor events, "don't allow it to hunt" is easier said than done. If you press the shutter when someone's in the frame but the person is no longer in front of you, chances are that you will set off a hunt cycle, and that happens quite a bit. It also depends on how you're using the lens. Is 20mm f/1.7 used from a distance for an establishing shot, or is it used close up to get a dramatic close-up? It's OK for an establishing shot but if you're very close, prepare for it to be extremely disappointing.
That's because when you're half a foot from the stage, the closest things on stage are very close, many times closer than the furthest things on stage (and the back of the stage where the camera will sometimes try to focus) and you're trying to grab the kind of framing of a moving subject where you're focused exactly on the face, the 20mm f/1.7 will hunt like a hillbilly. But when you're even 12 feet back from the stage, everything changes and it becomes much more usable.
If you don't want to have to think about your lens when you're taking indoor event photos, that's where you might end up preferring the 17mm f/1.8 or 25mm f/1.4. I know I did, and I have both those lenses now, whereas I used to have the 20mm f/1.7.
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GH4 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 12-40mm F2.8 +3 more
