D800 and Auto White Balance
Started Dec 11, 2013 | Photos
alan schenk
Regular MemberPosts: 176Gear list
Dec 11, 2013
good morning all
I had occasion to visit the London Wetland Centre yesterday, dry but cloudy and used auto white balance, shooting in raw, aperture priority.
To date I have had no issue with auto white balance, but in yesterday's shots, I found that auto white balance was making the landscape much cooler than it was in actuality, around 4100K, as opposed to about 4850-5000 kelvin, which was more representative of true colour.
Attached below is one shot with auto WB, and then another taken with a manual adjustment at daylight (around 5000k). Having to go manual and dial in a WB setting to achieve the right colour, in what I would normally consider a non-challenging environment for the camera, surprised me.
However, given that I'm not a guru at this stuff, I thought I would ask the forum their thoughts and to educate me around my expectations. Going auto clearly isn't the be all and end all and one should be aware of when to go manual, I just didn't think on this occasion it would be necessary, thoughts?
with auto white balance, about 4100k...too cool to reflect reality
manually adjusted next shot to daylight, around 5000k...much more reflective of reality
 alan schenk's gear list:alan schenk's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +4 more
Comment & critique:
Nikon D800
yvind Strm
Veteran MemberPosts: 4,130
Re: D800 and Auto White Balance
In reply to alan schenk, Dec 11, 2013
Hello Alan
Its important to remember that AWB is no guarantee for retaining colors as they were, but that it tries to give you a neutral WB.
The algorithms measuring WB is as dumb as the exposure metereing.
If you meter a dark area, the meter will expose lighter. (Because all it knows is a difference compared to gray)
Same with AWB. If you have a dominance of one color, the camera will think that its the light that causes it, and compensate in the opposite direction.
In this picture, there is a lot of vegetation that have a warm tone. The AWB thinks this is due to warm light, which it tries to neutralize. Thus the cold tone.
alan schenk wrote:
good morning all
Kind regards
Øyvind
Ansel Spear
Contributing MemberPosts: 549Gear list
In reply to yvind Strm, Dec 11, 2013
They are, of course, very overexposed which hasn't helped.  They also look soft to me.
If you shoot RAW, white balance isn't a problem because you can have another go in post!
 Ansel Spear's gear list:Ansel Spear's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 24mm f/2.8D +8 more
SamG10
Regular MemberPosts: 310Gear list
My D800 AWB is very accurate especially on external shots.  I very seldom change or tweak it.  I also shoot 100% RAW.
 SamG10's gear list:SamG10's gear list
Nikon D40X Nikon D1X Nikon D4 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
Island Golfer
Senior MemberPosts: 2,264Gear list
In reply to Ansel Spear, Dec 11, 2013
I agree. This is more of an over exposure issue. I find that my D800 needs a minus 0.03 compensation setting as a matter of routine in order to help bring out the color in a scene.
truview
4x5 Guy
Senior MemberPosts: 1,341
In reply to SamG10, Dec 11, 2013
That's perhaps good to know (not really), but doesn't help the OP. His shots are overexposed and that will make it more difficult to evaluate WB.
I'm quite sure that you don't have a camera with an especially accurate WB sensor/software and the OP most likely does not have a defective WB mechanism.
larrywilson
Veteran MemberPosts: 4,451Gear list
For this type image I choose the central weighted exposure metering.  I do use matrix metering for some types of photography, but for animal subjects I use the weighted metering or even spot metering at times.  I usually will adjust the white balance in post processing to make the histogram is touch the right side and not climb up the right side and if I don't like this I adjust to my eye.  I do like my images just a little underexposed to enrichen the colors.  I shot in raw.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 500mm f/4G ED VR Tokina AT-X 16-28mm f/2.8 Pro FX Carl Zeiss Makro-Planar T* 2/100 +6 more
larrywilson
In reply to larrywilson, Dec 11, 2013
I shot this bird using auto white balance and center weighted exposure.
Larry
Warbler on a cold day
Ansel Spear
..However, another school of thought for RAW shooters is to shoot to the right by a stop or so and manipulate in post, bringing down the highlights whilst retaining shadow depth.
Theory being that highlights are capable of higher DR values than the shadows.  Extrapolating from that, an underexposed RAW will lose shadow detail before an overexposed RAW will clip the highlights.
I have preferred to shoot to the left in the past, but this method does have some credence.
SamG10
Larry
NICE!  what lens?  Did you use a teleconverter ?
larrywilson
I used a Nikon 500mm f4.0 vr lens with a tc 1,7EII attached.  I cheated and used a d4 ha ha!!!
Larry
